exhaust s
marko
PostPosted: 22:11 - 01 Sep 2003    Post subject: exhaust s Reply with quote
Hi all i have a exhaust with a exspantion chamber it is about 2 inches from the manifold and about 9 inches long . could anyone ell me what will happen if i cut this off and weld a plate over the hole to make it a straight thro pipe. any help please much appriciated thank you
Shocked my eyes are wide with interest in this pipe could it be the ristrictor ????
McJamweasel
BCF Junkie
PostPosted: 22:28 - 01 Sep 2003    Post subject: Reply with quote
You mean take off the expansion chamber?
You'll bugger the power completely. They are there for a reason. Rolling Eyes
cagiva gezzer
PostPosted: 23:40 - 01 Sep 2003    Post subject: Reply with quote
Are you talkning about a scooter exhaust?
If so, this small pipe is the restrictor for the exhaust. Its not the expansion chamber, its a chamber which makes the expansion chamber seem to the engine to be a larger volume. It makes the exhaust less efficient and reduces power.
If you remove it and seal the hole up, it should increase power.
marko
PostPosted: 14:01 - 02 Sep 2003    Post subject: exhaust exspation chamber Reply with quote
right the bike is a 125 cagiva mito 2000 model.
so is the ristricto actually in side the main exhaust chamber and not in the exspantion chamber???? Neutral
Dr Nick
PostPosted: 15:42 - 02 Sep 2003    Post subject: Reply with quote
Why don't you buy an aftermarket pipe, and when you come to sell the bike you can take it off and put original one back on, plus it will go a lot better with something like an arrow pipe on it.
marko
PostPosted: 19:11 - 02 Sep 2003    Post subject: exspantin chamber Reply with quote
i have decided to leave the pipe alone and bye a aftermarket exhaust this way i wont mess up. Will the bike need retuneing tho if i put a arrows on it????? Neutral
McJamweasel
BCF Junkie
PostPosted: 22:30 - 02 Sep 2003    Post subject: Reply with quote
Yes, it will need rejetting. You will also need to remove the other restrictors, although I'm not sure what they are on the Mito.
An aftermarket pipe won't make much difference over a standard derestricted one tho.
93 NSR
PostPosted: 22:45 - 02 Sep 2003    Post subject: Reply with quote
i've got mito and it's got a acerbid back box on it but i'm not sure if the expansion chamber part of it is standard or not. How can i tell? i had to put the standard back box on for the mot it and it was real hard to ride.
Also what sprockets would you recomend because it only does 100.
Craig.
Racer X
PostPosted: 18:29 - 03 Sep 2003    Post subject: Reply with quote
want more speed, try a 15T or 16T front sproket, leave the rear sproket as it is!!
< Live To Ride & Ride To Live >
93 NSR
PostPosted: 22:26 - 03 Sep 2003    Post subject: Reply with quote
what do you rekon is on the front at the moment then?? saves me taking all the fairings off! its an early mito, mk1.
Craig
Dr Nick
PostPosted: 00:15 - 04 Sep 2003    Post subject: Reply with quote
probs 14:36
uprate the front to a 15 for more top end
Scotty
Scooter Boi
PostPosted: 00:21 - 04 Sep 2003    Post subject: Reply with quote
Remember doing that will see you a loss of accleration, and maybe even a lower top speed. as i wouldnt say a 125 can budge past 100mph if its lucky...
And changing the gear ratinos so there taller will / maybe make the give be slightly out of the peak power band thus owering your top speed, or renderning your last gear crap...
i'd probably only go up gears id the cylinder was bored out... or i had some mods to make the engine put out more BHP.
Regards
Scott
PostPosted: 01:18 - 04 Sep 2003    Post subject: Reply with quote
Craig
It should be 14/41 or 14/43 for a Mito 1 (first for a Mito Racing, 2nd for a plane Mito) according to the workshop manuals
93 NSR
PostPosted: 09:17 - 04 Sep 2003    Post subject: Reply with quote
i'll go and chech the rear sprocket then. i think it's the mito racing but i may be wrong. Any clue where i can get hayne's manuel??
Craig.
cagiva gezzer
PostPosted: 23:51 - 04 Sep 2003    Post subject: Reply with quote
Haynes dont do one, but you can downlaod them from keith's site or buy a cd version from ebay.
https://www.alfa-pages.co.uk/cagiva/c12.htm
Zimma
Wheelie Junkie
PostPosted: 01:37 - 05 Sep 2003    Post subject: Reply with quote
Oooooh, they make a flying Mito?? Mr. Green Now then Keith, I didn't expect that kind've mistake from you old chap. Wink Razz Very Happy
-Zimma
PostPosted: 19:58 - 05 Sep 2003    Post subject: Reply with quote
Mmm, suspect it a tank ran over it then it would be a plane Mito.
Oh well, it got past the spell checker. Anna will kill me for it though.
The last post was made 23 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 91.49 Kb
