Yamaha R1 1998
 Topic moved: from Forum Feedback & Help to The Workshop by EuropeanNC30Rider (30 Mar 2007 - 17:41)
Mad Mick
PostPosted: 17:36 - 30 Mar 2007    Post subject: Yamaha R1 1998 Reply with quote
Can anyone help solve a problem on a 1998 mint R1 - 8000 original miles, no modifications.
There is a hole in the left hand side of the cylinder head just under the frame spar where the engine bolts to the frame.
When the engine is running oil leaks out of the hole.
I have changed the oil pressure release valve and the oil strainer.
Wondering why the hole is even there and what its for and how to stop the oil leaking ??
Let me know if any answers
Mad Mick
plugger147
PostPosted: 22:38 - 30 Mar 2007    Post subject: Reply with quote
This can't be true it's a 98 R1, not only are they unbreakable but they self repair too. Laughing
sorry to be an annoying twat but it's a standing joke
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Jamie S
PostPosted: 22:47 - 30 Mar 2007    Post subject: Reply with quote
i dont get why this guy has such bad karma ? he has only had one post and no bad ratings ?hum ....?
plugger147
PostPosted: 22:54 - 30 Mar 2007    Post subject: Reply with quote
Perhaps it was because he had his post moved. Confused
beans
PostPosted: 22:56 - 30 Mar 2007    Post subject: Reply with quote
This might be a drain hole for the spark plugs, so that if the plug recess fills with water it can run off out of this hole. The oil may be coming from a worn camcover gasket or a loose sparkplug causing oil to leak into the recess and drain out of the hole.
Id say check the cam cover gasket and the cam cover is tight then check all the plugs are in tight too.
Yamaha FS1E- Suzuki RG 125 - Honda CB-1- Ducati Monster - Kawasaki ZX6-R F1- Kawasaki ZX6-R G1- 2003 Yamaha R6
Jamie S
could be , well i have learnt a lesson, to allways post in the right section as it has huge affects on your karma by the looks of it Confused
JonB
Afraid of Mileage
PostPosted: 23:33 - 30 Mar 2007    Post subject: Reply with quote
The sheer power produced from a 98 R1, was obviously enough to destroy steel.
bish777
PostPosted: 01:57 - 31 Mar 2007    Post subject: Reply with quote
well that area would be alloy rather than steel.....
GSXR1100J
st3v3
PostPosted: 11:57 - 31 Mar 2007    Post subject: Reply with quote
Serious answer, ask your local garage of their opinion, or it could be that a '98 R! has finally let the side down Wink causing rumours of it being anything but indestructible..
andyr1rider
PostPosted: 15:00 - 31 Mar 2007    Post subject: Reply with quote
the hole you are referring to is probably the oil pressure check bolt, it's on the left hand side of the casing,if you are sat on the bike. there is supposed to be a bolt in there. might of vibrated loose.it's just so you can check that the oil is pressurised ok and is reaching the top block of the engine and your cams ok.you just loosen the bolt a little with the engine running and if oil seeps out the pressures fine.hope this helps.
The last post was made 18 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 16 - Page Size: 63.24 Kb
