Brazing troubles
PostPosted: 14:19 - 08 Apr 2007    Post subject: Brazing troubles Reply with quote
The last crash on my 675 snapped off both arms on the front fairing bracket.
It seems to be made of some light alloy; not sure what, but doubt it will weld with my arc welder.
So I decided to try Brazing it. Never done brazing before.
I've got me one of these which claims to be suitable for brazing and a selection of different coated rods from B&Q.
From what I've read I basically need to heat the item up, then pull the heat back a bit and push the rod onto the materials to be joined.
However, so far I've not managed to actually get the rod to melt.
Last night I tried with a couple of one penny pieces and got one to the point it was glowing orange, but the rod still wasn't melting.
Any suggestions?
The torch has a 'swirl pattern', but this means there's not a distinctive traditional flame so that I can place the items at the obviously hottest bit. Seems to work better holding the torch quite close - is this right?
PostPosted: 18:12 - 08 Apr 2007    Post subject: Reply with quote
G,
My understanding of braizing comes from University. When I was there, they explained and demonstrated braizing to me.
Basically, it requires a paste which I think contains copper and tin iirc. They referred it as "Braize" or "Braizing paste".
You put the paste on both surfaces to be braized, then marry the two together. Once this is done, you touch the flame on the paste. The paste then flashes/ignites, and the bond is made. This bond is then stronger than the steel which it connects together.
So, I think you need some braizing paste, if your defenition of braizing matches mine! Smile
PostPosted: 18:15 - 08 Apr 2007    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Brazing
The American Welding Society prefers "Braize Welding" for what you're trying to do G... According to wikipedia anyway! Laughing
Also, Wikipedia says bronze brazing won't work on Aluminium.
PostPosted: 18:52 - 08 Apr 2007    Post subject: Reply with quote
That is indeed what I'm trying to do. I'm pretty sure it's some alloy, not aluminium, though may have some in it of course.
hmmmnz
PostPosted: 19:01 - 08 Apr 2007    Post subject: Reply with quote
i dont think your going to manage to actully braize the alloy, i think your going to have to weld it with some sort of tig welder or get some special welding rods for your arc welder
the humans are dead
I kick arse for the lord
Bezzer
PostPosted: 19:45 - 08 Apr 2007    Post subject: Reply with quote
The only way you'll do it yourself with just a heat torch is with "Lumiweld" or other similar rods made for alloy.
If the bracket is light then it's obviously an aluminium alloy, you don't use pure aluminium, when people talk of Aluminium welding they're really talking about alloy.
Ichy
PostPosted: 20:01 - 08 Apr 2007    Post subject: Reply with quote
You can braze any two metals together, I used to use it a lot to attach aluminium plates to steel bodies. Brazing is basically a sort of glue so it doesn't need any specific rod or flux. Its very similar to soldering except your using brass instead of lead so if you've done any plumbing you already know what to do.
As Marjay said you need some flux but you don't always need to coat the metal, just warm up the rod and dip into the flux.
For what your doing you need a thinnish rod, 1-2mm, you can use bigger but it needs more heat. Arc brazing can be a bit aggressive especially on thin material. A blow torch might be better, the type used for plumbing with an end that gives a very pointed tip, in fact, in some cases you can get away with soldering the bracket.
PostPosted: 20:21 - 08 Apr 2007    Post subject: Reply with quote
I have been using a blow torch (see the link in my first post for what I've been using). I bought rods that were right next to the torches and are made by the same company.
The torch doesn't have a pointed tip to the flame, but claims to be more suited to brazing than the ones that are designed for plumbing thanks to a hotter flame.
The rods are coated, so should I still have to use flux? I did get some flux in case I had to.
I did wonder about sticking the rod into my Arc welder, but in the end decided it was best not to. Could I still use the Arc welder with this alloy? Would it conduct electricity well enough?
Ichy
PostPosted: 21:14 - 08 Apr 2007    Post subject: Reply with quote
Sorry being too lazy to follow the link and read the post properly I assumed you were using a carbon arc setup since you mentioned the welder.
Rolling Eyes
Anyway, there's definitely something not right if the rods not melting on two pennies. The temperature should be up to about 450 degrees which your torch should be capable of although the output of the others on the site in your link are almost a 1000w higher. What material is the rod and can you melt the it by just holding it in the flame? The flux won't have any effect on this since its only there to prevent oxides from forming, stops the molten material from balling up.
I've always used oxyacetylene torches with quite a pointed flame and I've always kept the heat on the part because it draws the filler through the material.
