| Phil_G |
 Phil_G Traffic Copper
 Posted: 20:13 - 17 Mar 2007 Post subject: Repair Vs Replace |
Ok,
What would you guys 'n' gals do?
My 1997 ER5 has decided to blow its headgasket and Im in a bit of a quandry as to what I should do.
Repair its existing motor, or replace it with another.
As i see it there are advantages and disadvantages to both sides and I would appreciate some other peoples points of view.
Repair: I know the motor has good bearings in it, and has up to now run well. The clutch is good, and it doesnt burn oil. Therefore, I know that once the gasket is done, I would have a theoretically sound engine, with which i can go back to enjoying the highways and byways of North wales. I haven't let the motor overheat, so I hope that it would repair quite well.
Good: Known motor, matching numbers, no hassle of dragging dirty lumps about teh country
Down: Motor higher mileage, hassle stripping and rebuilding etc
Replace: Unknown motor. Would be lower mileage than mine is atm (55k!) but whose to say how its been treated and what sort of crash or instance caused the donor vehicles demise and what are the consequences of that within the motor?
Good: Easy and hassle free swap over, possibility of lower mileage unit.
bad: Unknowns, got to collect or hassle of arranging couriering of motor.
Any points ive missed or you feel add to either side of the argument, then please feel free to add
Cheers
Phil ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 20:31 - 17 Mar 2007 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=80892&highlight=tit+bum+fanny+wank
I got rid due to a knackered engine and I wish now that I had kept it. I was dubious of undertaking the task of changing an engine, so it went . After mucking about with the FZR, I would now say 'bring it on' . Its really quite easy to break a bike and put back together as long as you are sensible and methodical In all, start at breakfast time and by lunch, you'll be ready for a little spin
If you are going to get a new engine, try and get one that is running or heard running as you said, could be a lemon.
Buy another bike and canabolise whatever you want and will always have spares for all eventualities
Roll up your sleeves and have a go at the repair? May be a little tricky if things get messy and time / money consuming?
If you like the bike, then whatever makes you happy. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Phil_G |
 Posted: 21:01 - 17 Mar 2007 Post subject: |
thanks for the input
The bike felt like it had ample power for my modest abilities, even when it would appear to have been manifesting symptoms of failure, so I will no questions asked retain the bike, but I dont know whether I should just repair the motor it has now or replace the dead motor with a good one. that is the only quandry  ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| iooi |
 iooi Super Spammer
 Posted: 21:51 - 17 Mar 2007 Post subject: |
If you know the rest of your engine is sound then repair. It will be a lot less work, and you at least know waht you are dealing with, unlike a replacement engine which may have many other little faults.
But i think you already know which way you are going..  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Phil_G |
 Posted: 22:46 - 17 Mar 2007 Post subject: |
I must admit i am debating repair, and whilst there, I will redo the timing chain and tensioner.
how hard are these things to work on? ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| john2 |
 john2 Brolly Dolly
| cheekythomas |
 cheekythomas Crazy Courier
| Zimbo |
 Zimbo World Chat Champion
| stu_m |
 stu_m Crazy Courier
| Odie |
 Odie World Chat Champion
| cestrian |
 cestrian World Chat Champion
| Phil_G |
 Posted: 13:20 - 18 Mar 2007 Post subject: |
| Odie wrote: | if you are going to change an engine because the head gasket is gone you have more money than sense unless you have major problems with the engine!
sell me the bike, i will fix it and then sell it, the job is so easy to do! |
I dont have more money than sense, I am merely trying to be realistic and consider that a 55,000 motor might not be the most likely candidate for repair.
Then price in that gasket sets are coming in at £65-70 for top end gasket sets, I thought that I should consider all options. I have priced genuine gaskets and they are about 25+vat for the head gasket, and they also mentioned the base gasket at 17ish+vat. Its also a lot easier to collect a motor, and then pull one out, stick another one in and then ride off into the sunset!
@ Kickstart: The motor hasnt been overly hot as I can tell. The problem has only manifested itself with a slight hesitation when opening the throttle at low motor speeds. I hadnt noticed coolant loss and thought that it could be fuelling issues, so I got the local bike place to have a look/set it up for me, and they then spotted other problems which culminated in a compression test that indicated one cylinder at 125ish PSI and the second one around 70PSI (think thats what they said.)
thanks to all who have commented. ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| Odie |
| sickpup |
 sickpup Old Timer
| Phil_G |
| sickpup |
 sickpup Old Timer
| Phil_G |
 Posted: 20:21 - 19 Mar 2007 Post subject: |
cool!
wont be picking it back up for a while yet, so id appreciate a heads up when you got it done
thanks again
The last post was made 18 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
