| Stridz |
 Stridz Two Stroke Sniffer
| Gazdaman |
 Gazdaman I did a trackday!!!
| R4nger |
 R4nger World Chat Champion
| bish777 |
 bish777 World Chat Champion
| steveh |
 steveh World Chat Champion
 Posted: 02:08 - 10 Mar 2007 Post subject: |
| R4nger wrote: |
The Thunder is also turns in slow into corners, has the worst headlight beam pattern in the world (Candle in the wind springs to mind) and you have to service the brake callipers each time you change the oil otherwise they will more than likely seize up |
I disagree..
The thundercat..
Standard yes, Ive dropped my forks a 1.5cm and it flicks into corners faster than most other bikes ive ridden, also being jacked up at the rear helps as the wheel base is slightly shorter.
The headlight as standard, is wank ill admit, but a strong bulb does help and i never have any problems in lanes.
As for the brakes, ive done my seals, not because they needed doing, just because they were there, cheap, and i like strong brakes, never had any problems, spray of brake cleaner now and then helps.
Watch out for 2nd gear failure in the older models, it usually goes around 30k, simple way to test, is jam the throttle open in 2nd, from 4k, if it falls out of gear, the selector arm is fooked.
(make sure you got a long road, as you will be doing over the tonne.)
Spend abit of time setting up your suspension, ride height ect and you will not be left behind by anything.
The 'ace
Never owned one, but read about, and ridden one.
The ace is a lot heavyer than the cat, a lot wider and eats a lot more fuel..
they knock out about 150 bhp (says the book ) so only about 50 more than the thundercat.
Doesnt seem to have an issue with the 2nd gear munchies, but are prone to valve seizure.
Also wich i find interesting, the thundercats (book) top speed is 159.blah mph.. yet the thunderace is 158.4mph.
obviously speed isnt everything, the ace will get there faster (cat is 3.9 seconds iirc) not sure about the ace, but it will also guzzle up more fuel.
And finally, the thundercats better looking, cheaper to insure, more fun, and Very underrated.
Oh, i own a thundercat btw. ____________________ Current : 06 Zx10r, 07 Wr450f SM, 74 850 norton commando, 63 bsa b40, 1962 Triton 650, 67 Triumph Tr6r, 1955 Triton 750, 1978 TY250E. |
| bish777 |
 Posted: 02:33 - 10 Mar 2007 Post subject: |
| steveh wrote: | they knock out about 150 bhp (says the book  ) so only about 50 more than the thundercat. |
ONLY 50 horsepower? That means the thunderace will walk away from the thundercat in any rollon competition. This also means the motor will be more relaxed when cruising, needing far less revving.
| steveh wrote: | Doesnt seem to have an issue with the 2nd gear munchies, but are prone to valve seizure. |
No more than any other 20 valve yamaha.
| steveh wrote: |
obviously speed isnt everything, the ace will get there faster (cat is 3.9 seconds iirc) not sure about the ace, but it will also guzzle up more fuel. |
The gearing limits the top speed of the ace. take a few teeth off the back and im sure it would manage a fair bit more. It also means the aces accelleration is ferocious, the thundercat would feel quite anaemic by comparison. Also i think the top speed is more like 165-170.
| steveh wrote: | And finally, the thundercats better looking, cheaper to insure, more fun, and Very underrated. |
well to riposte
looks are subjective, the ace isnt bad to insure, what could be more fun than the full on grunt of a litre bike as apposed to a revvy and tiresome 600, and the Ace is underrated also. ____________________ GSXR1100J |
| APNess |
 APNess Trackday Trickster
 Posted: 00:12 - 11 Mar 2007 Post subject: |
Haven't ridden a Thundercat, only an R6, Gixer 6 and ZX6r, and my ace of course.
Roll on performance isn't even a comparison - an ace with a working exup valve (I mention that cuase they often rust, seize, generally need looking after and some people can't be bothered, so check it works) will simply stroll away (or it did in roll ons with my mates anyway, not really a contest.)
Brakes are good, fairing a bit flabby makes bike seem bigger than it is, oil consumption take a fairy liquid bottle full of the stuff and stash it under seat or in a pocket, you'll be ok. Mileage from tank varies depending on riding but I've seen 135 before the light came on, so it's reasonable.
Insurance cheaper than you might think - I have no no claims (this is my first bike) and pay £300 TPFT. Sporty 600s were a group or two higher, strangely enough.
