Chain came off today...
Ted
PostPosted: 15:44 - 14 Mar 2007    Post subject: Chain came off today... Reply with quote
Shocked ...just pulled away at a crossroad, had it in 1st gear (as you would when you pull away), ragged it a bit, attepted to knock it into 2nd, but somehow messed it up and discovered I was still in 1st when I let the clutch out, front end dived, so tugged on the throttle, then attempted 2nd again, but when I let the clutch out it just revved, assumed I had knocked it into neutral, so tapped it up again... still just revved (had come to a stop by now, at the foot of a steep hill), tried tapping it up, then down, just kept revving, thought the clutch had failed... then noticed the chain just resting next to the sprocket on the rear wheel!
Could have been much worse I guess!
Finglonga
PostPosted: 15:59 - 14 Mar 2007    Post subject: Reply with quote
When was the last time you checked your chain tension?
Andy Sez....
F.Y.Y.F.F.
Ted
PostPosted: 16:04 - 14 Mar 2007    Post subject: Reply with quote
I know it needs tightening... just havn't got around to it yet Embarassed
Mr.Everready
PostPosted: 16:05 - 14 Mar 2007    Post subject: Reply with quote
You mean you still havn't done it after that happening ?
techierob
PostPosted: 16:06 - 14 Mar 2007    Post subject: Reply with quote
just out of curiosity, is it completely unheard of for somebody to have a chain snap and cut into their leg? I've heard of people getting chucked off their bikes when a snapped chain caused the rear wheel to lock, but the idea of having a snapped chain lop my foot off always makes my arse clench Sick
MarkJ
PostPosted: 16:22 - 14 Mar 2007    Post subject: Reply with quote
It can happen apparently Sick
Louise
PostPosted: 16:24 - 14 Mar 2007    Post subject: Reply with quote
Thats one of the things that stick in the back of my mind when biking. Makes me cringe knowing my legs could be swiped off Sick
mr.z
PostPosted: 16:40 - 14 Mar 2007    Post subject: Reply with quote
Beaten to it but yes the can knock significant amount of material out of engineblocks/legs the other thing is say your travelling at 70 and the chain flys off and your unlucky enough for it to jam up the back wheel, well you can easily imagine what can happens next..
Having your chain maintained properly, fitting it properly and using a good brand makes it very unlikely to have problems, although a mate had his wheel lock up and he found the cause was a metal co2 cylinder had got lodged in the front sprocket (and cut it almost in half)
I'm not saying it to be smug but its one of the many reasons I couldn't have another chain drive bike again :/ if i did I'd make it an enclosure a-la cg125
The Tot
PostPosted: 17:06 - 14 Mar 2007    Post subject: Reply with quote
Could this be down to the black visor that you received today Cool Laughing . It could be a lot worse, so you're pretty lucky that you were going at a slow speed. I think Dodsi's chain came off at the split link Confused Shocked but he managed to keep it up. Keeping chain well lubed and tensioned is the key to this sort of instances occuring. Anyway, you've learnt your lesson now, so please be careful next time around. 10 minutes on a paddock stand and some spanners surely won't hurt.
Never argue with autism
doggone
PostPosted: 18:07 - 14 Mar 2007    Post subject: Reply with quote
Also while cleaning and lubing look at it properly.
Sometimes one of the side plates will come adrift and but it will hang together for a while.
Rookie
PostPosted: 18:09 - 14 Mar 2007    Post subject: Reply with quote
It always makes me squirm when I realise that chain is spinning at a phenomenal speed, inches away from my left foot. Sick
st3v3
PostPosted: 18:12 - 14 Mar 2007    Post subject: Reply with quote
happened to me recently, didn't tighten chain up for 2 weeks, kept popping off at most inconvenient spots but it's tight now, and I'm fitting new tensioners tomorrow Cool so me tyre don't get too fvcked Embarassed
Ted
PostPosted: 19:07 - 14 Mar 2007    Post subject: Reply with quote
Yeah I'm pretty sure a motorbike chain can cut at least down to the bone in someones leg... I had a pushbike chain snap and cut my leg open... the scar has only just faded enough to not be noticeable!
