MRI SCAN
Jamie S
PostPosted: 20:58 - 28 Mar 2007    Post subject: MRI SCAN Reply with quote
Hi, today I went to see prof Digby Tantan in sheffield, now he has requested that I go for a MRI scan manly to look at the left side of my brain. Has any one had one done ? what was it like ? is it dangerous , radiation ect? might sounds stupid but will it hurt ? its just so I know what to expect, because you go through them tunnel things dont you ? must be scary if you do?
cheers
And no taking the piss here , it is because of my ADHD and asperges , they need to "check" that something is not seriously wrong .
cheers
A scared jay
JonB
Afraid of Mileage
PostPosted: 21:12 - 28 Mar 2007    Post subject: Reply with quote
It's not biggie. Had an MRI for my back.
Basically you lie inside a big machine for about 15 minutes, the hospital I was at laid on some headphones to pass the time.
The only downside about the MRI was the fact I got quite claustrophobic, being completely surrounded by a wall like feature. However after 5 minutes I fell asleep anyway.
Doesn't hurt at all, there isn;t even anything to be felt.
Paivi
PostPosted: 21:23 - 28 Mar 2007    Post subject: Reply with quote
I've had a brain scan which lasted for appx 20min. You're strapped on a board, in a neck brace and pushed into the machine. You won't be able to move at all. It's a very tight fit and dimly lit. Very strange humming sound and the constant clicking when the shots are taken is quite annoying and prevented any sleep. There's no pain or feeling, as it's effectively just taking a series of x-rays of your brain.
You'll get a panic button to press if you start feeling claustrophobic or sick. I felt very uncomfortable and couldn't wait for it to be over. It's very common to start feeling sick, so they'll wheel you out for a few minutes' rest before continuing. If you think you're going to be sick, press that button immediately, as you cannot move your head. I was advised not to eat for 12h before and only have small amounts of water in that time, too.
I'm assuming there's radiation or some such thing, as the staff are in another room, but they're in frequent communication with you to check how you're doing.
Jull
PostPosted: 21:49 - 28 Mar 2007    Post subject: Reply with quote
I had a MRI brain scan too, what Paivi said Thumbs Up but I took a cd with me and they played it through the speakers into the room, couldn't hear it very clearly but it did take the edge off the scan noises and it was useful to count the tracks to judge how long I'd been stuck in there.
If you think it may freak you out being strapped in, they may give you a sedative beforehand but only if it won't affect the part of the brain that they're scanning.
After having one it wouldn't worry me if I had to go and have another - nowt to worry about, you'll be fine!
Lone-Wolf
PostPosted: 22:03 - 28 Mar 2007    Post subject: Reply with quote
Wotcha.
Radiation is the least of your worries - it doesn't use it. . . at least I don't think it does Confused
Magnetism is your friend.
MRI = Magnetic Resonance Imaging
Cheers.
L.W. - www.moonshiners.org.uk
Blackrhythms
PostPosted: 22:56 - 28 Mar 2007    Post subject: Reply with quote
Yeah I had one on my brain and back - as the others have said, it's not painful at all. I was wary I'd get claustrophobic but actually found it ok when I was in the machine. The music does help - the only thing I didn't like was the bangs and clicks out of the machine cos they were quite loud and stopped me falling asleep! Laughing
Don't worry, the staff are really helpful and talk you through any worries you may have! Good luck! Thumbs Up
Cool
Jamie S
PostPosted: 23:05 - 28 Mar 2007    Post subject: Reply with quote
cheers guys that's reassuring,so it seems the only problem ill have is being slightly claustrophobic then.
thanks for the help Karma
ZRX61
Victor Meldrew
PostPosted: 02:57 - 29 Mar 2007    Post subject: Reply with quote
I've had a few, I usually doze off within about 2 minutes of em starting.
msgander
PostPosted: 10:21 - 29 Mar 2007    Post subject: Reply with quote
doesnt hurt, you usually have mirror to look at which projects outside the tunnel, I fell asleep! quite noisy, no radiation.....chill.
Always believe that your guardian angel flies a bit faster than you...............
TheShaggyDA
Repost Police
PostPosted: 12:26 - 29 Mar 2007    Post subject: Reply with quote
It's a tight fit, and you don't want to do it with any metal in your head.
pwntifex
PostPosted: 12:41 - 29 Mar 2007    Post subject: Reply with quote
You will have at least a 2hr wait.
PostPosted: 12:52 - 29 Mar 2007    Post subject: Reply with quote
Scans are boring, you lie down, what you're lying on moves into the scanner machine which then proceeds to make lots of various noises as it's taking pictures. Boring, you can't really move, the way the staff tell you that it's safe and then they go and sit in a separate room is reassuring, did I mention it's boring?
