YBR Oil Change
Adam.I
PostPosted: 12:56 - 30 Mar 2007    Post subject: YBR Oil Change Reply with quote
Hello. It's my day off and I think it's about time that I did some maintainance to the bike. One of the things that needs doing is the engine oil. Was last done 2,000 miles ago and now is about time to change it. I want to do this myself, not just to save money, but wanna get dirty with the bike and do things like this myself more often. I would normally refer to the owners manual for this but I have turned the house upside down and cannot find it anywhere! So, what I'm after is just a rough guide what it is that I need to be doing. I have searched BCF and Google to no avail, even looked in the videos section. Also, if you could recommend me a good oil and chain lube, that would be grand. The lube I have is a bit crap.
Veni Vidi Vici
Matt06
PostPosted: 13:39 - 30 Mar 2007    Post subject: Reply with quote
I use Silkolene 10 40 Semi Synthetic for my YBR. Its the same stuff they use in the Yamaha warrenty service thing so I recommend it Thumbs Up.
For my chain on my YBR I use some Castrol Spray Chain Wax. Works quite well and does the job.
To change the oil you need to drain you're current oil. Down on the engine near the gear lever there is a bolt/screw that when you undo it will drain the oil. Use a tray or something to collect the old oil and once that is done do the bolt back up and put you're new oil in.
https://img163.imageshack.us/img163/4381/3003071444oq1.jpg
Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
Stiffler
PostPosted: 14:01 - 30 Mar 2007    Post subject: Reply with quote
Just to add to that. Drain the oil after you've warmed the bike up, this makes the oil less viscous and so it drains more easily. Also open the dipstick cover to allow air to enter.
Once all the oil has drained return the drain bolt and then add 1 litre of oil into the hole for the dipstick. The amount of oil you require is also printed on the engine casing there for future reference (although 1 litre is pretty easy to remember)
Good luck
Tim
Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS
Adam.I
PostPosted: 14:05 - 30 Mar 2007    Post subject: Reply with quote
Thanks for the help guys. Just been and bought some stuff now. Matt06, I tried the Castrol Spray Chain Wax but I didn't really rate it to be honest, but thanks again.
Veni Vidi Vici
Stiffler
PostPosted: 14:19 - 30 Mar 2007    Post subject: Reply with quote
I used gear oil for my YBR. It kept the chain beautifully clean but it needed regular applications. I used to do it 2x a week or more regularlly after being out in the wet.
Quick wipe of the chain by holding an old towel around the chain as I spun the back wheel with my right arm. then drisel the oil over the links as I spun the chain. Then run the chain through the towel again. If it was really dirty I'd repeat the oiling as the first application would loosen the grime. Took about 2 mins at most and the man at my local dealer even commented on how good knick it was in Cool Remember it is best practice to lube the chain after a ride when it is warm... Having said that the YBR chain doesn't really get that warm!
Tim
Adam.I
PostPosted: 14:31 - 30 Mar 2007    Post subject: Reply with quote
All done and dusted. That was pretty easy. Thanks again guys. What to do with the old oil though? Do the council take it of my hands?
Veni Vidi Vici
Adam.I
PostPosted: 16:02 - 30 Mar 2007    Post subject: Reply with quote
Managed to find my nearest place where I can dispose of the old oil.
Veni Vidi Vici
The last post was made 18 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 55.24 Kb
