Oxford Hotgrips
scottinbelfas...
PostPosted: 23:04 - 18 Mar 2007    Post subject: Oxford Hotgrips Reply with quote
Hi Guys
Please somebody help!
Fitted 2007 Hotgrips to my Suzuki GSX600FY they are the 2007 model with 4 leds to select power level
Fairly straightforward to fit but slow due to the fairing
Took live feed from rear brake light switch i.e. no power flowing when ignition switched off.
Grips worked fine on testing but if I turn on the lights or flash the PASS button the grips switch off, if I turn bike off and restart it grips turn on and work
The grips dont switch off if I push the horn, use indicaters or apply front or rear brakes
My thoughts are
1. a faulty grip temp controller
2. battery on bike not 100%
but Im only guessing
Any help would be great
Scott Question Question Question
stu_m
PostPosted: 23:27 - 18 Mar 2007    Post subject: Reply with quote
sounds like the head light is sapping all the power for the lights and turning the grips off ie not enough power to them while the head light is on Confused
check all your wiring to make sure all connections are good
also check the earths
im also only guessing
Stu
Ichy
PostPosted: 06:39 - 19 Mar 2007    Post subject: Reply with quote
Is this with the engine running or just with the ignition turned on?
scottinbelfas...
PostPosted: 09:37 - 19 Mar 2007    Post subject: Reply with quote
Its with the engine running
negative direct to battery negative, live direct to brake light switch I had no other connections to make its the rest are all push in connectors.
Thanks
Scott
extreme3d
PostPosted: 19:06 - 19 Mar 2007    Post subject: Reply with quote
The bikes wiring loom is not designed to take 3+ Amps. Especially the brake light switch wires which are skinny little things!! You need to take the power direct from the battery. To enable the grips to be turned off with the ignition you need to use a relay. The rear brake live (which is always on even if the brake light is not) is used as the signal wire that opens the relay allowing the battery circuit to open. When the ignition is turned off, the switch wire ceases to be live and the relay cuts the power from the battery.
This wiring diagram should help. You can get a suitable 12volt automotive relay from halfords for around £5. The fuse must go between the relay and the battery. Ideally as close to the battery as possible.
https://i10.photobucket.com/albums/a129/extreme3d51/wiringdiagramheatedgrips.jpg
scottinbelfas...
PostPosted: 08:12 - 20 Mar 2007    Post subject: Oxford HotGrips Reply with quote
https://i10.photobucket.com/albums/a129/extreme3d51/wiringdiagramheatedgrips.jpg[/quote]
Thanks to everyone for their help
Scptt
The last post was made 18 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 48.33 Kb
