Exhaust repair
Le Chien
PostPosted: 18:26 - 16 Mar 2007    Post subject: Exhaust repair Reply with quote
Hi Guys, I have a problem in that my exhaust appears to have rusted at the join between the back end and the front end. Looking at it , I could see how it could be fixed so have tried a couple of exhaust repair goods available at Halfords (putty, bandage etc..). They don't seen to have worked but I think that a welder might have some luck fixing it. Is this a good idea? basically the cost of repairing it might be more than the cost of the bike (I've had some silly quotes). Any ideas welcome.... Confused
0ddball
PostPosted: 18:33 - 16 Mar 2007    Post subject: Reply with quote
Can you post a pic?
finpos
PostPosted: 19:25 - 16 Mar 2007    Post subject: Reply with quote
You've got two problems:
1. The two parts of the exhaust will be moving against each other. So any non structural bodge (bandage, filler) will just shake itself off. I guess you've discovered this for yourself Smile
2. It's tricky to weld rusty metal. If you ask someone to do it, they will give you a sod-off quote. I guess you discovered that as well Smile
If you are desperate to fix it yourself for cheap, the only way to do it is to make a long sleeve, which can fit either inside or outside the existing tubes. The idea is to provide some mechanical strength. Use big clamps to keep it in place, and use some elastic type of filler (high temp silicone) to stick it all together.
finpos.
Le Chien
PostPosted: 21:04 - 16 Mar 2007    Post subject: Reply with quote
Hi,
So I guess it's a new exhaust then! Anyone got any ideas on the place(s) to get hold of a new system and an idea of how much I should be paying? Also best places to get it fitted or is it a fairly easy job?
Cheers...
PS it's for a Suzuki GSX 600F (2000)
The last post was made 19 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 43.77 Kb
