College maths.....lame
killa
Won't Shut Up
PostPosted: 09:28 - 29 Mar 2007    Post subject: [HELP!] College maths.....lame Reply with quote
I don't have notes for some of my assignment (they havent even covered it) and i'm stuck.
Question:- The ball of a float valve is a sphere of 200mm diameter. If the ball is immersed to a depth of 150mm, calculate
[i] It’s wetted surface area
[ii] The volume of liquid displaced in liqud
I need the working as well. Embarassed
Thanks! Thumbs Up
bob-a-job
PostPosted: 10:32 - 29 Mar 2007    Post subject: Reply with quote
I assume it means the most bottom point is at 150 mm... not the centre point?
killa
Won't Shut Up
PostPosted: 10:42 - 29 Mar 2007    Post subject: Reply with quote
I assumed it meant submerged to a depth of 150mm. Confused
bob-a-job
PostPosted: 10:46 - 29 Mar 2007    Post subject: Reply with quote
Well if it is totally submerged the calulations are easy (assuming there is no compression) or if it is not completely submerged the calcualtion is slightly (alot) harder as you have to remove part of the sphere...
bob-a-job
PostPosted: 10:48 - 29 Mar 2007    Post subject: Reply with quote
If fully submerged:
area = 4 * pi * r^2
area = 4 * pi * 100^2
= 125663.68 mm^2
= 0.126 Metres^2 (3sf)
bob-a-job
PostPosted: 10:55 - 29 Mar 2007    Post subject: Reply with quote
If fully submerged:
vol of liquid displaced = volume of sphere
= (4/3) * pi * r^3
= 1.3333333 * pi * 100^3
= 4188789.3 (.3 is recurring) mm^3
= 4188.8 ML (1dp)
or
= 4.2 Litres (1dp)
bob-a-job
I think!!!
shorty
PostPosted: 11:02 - 29 Mar 2007    Post subject: Reply with quote
ermmm before you follow bob-a-jobs advice too far as far as I'm aware this is a fairly straightforward calculus exercise you may find that this site offers some help.
And the volume of water displaced is equal to the volume of the submerged part of the sphere which will be another integration.
Worth bearing in mind that you will certainly get marks for mentioning this along with the standard surface area and volume formulae.
There are plenty of examples on the web for doing these type of calculations.
Shorty
Triumph Daytona 675 Triple
Triumph Tiger Sport 1050
bob-a-job
PostPosted: 11:06 - 29 Mar 2007    Post subject: Reply with quote
Here is a diagram trying to explain my first post above...
bob-a-job
PostPosted: 11:11 - 29 Mar 2007    Post subject: Reply with quote
I found all my stuff here:
SPHERE
- https://en.wikipedia.org/wiki/Sphere
DOME (used to removed unsubmerged part)
- https://en.wikipedia.org/wiki/Dome_%28mathematics%29
Assuming that the sphere gets fully submerged (i believe the calcs above are right), however that does seem a bit simple for college so my gues is that you will have to calc the detaisl assuming it is not fully submerged.. so as shorty says, you will have to use integration to help you calulate the non submerged part.....
killa
Won't Shut Up
PostPosted: 11:13 - 29 Mar 2007    Post subject: Reply with quote
Ok, thanks…..I think.
I do think it means the ball is only 150mm in the water.
* = X, right?
Wish I had some notes on this, even with the figures I’m a bit lost.
Karma for you when I get some to give. Wink
bob-a-job
PostPosted: 11:16 - 29 Mar 2007    Post subject: Reply with quote
* = X, right?
yeh, i think you will have to do some annoying integration... and yes, * equals multiply
shorty
PostPosted: 11:17 - 29 Mar 2007    Post subject: Reply with quote
I would suggest that you do it twice (as once you have done it once it will be dead easier doing it again -
1) Sphere completely submerged so that the top is 150mm below the surface (v. easy as is just spherical volume and total surface)
2) Sphere submerged so that bottom is 150mm below the surface.
shorty
PostPosted: 12:05 - 29 Mar 2007    Post subject: Reply with quote
How's this....
The integral for the surface area of a sphere looks like this:
b
A = 2*Pi*R | dx = 2*Pi*R(b - a)
a
In your case R is 100 and you want to start at 100-150mm, so a = -50
and b = 100. In the normal case of a whole sphere, a = -R and b = R.
So:
b
A = 2*Pi*R | dx = 2*Pi*R(b - a) = 2*Pi*100(100+50)
a
= 47123.89mm^2 (2 d.p)
to check total area (as bob said) is 125663.68 mm^2
Taken from here: https://mathforum.org/library/drmath/view/52133.html
Just the volume to do then.
Shorty
Mal
PostPosted: 12:57 - 29 Mar 2007    Post subject: Reply with quote
Vol of a sphere = (4/3)*pi*r^3
= (4/3)*3.142*100*100*100
= 4189333 mm^3
Vol of a dome = pi*r*h^2 - (1/2)*pi*h^3
= 3.142*100*50*50 - 0.5*3.142*50*50*50
= 785500 - 196375
= 589125 mm^3
Vol of water displaced = vol of sphere below water
= vol of sphere - vol of dome
= 4189333.3 - 589125
= 3600208.3 mm^3
Surface area of a sphere = 4*pi*r^2
= 4*3.142*100*100
= 125680 mm^2
Surface area of a dome = 2*pi*r*h
= 2*3.142*100*50
= 31420 mm^2
Wetted area = area of sphere - area of dome above water
= 125680 - 31420
= 94260 mm^2
Hope this helps.