My chain is lubed up and cleaned properly, I spent ages on it and the sprokets about 3-4 days ago, and I re-lube it before I go out on longer journeys, but I had trouble trying to tighten it, know I realise what I did wrong, but didn't have a chance to tighten it, I guess I should have made time to do it!
And no, I havn't sorted it yet, I was on my way home when it happened and managed to get the chain back on, I prob won't use the bike again until the weekend, but I will sort the chain out before I use it!
moonym20
PostPosted: 19:27 - 14 Mar 2007    Post subject: Reply with quote
Its a mistake you only make once Twisted Evil
happened to me last year when i tried to get every last mile out of my chain before getting it replaced, it jumped onto the plates when i went over a speed hump and got very tight and twisted. loosened the rear wheel off put the chain on and tightened it up and got 2 miles before it went off permanently
make sure that your chain has not twisted! you will soon find out when it comes flying off again when the first hint of slack appears!
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
Dazbo666
PostPosted: 19:35 - 14 Mar 2007    Post subject: Reply with quote
Shocked erm, isn't that enough of an incentive to make sure you keep on top of the maintenance?!
Keeping all my limbs intact and in the correct places is good enough for me Laughing LOL
Word of the day : DILLIGAF
moonym20
PostPosted: 19:39 - 14 Mar 2007    Post subject: Reply with quote
I forgot to mention J.G. Parry-Thomas
he was killed in 1927 (in a car..) when the drive chain snapped... if i remember rightly his head was poking out one side of the cockpit at the time the chain snapped.... it took his head clean off Shocked
https://en.wikipedia.org/wiki/J.G._Parry-Thomas
Cognitive_Faux
PostPosted: 19:56 - 14 Mar 2007    Post subject: Reply with quote
im glad im not the only 1 having a bad day lol (sorry)
yeah my chain slip a fair bit on my YZF6... but thats because my sprockets are abit hooked... was trying to sell it but im replacing them first...
..guna hav to use it now though as a car decided to pull out on me TODAY while i was on my Fazer..... its not fair.
so to recap. adjust the chain when u can, its on a five minute job
bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass)
crazymotorbik...
PostPosted: 20:58 - 14 Mar 2007    Post subject: Reply with quote
Im glad ive got a belt driven bike Thumbs Up
Altough i must admit i do think about the chain coming off on my other bike Thumbs Down
I like my legs attached to my body thank you.
rhone81
PostPosted: 22:24 - 14 Mar 2007    Post subject: Reply with quote
Chain snapped on my insurance hire bike (Suzuki Van Van). Hillstart away from lights, up into second and severed completely. Completely my fault - didn't clean it or lube it for 2 months... Embarassed
Happens to the best of us - my instuctor had his chain snap a few years ago - on his way to interview at the bike school!
Louise
PostPosted: 22:25 - 14 Mar 2007    Post subject: Reply with quote
Are you saying I need to check my chain every week Shocked Ive not done it since I had it fitted - Tell a lie, other day But apart from that I hadnt checked for a few weeks
wilbur
PostPosted: 22:29 - 14 Mar 2007    Post subject: Reply with quote
Are you saying I need to check my chain every week ?
Its not a bad idea.
Simple
PostPosted: 22:34 - 14 Mar 2007    Post subject: Reply with quote
A friend recently had a chain snap on their 636, it hit the pillions boot, she has a little scuff on the leather where the chain whipped Shocked
Insta - FemFeral
SoND
PostPosted: 23:01 - 14 Mar 2007    Post subject: Reply with quote
Its not a bad idea.
You should be checking it near enough everytime you go out.
moonym20
PostPosted: 23:04 - 14 Mar 2007    Post subject: Reply with quote
I go on the assumption that when some folks never check or even tighten their chains they never really bother to lube them either Confused
a paddock stand pays dividends when tightening your chain and more importantly when giving it a good lube. you may find that your chain life extends a bit more..... Wink
The last post was made 19 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 130.47 Kb