When it comes to twistys the 'ace will make it's weight felt - treat it like it is - a sporty tourer.
145hp at crank means around 125-130 at back wheel, nice spread of torque from 3k rpm on.
Headlight is crap, some H4 car bulbs fit in when you bend a tab on the bulb over (you'll see when it's time to fit it).
You can usually get an 'ace for less than 2k on ebay/autotrader, plenty about.
Fit longer (albeit only slightly) dog bones (suspension tie rods) to sharpen up steering, but beware that your back brake will lock up easier with less weight on the wheel. I like using both, keeps the things moving, though some will call me a wuss for using it at all, so I took the dogbones off. I'll try them again when I get decent tyres - got crappy macadams on at the moment, and they are rubbish unless riding in a straight line.
Even then I've had the back end try to overtake me a few times...
Thundercat is probably much the same in many respects, just 10kg or so lighter, slower, better on fuel, cheaper to insure and easier on tyres/chains.
No idea where the 'Thundercat is faster' argument comes from. I think an 'ace will do 160 in 4th, certainly does around 145 in 3rd if I remember right. Needs caning in 4th to get best out of 5th, but I haven't explored the upper reaches of the rev range in 5th yet. |
| Zimbo |
 Zimbo World Chat Champion
| bish777 |
| krebsy |
 krebsy World Chat Champion
| Stridz |
| Cognitive_Faux |
 Cognitive_Faux Nova Slayer
 Posted: 17:00 - 16 Mar 2007 Post subject: |
never owned an ACE, but i do have a T'Cat... i have had it about a year, its done 62,000 miles and its still going, its probably not quite 100 bhp anymore, some them horses have probabliy run away
i think the Tcat is classed as a sports tourer (according to my insurence co.) i got it about the same time as a friend got his R6... the R6 was all or nothing, where as the tcat was smoother (he agreed)(gearbox wise)
yes the headlight is crap.
they are fooking ugly front on.
and the brakes are also a pain in the arse.
all that plastic is a pain in the arse when you want to work on it (why i got the fazer).
i did have it up to an indicated 155mph (not on public roads officer .
i recently went to avebury from crawley (174.4km according to auto-route)(all the way there and harf way back was 1 tank, filled up in reading)(£15-£17 to fill it)
i dont no what that works out at mpg wise.
and for fook sake, get one thats not been pissed about with, mines done all them miles because its absolutely standard. ____________________ bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass) |
| strag |
 strag World Chat Champion
 Posted: 18:51 - 16 Mar 2007 Post subject: |
I've had both. The Cat, whilst a competent bike, single and pillion, is nowhere near as quick as the Ace. I swapped the cat for the Ace as I was doing a lot of 2 up riding, the Ace is better than the cat for this as it has far more torque.
The headlight on the cat is abysmal, much better on the Ace as it has a twin headlight in a single unit.
Don't be put off by the weight of the Ace, it is much more nimble than you think and will outhandle the majority of riders. I used mine on track alongside a lot of cats and to be honest, it pissed all over them. It will leave 600s standing. A cat will be generally around 96BHP, so that extra BHP does really tell, I was a member of the Cat MSN site and have been on many rideouts with Cats (and other 600s) while I have been on the Ace, no contest.
I saw well over 170mph on the clocks on the Ace, so no idea where the figures came from in the post above.
Fuel, I could get 180 miles on the Cat before reserve light, I could get 140 on the Ace before reserve, there isn't that much in it. Obviously The Ace will use a bit more, but it is a 1002cc bike.
My Cat never chewed second gear and My Ace did not excessively use oil. These are known issues on these bikes though, so beware.
The Ace has a harder seat, and the bars are below the yolks so has a more full on riding position.
I sold mine 2 years ago and it is still running very well and looking nice.
I liked both bikes I owned, they did what they should have done, and I had fun doing it. But overall I much preferred the Ace. Funnily enough, my wife found my K4 GSXR1000 more comfortable as a pillion than both the Ace and the Cat. She hasn't been on the K5 though.
The consumables on the Ace aren't bad either. I would get 3-4,000 out of a rear and I had 20k from chain and sprockets.
My advice would, as always, have a ride on the Ace and see if it suits you.
Oh, and the Ace only has 5 gears. ____________________ carbon bling |
The last post was made 19 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
