| veeeffarr |
 veeeffarr Super Spammer
| Jamie S |
 Jamie S World Chat Champion
 Posted: 11:03 - 28 Mar 2007 Post subject: |
thought your engine was out of your bike ?!?  |
| veeeffarr |
| Jamie S |
| DaveH |
 DaveH World Chat Champion
 Posted: 11:32 - 28 Mar 2007 Post subject: Re: GS500 - Starting problems |
| Toby R wrote: | Hi,
Got some basic issues with my 1995 GS500E that are starting to piss me off.
The bike won't start without choke, if I use choke to get it started, and then switch it off the bike has a lot of trouble revving past 2,000rpm, it will make popping noises and the revs keep dipping until it finally manages to rev up, any ideas what this could be? It's not returning to idle at all unless it's been ragged for about 15 miles.
Could this be the carbs out of balance?
Also, my choke cable is sticky and I'm having to manually push the plunger in on the carbs, any ideas on how to free this up?
Cheers,
T | Has it been sitting for any length of time, or has it just started doing this?
You can lube the choke cable, but it may be that its corroded within the sleeve, so might not get it to be that free. ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| veeeffarr |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 12:13 - 28 Mar 2007 Post subject: |
sounds like an air leak some where, if its popping,
thats proply why it runs ok with the choke on,
get the bike running, then spray wd40 at the carbs both before the carb and between it and the engine,
if the revs change at all, you have an air leak
that gs of yours seems to be a bit of a lemon toby
i havn't had any issue with my 95 apart from the starter relay died, ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Itchy |
 Itchy Super Spammer
 Posted: 12:18 - 28 Mar 2007 Post subject: |
thats not a starting problem , I have bigger starting issues, go ask Gmanxii , he had the pleasure of seeing me start it , misfire multiple times then had to be bumped. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| veeeffarr |
 Posted: 12:30 - 28 Mar 2007 Post subject: |
| hmmmnz wrote: | sounds like an air leak some where, if its popping,
i havn't had any issue with my 95 apart from the starter relay died, |
Mainly sorted now matey I just need to sort this damn problem then it will be fine, gonna strip it down now it's daylight for when I get home at 7pm and give it a damn good going over.
T |
| Itchy |
 Itchy Super Spammer
 Posted: 12:40 - 28 Mar 2007 Post subject: |
yes your GS500 is a lemon buy my NTV £400 ! , its got 12Months MOT + 4 months tax on it, I've fixed every part of it it runs its ok ,
looks awful , runs ok ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Compo |
 Compo Nova Slayer
| Compo |
 Compo Nova Slayer
| finpos |
 finpos World Chat Champion
| veeeffarr |
| veeeffarr |
 Posted: 19:28 - 28 Mar 2007 Post subject: |
Got another problem
I have a hose coming from a t piece on my carbs (#58 on here: https://www.ronayers.com/fiche/300_0027/carburetor/carburetor.jpg) but it doesn't seem to connect to anything? It's on a pipe that links both carbs together as you can see, The pipe rotates... So I'm not sure if it's a breather or not? There was a spare clip on one of my air filter securing screws so I've clipped it in there for now... |
| JonB |
 JonB Afraid of Mileage
| veeeffarr |
| veeeffarr |
| Dalemac |
 Dalemac World Chat Champion
| DaveH |
| veeeffarr |
| DaveH |
 Posted: 21:33 - 28 Mar 2007 Post subject: |
Did putting the choke on during the run make any difference?
Checked the link, didn't seem to work, so not sure about the carb pipe. ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| JonB |
 Posted: 21:39 - 28 Mar 2007 Post subject: |
OK. Toby buy a new bike.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| veeeffarr |
 Posted: 21:40 - 28 Mar 2007 Post subject: |
It's not the hose anyway, just found a diagram. Choke did fuck all, no idea what to do now.  |
| DaveH |
 Posted: 21:50 - 28 Mar 2007 Post subject: |
Unless the wire has come off the coil again and its only running on one cylinder...start it and CAREFULLY check the exhaust pipes to see of one is cold, or at least cooler. Just run it for a couple of seconds, if using hands, else try a damp cloth and listen for the hiss agains the hot pipe ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
The last post was made 18 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
