VFR400 cant get neutral when hot
rpg
PostPosted: 16:54 - 29 Mar 2007    Post subject: VFR400 cant get neutral when hot Reply with quote
hi all, a friend of mine cannot get neutral when the engine is hot. Any ideas as to the problem? Bike is VFR400 NC30
many thanks in anticipation. Smile
mr.z
PostPosted: 17:34 - 29 Mar 2007    Post subject: Reply with quote
sounds weird.. i'd suggest an oil change and see if that helps (i take tricky changes as an indication that the oil need a changeing)
moto_psycho
PostPosted: 18:45 - 29 Mar 2007    Post subject: Reply with quote
clutch is dragging, check for correct oil grade, perhaps replace clutch plates and ensure correctly torqued
or!
is the cable adjusted properly?
meant to be restricted... aint Twisted Evil
rpg
PostPosted: 19:09 - 29 Mar 2007    Post subject: Reply with quote
Thanks all Smile I was thinking along the lines of the clutch needing replacing also Smile Will investigate further and let you know.
Many thanks for the replies Wink
The last post was made 18 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 38.7 Kb