They don't hurt at all, it's CAT scans that involve radiation, I wouldn't say they're scary at all just boring. Thumbs Up
JonB
Afraid of Mileage
PostPosted: 13:48 - 29 Mar 2007    Post subject: Reply with quote
If you are unlucky. I waited 10 minutes.
Whosthedaddy
PostPosted: 16:45 - 29 Mar 2007    Post subject: Reply with quote
Lone-Wolf wrote:
Wotcha.
Only if they use contrast dye, some tests are better with radioactive contrast some aren't.
-Savage-
PostPosted: 16:52 - 29 Mar 2007    Post subject: Reply with quote
Whosthedaddy wrote:
Lone-Wolf wrote:
Wotcha.
your thinking of CAT scanning i think, MRI, or NMRI is nuclear magnetic resonance imaging. it works by energising proton spins in atoms using radio waves, then as they relax, they generate a magnetic field, which interfears with the 2 telsa field you iare loc ated in, and gives a reading of each atom.
no radiation, no harmfull effects apart form risks of having metal in your body.
ncrn
PostPosted: 17:02 - 29 Mar 2007    Post subject: Reply with quote
Don't they have to sit in another room because long periods of exposure, ie every day all day, can cause damage to the body?
Whosthedaddy
PostPosted: 17:13 - 29 Mar 2007    Post subject: Reply with quote
This is filmed from the operators room
https://www.youtube.com/watch?v=WsFfpzK-JgU
I have only seen MRI scans go head first, but for an MRI leg, it would seem pointless to go head first Laughing
Its unlikley that they will use contras in this instancet, but some MRI scans will be performed with dye.
plugger147
PostPosted: 21:26 - 29 Mar 2007    Post subject: Reply with quote
It's pretty harmless I spent an hour in one in january, about 20 minutes in they came in and stuck a needle in my arm. doesn't hurt one bit. I would have gone to sleep but it was a bit to noisy.
Going in again in july for another, then proberly every six months to a year for more scans.
Don't worry about it at all, after it's done you'll wonder why you where bothered in the first place.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Pte1643
PostPosted: 22:54 - 29 Mar 2007    Post subject: Reply with quote
I've never had one, so can't comment, really.
But surely if you just closed your eyes it should take your mind off the claustrophobia. Thumbs Up
TheShaggyDA
Repost Police
PostPosted: 11:03 - 30 Mar 2007    Post subject: Reply with quote
Claustrophobics around the world have now built a statue of you, and kneel before it every day.
nrml76
PostPosted: 19:35 - 30 Mar 2007    Post subject: Reply with quote
As mentioned before, the main problems most people have is claustrophobia and noise (you will be given a piar of ear defenders to wear). Contrast agents are usually used in specific circumstances like MR-angiography etc; not as widely as in CT scans. Ferrous metal implants in your body is a contraindication for MR scans. If you have had bones fixed in the past, get in touch with the surgeon who did it now itself, and find out if they were ferrous metal or titanium. It will save a last minute cancellation on the day. Oh, dont forget to remove all piercings (especially those in sensitive places), if you have any.
Everyone who lives dies, yet not everyone who dies has lived. We take these risks not to escape life, but to prevent life from escaping us.
beatnck
PostPosted: 19:42 - 30 Mar 2007    Post subject: Reply with quote
i had one a couple of years ago after i got knocked out (accidently, by my best mate! Rolling Eyes )
i lost all my memory for two weeks, couldnt remember a thing, not even my name Shocked
i cant actually remember the scan, but according to my girlfriend i just laid back and chilled out, no problem.
im sure you'll be fine mate Thumbs Up
no silly comment here!!
Giffer2
PostPosted: 20:24 - 30 Mar 2007    Post subject: Reply with quote
Hurt like hell for me, everytime it kicked in (The loud bangs at the start of a cycle) my fingers felt like they were being ripped apart, I was in mine for 40 minutes.
I didn't care about the closeness/confied space, but I was shaking for about 2 days after the scan which the doctors said was very strange (They even said I shouldn't have had any pain in the my fingers).
plugger147
PostPosted: 21:14 - 30 Mar 2007    Post subject: Reply with quote
Your a weirdo. Laughing
Oh the only thing that bothered me was when it was operating the textured ceiling vibrated and the moving speckles made me dizzy.
Put it out of your head for now mate your proberly going to have a few months before you get an appointment.
Pte1643
PostPosted: 21:58 - 30 Mar 2007    Post subject: Reply with quote
What did I say? Confused
I thought it was a reasonable comment.
Hmmmm...
The statue sounds good though. Mr. Green
The last post was made 19 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 135.17 Kb
