What's the difference between regular and inverted forks?
5v3d3b0
PostPosted: 13:41 - 25 Mar 2007    Post subject: What's the difference between regular and inverted forks? Reply with quote
I've got inverted ones on the RS 125, just wanted to know whats bettter about them, apart rom looking the shits
pwntifex
PostPosted: 13:45 - 25 Mar 2007    Post subject: Reply with quote
They add at least 10bhp. Wink
5v3d3b0
PostPosted: 13:48 - 25 Mar 2007    Post subject: Reply with quote
And when combined with racing stripes and rim tape can almost match a 98 R1 XD
-Savage-
PostPosted: 14:10 - 25 Mar 2007    Post subject: Reply with quote
not forgetting an after-market powerband FTW
mr.z
PostPosted: 14:21 - 25 Mar 2007    Post subject: Reply with quote
Afaik lower unsprung weight? Given the choice i'd stick with conventional forks simply because they can have gaiters..
In the real world not much difference..
The Tot
PostPosted: 14:23 - 25 Mar 2007    Post subject: Reply with quote
Inverted forks are difficult to fit up your bumhole as the top half of the forks are wider in diamter and are usually gold in colour and often ribbed. It's a girthy, ribbed piece of tubing and you may want to call it Bubbah!
RWU forks are a smooth chromed surface and can slide up and down your bumhole easier. All you need to do is just remove the yokes in either case. You can do without the lube cos of the frictionless surface. And it's rate cold!
It's got something to do with the stanchions carrying a lighter mass blah de blah and making it easier to turn. I personally think it has more relevance to how easy it is to slide the forks up and down your bumhole Razz
Never argue with autism
PostPosted: 14:26 - 25 Mar 2007    Post subject: Reply with quote
USD forks are stiffer, and when compressed the point where there is the greatest stress (just under the bottom yoke) has the strength of both the inner and the outer.
There are also claims that an USD fork has less unsprung weight, but not so sure on that.
colin1
Captain Safety
PostPosted: 18:47 - 25 Mar 2007    Post subject: Reply with quote
with working suspension, the wheel and the bottom half of the suspension go up and down a lot in time with the bumps in the road.
if the wheel and the bottom half of the suspension (the bit that moves) are light, its easier for the suspension to hold the wheel to the road and insulate the bike from the bumps, giving better road holding
this is the unsprung weight thing people are referring to, for those that arent up on the lingo
You can still get Up Side Down suspension that is worse than right way up suspension, but thats down to the components, as the USD configuration is inheritantly better
also as the join is lower, down the forks may be less likely to flex, which may or may not be significant
PostPosted: 18:58 - 25 Mar 2007    Post subject: Reply with quote
How can USD forks have lower unsprung weight when the steel fork tube is unsprung yet it is sprung on conventional forks.
Conventional forks are still highly capable BTW they only switched the GSXR600 to USD in 2003/4.
Itchy
PostPosted: 13:29 - 26 Mar 2007    Post subject: Reply with quote
When you bust the fork seals on RWUF , you go ohhhh shit, but can see it happen and bag them up , most of the time since even with faired bikes you can see down the yokes.
when you bust fork seals on USD forks you can't see it and attempt to brake going hot into a corner and think SHIIITITTTT,
which means that USD need more preventitive maintenance.
Mr.Everready
PostPosted: 13:55 - 26 Mar 2007    Post subject: Reply with quote
You da man colin. Thumbs Up Wink
Kal
PostPosted: 15:14 - 26 Mar 2007    Post subject: Reply with quote
USD look prettier...
Kal...
The last post was made 19 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 75.5 Kb
