electric pump
-Ali-
PostPosted: 19:34 - 01 Apr 2007    Post subject: electric pump Reply with quote
i have a standard pump with plugs into a 12v cig lighter. Would it be possible to take the plug off and replace it with two crocadile clips, so that i can attact it to the battery.
TheShaggyDA
Repost Police
PostPosted: 19:37 - 01 Apr 2007    Post subject: Reply with quote
Yes.
0ddball
Sure, thats what i did as it makes it more versatile. If you find the cig lighter plug has a fuse built into it, it would be wise to add an inline fuse in the +'ve wire when you fit the crocodile clips.
-Ali-
PostPosted: 19:59 - 01 Apr 2007    Post subject: Reply with quote
so i'd want a pair of these? https://www.maplin.co.uk/module.aspx?ITAG=POP&ModuleNo=1059&doy=1m4#popular
Also which wire would i connect positive/negative to? As you have one wire that attaches to the two metail prongs and one which attaches to the metal bit at the end of the plug.
garyd
PostPosted: 20:05 - 01 Apr 2007    Post subject: Reply with quote
the 2 core wiring wont matter ,as long as one is pos the other neg
0ddball
PostPosted: 20:08 - 01 Apr 2007    Post subject: Reply with quote
When you split the plug open, the +'ve wire is the one that is fused.
Finglonga
PostPosted: 21:06 - 01 Apr 2007    Post subject: Reply with quote
Its also the one in the centre of the ciggy plug as not all are fused.
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.19 - MySQL Queries: 13 - Page Size: 50.4 Kb
