Generators
Annabella
Like a person, only smaller
PostPosted: 21:17 - 31 Aug 2003    Post subject: Generators Reply with quote
Ok, any help appreciated.
My CBR has a small problem. When the lights or cooling fan are on, the charging voltage across the battery drops considerably (from well above 12V to below 11.3V). Hence, it won't start, as Keith knows!
To me this seems like a generator problem. Any ideas how I can check that this is the case, any one changed the generator, and any ideas on cost?
Bit vague, sorry about that!
Avast! Pirates ahoy!
I did Cadwell! Very Happy
TiN
Pocket Tin
PostPosted: 21:19 - 31 Aug 2003    Post subject: Reply with quote
Could also the regulator/rectifier? They cost between around £50, and I think that the CBR400 uses that same unit as the CBR600 and Fireblade.
TiN
dotgems.net
McJamweasel
BCF Junkie
PostPosted: 21:20 - 31 Aug 2003    Post subject: Reply with quote
Try feeding the hamsters an extra half portion of feed every day, it'll work wonders! Razz
Sorry, couldn't resist
Robby
Dirty Old Man
PostPosted: 21:30 - 31 Aug 2003    Post subject: Reply with quote
my vfr did the same thing. Rewound alternator was about 70 quid all in through elliotts.
Fitting it is an arse tho, you need a rotor puller or something. I got it done in the local shop.
Wouldn't expect it to be reg/rec. Blow reg/rec normally gives a higher voltage or nothing at all.
PostPosted: 22:45 - 31 Aug 2003    Post subject: Reply with quote
Could be the regulator / rectifier, but as Robby says they normally fail by frying the battery or failing to charge totally.
Use a multimeter and check for the correct resistance over to wires for the alternator.
Other possibility is that it has done the same as the GPZ500 and had the magnets come off the alternator rotor.
kevo
Cop Seeking Missile
PostPosted: 23:59 - 31 Aug 2003    Post subject: Re: Generators Reply with quote
Try this groovy fault finding chart.
Regards,
Kevo.
The last post was made 22 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.92 - MySQL Queries: 13 - Page Size: 48.85 Kb
