| Dan |
 Dan Brolly Dolly
 Posted: 23:54 - 12 May 2002 Post subject: SV 650's |
i was just wondering about these, i know you got one summy, just wanted to kno what the performance was like? and how reliable they are? and have r they on the insurance, i was thinking of one cos i can get a new one for around £3500
cheers  |
| NELLY |
 NELLY Derestricted Danger
 Posted: 00:18 - 13 May 2002 Post subject: |
Hi Dan
i am not summy ,im Nelly but i have a SV650s in yellow you may have seen it on summys mail , the bike is a very good bike .
the insurence is good, the performance is very good , and can be made
better very easerly i have a blue flame race can on my bike .
i have done 125mph on it and it still had guts (how fast do ya wona go )
that was pissing a BMW car off.  |
| Dan |
 Dan Brolly Dolly
| Phil. |
 Phil. World Chat Champion
| Dan |
 Dan Brolly Dolly
| Phil. |
| Dan |
 Dan Brolly Dolly
| Kickstart |
 Kickstart The Oracle
 Posted: 22:26 - 14 May 2002 Post subject: |
| SummY wrote: |
Vtwins have more toruque but inline has more power at higher revs..
Korns bein a V4 has 2 cyclinders oposite each other, best of both worlds. |
Not quite true. Torque is affected by the length of the stroke (ie, the longer the stroke the greater the leaverage on the crank as the piston goes down), and a 2 cylinder engine of the same capacity as a 4 will have a longer stroke and a larger bore.
However, power is torque x rpm, and a longer stroke engine cannot rev as high so is not going to make enough extra torque to compensate for the lower revs to give higher power.
The engine configuration has no effect of the torque characteristics of an engine. It does affect the firing order, which makes it feel different, and it also affects whether the engine needs a balance shaft to feel smooth. A 90 degree V twin is perfectly balanced, when running on a single crank pin. To smooth out different angle V twins you can run 2 crank pins, one for each con rod / cylinder but that means you land up with a wider engine, which looses one advantage of a V twin. You can also run a balance shaft but that will absorb power (but if the lack of vibration means you can lighten the engine alot without it shaking to bits, you may well gain that power back)
All thebest
Keith |
| Phil. |
 Posted: 17:18 - 15 May 2002 Post subject: Twins |
As always super K comes and saves the day from waffel
Cheers keith |
| NELLY |
 Posted: 08:59 - 17 May 2002 Post subject: |
Hi K
I could not have but it better myself,
i just know it is a big throbing bike that kickes ass,  |
The last post was made 23 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