Mal
shorty
PostPosted: 13:20 - 29 Mar 2007    Post subject: Reply with quote
Mal - am I missing something with the radius of the dome or are you just assuming that it is the same as that of the sphere? It isn't - that would only be the case if the sphere was submerged 100mm. The radius of the dome is unknown.
The point of this exercise, I am sure, is to use calculus - otherwise it is very simple arithmetic.
Shorty
Annabella
Like a person, only smaller
PostPosted: 13:54 - 29 Mar 2007    Post subject: Reply with quote
I must admit I read it as a calculus problem, but am too rusty to actually work it out properly!
Like shorty said, the radius of the dome is unknown...
Avast! Pirates ahoy!
I did Cadwell! Very Happy
killa
Won't Shut Up
PostPosted: 14:36 - 29 Mar 2007    Post subject: Reply with quote
Now im confused Confused
shorty
PostPosted: 14:46 - 29 Mar 2007    Post subject: Reply with quote
OK Killa, I shall try my best to dis-confuse you. Bear in mind it's 10 odd years since i've done this so bear with me...
What Mal has said is entirely correct as far as the logic and workings go apart from the fact that the radius of the "dome" (i.e. the part of the sphere above the water) is unknown.
You can work out the radius of the dome as it changes depending on how far up the sphere you go. That means at the "equator" of the sphere the radius of the dome is equal to the radius of the sphere.
What you need to do is work out the radius of the dome using calculus (integration isn't it guys?).
My example uses calculus to work out the area of the sphere - what you could do is just work out the radius of the bottom of the dome and plug that into Mal's equations to give you the answers.
Hope that's a bit clearer.
Incidentally you will almost certainly get marks for mentioning all of the above as it shows that you understand in principle what you need to do.
HTH
Shorty
killa
Won't Shut Up
PostPosted: 14:50 - 29 Mar 2007    Post subject: Reply with quote
I gotcha Thumbs Up
Thanks
Mal
PostPosted: 18:45 - 29 Mar 2007    Post subject: Reply with quote
It is actually known, the radius of the dome is the radius of curvature which is the same as the sphere that it forms part of, so the radius would be the same if it was 5mm or 50mm tall.
Mal
(Sorry if I didn't make this clear in my original post. Rolling Eyes )
instigator
PostPosted: 19:01 - 29 Mar 2007    Post subject: Reply with quote
what course you doing at college and where killa?
syl
PostPosted: 19:50 - 29 Mar 2007    Post subject: Re: [HELP!] College maths.....lame Reply with quote
Thanks! Thumbs Up
OK - caveat haven't done any proper maths in the last 18 years!
200mm diameter (100 radius)
150mm submerged
Surface area of sphere = 4 pi r^2
= 125663.71
Volume of sphere = 4/3 pi r^3
= 4188790
The height of the dome = 200 - 50 = 50mm
The radius of the circle = sqrt (radius^2) - (height above centre^2)
(think pythagorus triangles)
= sqrt ((100^2)-(50^2))
= 86.60
Radius of curvature of dome = (height ^2 + (diameter/2)^2) / (2 x height)
= (50 ^2 + (86.6/2)^2 / (2 x 50)
= 2500 + 1874.89 / 100
= 43.75
Surface area of exposed dome ceiling = 2 pi Rc height
= 2 x pi x 43.75 x 50
= 13744.47
Volume of dome = pi Rc height ^2 – 1/3 pi height^3
= pi x 43.75 x 50^2 – 1/3 x pi x 50^3
= 212712
Take the dome from the sphere and you get:
Area submerged = 111919.24
Volume submerged = 3976078
Edit 1: PS - I don't have a decent calculator anymore, so I did it with the windows one. I haven't checked it and it may be that it doesn't process things in the correct order (eg multiply before subtracting etc) and I've rounded off at 2 significant digits throughout. I'd repeat the calculations with a proper calculator before you used any of my stuff.
Edit 2: I just noticed I used the radius rather than the diameter in a calculation, so it definately needs to be recalculated and I don't have the time! Smile
Current bike: Kawasaki Z750S
syl
PostPosted: 19:55 - 29 Mar 2007    Post subject: Reply with quote
Mal
No it's not. You need to work out the radius of the circle that is created as the base of the dome.
If you think of a 3D sphere and cut across the top of it with a bit of paper, you create a dome , the base of which has a specific radius. This can be worked out by creating a triangle, with points at
A = centre of the sphere
B = edge of the sphere at a point where the paper cuts it
C = centre of the circle (base of the dome)
AB = the radius of the sphere (100mm)
AC = the radius of the sphere - the height above the water (50mm)
BC = the radius of curvature of the dome
You can work BC out easily with pythagorus formula as the triangle created is a right angle at C
The last post was made 19 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 131.33 Kb
