help tyres for gs500e
jp007
PostPosted: 21:34 - 15 Mar 2007    Post subject: help tyres for gs500e Reply with quote
hi
i need some help
i just order 2 new tyres for my suzuki gs500E year of 1999, but i ordered the wrong rear tyre size i ordered the 150/70 zr 17 the michelin pilot road .
can you please tell me if fit“s and if i fit the tyre do i going tohave any problemes ?
thank you
paul
Resurrection
Ballast Boy
PostPosted: 21:50 - 15 Mar 2007    Post subject: Reply with quote
Can't you swap them for the correct sizes?
Res
ZX9r
jp007
PostPosted: 22:20 - 15 Mar 2007    Post subject: Reply with quote
no
i can not send them back
Resurrection
Ballast Boy
PostPosted: 19:33 - 16 Mar 2007    Post subject: Reply with quote
Whys that then?
Res
ZX9r
veeeffarr
PostPosted: 19:36 - 16 Mar 2007    Post subject: Reply with quote
Racers use 150 profiles on the GS (Yes there is a GS race class)
They will fit, but I wouldn't like to run them to be honest, they will change the bikes handling, plus I like to run my bike stock.
For reference.
You need these:
110/70/17 Up front
130/70/17 On back
I've always found BT45's to be good.
Question: Why the f**k order Z-rated tyres? There's no point, and I think some places will refuse to plug Z-rated tyres.
geordiecbrblo...
PostPosted: 13:42 - 17 Mar 2007    Post subject: Reply with quote
Buy the right size and ebay the wrong one is the only sensible thing to do Wink
hmmmnz
PostPosted: 18:20 - 17 Mar 2007    Post subject: Reply with quote
i ran a 150 on the original 3.5inch rim, its a little tight to both the chain and the torque arm, but doable, it also doesn't handle as well as the 130 on the original rim,
you could try and find a bandit 400 rim and put the tyre on that as its a 4 inch rim, the sprocket carrier from the gs can be used,
you would have to slice the thickness of the caliper bracket to get it to fit correctly,
in short you can get a 150 on the gs rim (with a little bit of tweaking, eg space the rear sprocket with washers, and shift over the torque arm)
have fun Thumbs Up
the humans are dead
I kick arse for the lord
The last post was made 19 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 50.2 Kb
