The dangers of running a twin on 1 cylinder?
M1ke
Ped Boi
PostPosted: 14:07 - 27 Mar 2007    Post subject: The dangers of running a twin on 1 cylinder? Reply with quote
i've had a few problems with my motorcycle over the past couple of weeks. Basically when its wet it drops onto 1 cylinder (it is a 500cc twin)
What I would like to know is, what damage would running the bike on 1 cylinder do? It can still do 60mph, has sod all throttle response however it still gets me to work down the M6 quicker than my car can in rush hour traffic.
The commute is 80 miles per day... Will she blow?
PostPosted: 14:10 - 27 Mar 2007    Post subject: Re: The dangers of running a twin on 1 cylinder? Reply with quote
M1ke wrote:
i've had a few problems with my motorcycle over the past couple of weeks. Basically when its warm it drops onto 1 cylinder (it is a 500cc twin)
G ran a whole race with his SV on one cylinder... but he did have it rebuilt not long after...
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
veeeffarr
PostPosted: 14:22 - 27 Mar 2007    Post subject: Reply with quote
Which 500 twin?
Checked plugs, coils?
M1ke
Ped Boi
PostPosted: 14:25 - 27 Mar 2007    Post subject: Reply with quote
Its a VT500, I've changed the ht's and coils and its not them.
PostPosted: 14:57 - 27 Mar 2007    Post subject: Reply with quote
I presume you've tried David Silvers? They do a whole stator and rotor assemby for £95.
https://www.davidsilverspares.co.uk/
Andyco11
PostPosted: 18:40 - 27 Mar 2007    Post subject: Reply with quote
You probably have tried here https://www.dkmotorcycles.co.uk/dkonline/used_spares/ already but if you havent give them ago as thay usually have some odd stuff in there [/url]
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
Odie
PostPosted: 18:52 - 27 Mar 2007    Post subject: Reply with quote
The problem running a twin or any multi cylinder motorcycle that is not running on all cylinders is that the un-burnt fuel will travel down the cylinder bores and remove the film of oil covering the bores lubricating the piston thus causing a partial seizure due to friction. Or it could travel further, past the piston/s and drain into the oil thus rendering its lubrication propertys to that of piss!
Not wanting to put to much of a dampener on things " DONT DO IT, IT WILL BUGGER YOUR ENGINE!"
Ichy
PostPosted: 05:27 - 28 Mar 2007    Post subject: Reply with quote
Have you looked at the other vt's? I know Honda used the same pick-up on the 600 for as long as the model ran, I'm just not sure that they used the same pick-up on the 500 or 750.
The key is that its OK until it gets warm. What makes you certain its the pick-ups? Have you checked the connector and wires to make sure there aren't any breaks?
Item no.290098020485 on ebay, ask him if he has the pick-ups, he might split them out for £10?
yambabe
PostPosted: 22:26 - 28 Mar 2007    Post subject: Reply with quote
Before you give up and ebay it John is suggesting that it could be the ECUs causing it as the VT has two.
He says swap them over and see if the problem swaps to the other cylinder. If it does, picking up a new ECU and replacing it should be a cheap and easy option to get it running properly again.
PostPosted: 15:44 - 29 Mar 2007    Post subject: Reply with quote
Bore wash would be an issue but not over the very short term I think because 1, there is no load on the piston walls since it's not firing so no need for such heavy lubrication and 2. much of the effort of drawing in fuel/air under load is produced by cylinder scavanging after the mixture has fired.
It is still a problem but would probably not have caused much if any damage in a "get you home" situation.
Odie
PostPosted: 23:26 - 30 Mar 2007    Post subject: Reply with quote
Depends how far away home is! Mr. Green
The last post was made 18 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 80.28 Kb
