| Visitor Q |
 Visitor Q $25 whore
 Posted: 16:49 - 28 Mar 2007 Post subject: Wheel bearings/drifting |
How the fuck...
Are you just meant to wrench the spacer sideways as hard as possible and then hammer like a madman around the breaing edge with a screw driver/long allen key?
Is their any actual skill in it?
And what exactly does a drift look like? As i could probably fashing something just as good.
I also have a spare axle, is that any good for doing it? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:55 - 28 Mar 2007 Post subject: |
Just did the rear.
Piece of piss (ish).
Simply because the spacer was moving more allowing me to welly the cunt.
The front barely gives me a mm. Is there anyway to force the spacer aside? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| stinkwheel |
| snapperslappe... |
 snapperslappe... Scooby Slapper
| stinkwheel |
 Posted: 20:10 - 28 Mar 2007 Post subject: |
They don't usually balance them with the sprocket carrier in place, so no.
Although I can't work out why, it seems to me like you should balance the whole wheel and hub assembly. Maybe someone else knows? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| snapperslappe... |
| snapperslappe... |
 Posted: 21:35 - 28 Mar 2007 Post subject: |
top stuff......cheers matey....
hopefully should make the back end feel a bit more planted in the twisties, and stop that fricking squeaking when wheeling the bike out of the garage....... |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 22:37 - 28 Mar 2007 Post subject: |
Bum, wishing i hadnt read this now... making me think ive hashed it up (and i were so proud earlier).
So how critical is it to balance it when new bearings are put in... ?
How critical is this put them in and take them out business. As when mine were in they were staying in.
And i tapped them in with a smaller socket working a criss-cross pattern round the outer rim.
IE covering inside and outside race at 6 oclock, then 10, then 2. Little taps. Fuck loads of grease.
Ive got to the point now were ive fucked up the old bearings too much to stop. So gonna invest most of my time trying to get the spacer moved abit to increase the lip.
Out of curiousity, how bad are little dents in the spacer? Or having a fuck load of rust on the OUTSIDE (ie in the hub side not axle side) of the spacer. Metal was thick and meaty so just filed it abit and covered in oil. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
 Posted: 11:26 - 29 Mar 2007 Post subject: |
Thanks for the reply mate
I may go and treat myself to a drift, to go with my absolutely huge half inch drive torque wrench i got for 16 quid
Think i may avoid doing engine bolts with that one lol.
So is a drift meant to be the same diameter as the hole in the inner race of the bearing, or slightly smaller? or very much smaller.
Im off to go sit outside, in the rain, and repeatedly club it with something until it moves enough to get a proper purpose.
The annoying thing is (as i found with the rear), once youve got the 'sweet spot' it comes out in about 6 good hits. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| tatters |
 tatters Exxon Valdez
 Posted: 14:48 - 29 Mar 2007 Post subject: |
I use these punchs for removing/fitting bearings+seals.
cheap as cheaps
https://cgi.ebay.co.uk/200mm-8-PIECE-PARALLEL-PIN-PUNCH-SET_W0QQitemZ140099029005QQcategoryZ121893QQrdZ1QQcmdZViewItem ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 15:11 - 29 Mar 2007 Post subject: |
| Hetzer wrote: |
A 'drift' is whatever you're hitting with your hammer to drive out the bearing. I've always used a flat-headed screw-driver, though you can buy a dedicated tool (called a 'drift'  ).
Which bearing are you having trouble removing, the first or the second in the wheel? |
Hmm, well that screws my plan as i was intending to hustle down to the tool shop and buy a drift. Might go anyway and see what they have but so far using the edge of a chisel is about the only thing ive got any luck with.
Its the ruddy spacer in the middle i tells you. And first bearing. Im assuming once you have once side out you get the spacer out and the second is a piece of pish (or it was like that with the rear anyway).
Im quickly running out of jobs i can do until the wheels back on
Just finished stripping, cleaning, greasing and fitting new pads to the two front calipers and cleaning the wheels.
I guess im just lucking for a better solution then 'keep forcing a slight lip by wedging the spacer in a random direction, then spank it with a chisel/screwdriver as hard as possible'.
What about something like this or this - (scroll down about 5 entries, its the one with pics)
Might go down with my bearings and see if i can get a ground anchor. Worth a punt. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
| veeeffarr |
 veeeffarr Super Spammer
The last post was made 18 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
