| Kel |
 Kel Borekit Bruiser
| Trixie |
 Trixie World Chat Champion
| Kel |
 Kel Borekit Bruiser
 Posted: 12:06 - 16 Mar 2007 Post subject: After braking revs won't increase |
No offence taken.
I've been riding since October last year, and this problem has only recently started happening.
Perhaps that wasn't the best example to give, and you are right, I was in 3rd, not fourth (I'm at work, trying to be post quickly). The point I was trying to make is that braking, going down the gears, and then trying to come back up seems to be the problem. |
| hazza |
 hazza World Chat Champion
| Odie |
 Odie World Chat Champion
| finpos |
 finpos World Chat Champion
| Kel |
 Kel Borekit Bruiser
| iooi |
 iooi Super Spammer
 Posted: 14:41 - 19 Mar 2007 Post subject: |
Simplist way to find out if it is the brakes binding is next time it does not want to rev, pull over without braking anymore, bike onto center stand and try to spin wheels by hand. If you struggle then you have the answer, if they are pretty free then it thinking caps on again.
Having said that a even easier answer is when it does it, clutch in.... Throttle wide open..... What happens ???
Just do not dump the clutch if it does rev like mad... I would not like to see you on your backside on the road...  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Odie |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 17:25 - 19 Mar 2007 Post subject: Re: After braking revs won't increase |
Best way to check which caliper is dragging is to put your hand near (not on) each caliper and see which one gives off the most heat. It may however, be adviseable not to ride the bike if the brakes are binding like that, as it could lock up and throw you arseways  ____________________ TL1000s, KDX200 |
| Odie |
| Kel |
 Kel Borekit Bruiser
| Odie |
 Posted: 17:17 - 20 Mar 2007 Post subject: Re: After braking revs won't increase |
| Kel |
 Kel Borekit Bruiser
 Posted: 10:03 - 21 Mar 2007 Post subject: After braking revs won't increase |
Thats the main problem - I can't get a manual for it!!
If you should know anyone that has a manual for a Jialing JH125G I'd be most interested  |
| Odie |
| binge |
 binge Emo Kiddy
 Posted: 18:41 - 21 Mar 2007 Post subject: |
Does sound like the brakes sticking.
Id put bets on it been the rear brake too, I had none stop trouble with my rear drum brake on my Speed fight a few years back, ended up chucking a disk setup on the rear instead, Solved the problem.
I'm guessing its cable rear brake too,Not hydraulic, it probably just wants freeing up and lubing.  |
| Kel |
 Kel Borekit Bruiser
| Odie |
| Kel |
 Kel Borekit Bruiser
 Posted: 11:03 - 28 Mar 2007 Post subject: Re: After braking revs won't increase |
The bike is 6 years old. There was a hole on one side and its got a slight mark that looks as if it goes most of the way round, but hasn't actually cracked yet.
I'm not going to attempt to do anything about the manafacturers warranty, the importer for this model no longer imports (maybe went bust) and the new importer for Jialing is no help, just keeps trying to sell me a new bike! Plus, I'm starting to believe what is said about chinese imports, they just aren't built to last.
As long as the bike lasts me until the end of the year I'll be happy enough, just want to get my test done on it.
Will be picking it up later, can't wait!
Cheers again
Kel |
The last post was made 18 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