You need to make sure the rods you have brought are ok for the material your bonding. Copper and brass is ok for steel, copper etc but won't work on aluminium, you'll need an aluminium filler rod for that. Any sign of magnesium and you've got more problems.
Think you'll have the same problem with the arc welder unless you get aluminium filler rods.
PostPosted: 21:29 - 08 Apr 2007    Post subject: Reply with quote
I got one of each of the ones they had, which I'm pretty sure were designed to work with this torch, but the two I've tried so far won't even melt in the flame from the torch.
Using my IR thermometer it's shown the surface of something I was heating up to be about 550 degrees when it had cooled down slightly - seemed to have trouble above that.
Screwfix didn't have any torches, so I had to get it from B&Q and this was the only model they did.
PostPosted: 21:31 - 08 Apr 2007    Post subject: Reply with quote
Allen Millyard of V12 Kawasaki Z2600 fame uses lumiweld to join the bandsawed crankcases on his inline five, KH250 based 2-strokes.
Low temperature aluminium solder. Got to be worth a try.
Are they circular in cross section? If so, have you considered drilling them and sweating a slug in?
PostPosted: 21:34 - 08 Apr 2007    Post subject: Reply with quote
They are some fancy ergonomic shape or something Rolling Eyes.
I did consider trying to drill some very fine holes and stick a couple of pins through, but I think better would be just to slap a bigger bit of metal on underneath.
PostPosted: 21:36 - 08 Apr 2007    Post subject: Reply with quote
Bit of flatbar, a vice and a lumphammer? (aka a 'bracket kit').
Ichy
PostPosted: 21:42 - 08 Apr 2007    Post subject: Reply with quote
I've got some two pack adhesive that you can have, use it to refit broken studs and fixings on cars where we can't get a welder in. Its called power mix, made by www.vip-gmbh.com. look under
products,
adhesives,
2 part products,
then scroll down to 2 part Urethan adhesive.
It does mention plastics but the spec sheet also mentions metal. I have the mixing nozzle but not the application gun, I use my fingers to push the plungers down.
PostPosted: 21:56 - 08 Apr 2007    Post subject: Reply with quote
Embarassed Now this is a bit embarrassing Embarassed
I actually tried the aluminium rods I've got and they, err, do seem to work! I had been saving them as I only had two.
Doesn't explain why the others ones don't when I'm sure they 'should'.
Cheers for the offer ichy, got a few other adhesives I can try as well so should be ok one way or another.
Should these aluminium rods be fluxed? They don't seem to have any outer coating from what I can tell.
hmmmnz
PostPosted: 22:05 - 08 Apr 2007    Post subject: Reply with quote
its not really nessasary, the flux just cleans the area up so it bonds easier, but if they are working with out flux then sweet, mabee a quick sand to clean up the area would be enough
the humans are dead
Ichy
PostPosted: 22:06 - 08 Apr 2007    Post subject: Reply with quote
Should have some type of flux to remove oxides and contaminates.
Problem is to braze aluminium you need a flux with alkaline chlorides or fluorides and lithium salts, maybe the one you brought will be ok?
Some rods are flux cored, not flux coated so give them a try, it will be obvious if there isn't any.
Bezzer
PostPosted: 22:08 - 08 Apr 2007    Post subject: Reply with quote
Lumiweld rods and probably yours as well don't have/need a flux, but you need a stainless steel wire brush which you use to agitate the liquid rod into the area you're using it. Don't know why so don't ask Mr. Green but that's how they "work" for some reason.
Bezzer
PostPosted: 22:14 - 08 Apr 2007    Post subject: Reply with quote
Here you go -
Is it as easy to use as watching the demonstrators suggests? if you follow the instructions included with each pack; then the process is quite simply within the grasp of anyone who can master soldering (that word again!); no flux is used, oxides are removed mechanically by agitating with a stainless steel rod (or stainless steel brush, available from the suppliers) through a pool of molten `Lumiweld' on the surface of the workpieces. The `Lumiweld' itself prevents the oxides reforming and a neat run or fillet can be made with the filler rod, which then forms the`Molecular bond'. You can make Lap, Butt or Joint welds and a butane canister type of blow lamp or even a gas cooker will suffice as the heat source. As the bond is only formed with aluminium or zinc alloys it can be effectively used to reclaim stripped threads in such materials by drilling out the offending hole and popping in a bolt of the correct thread form; `Lumiweld' run around the bolt then bonds to the aluminium but not the bolt, which can be unscrewed from the hole leaving a new thread behind it: Again, the low working temperature of the operation makes this an attractive alternative to other forms of repair, where a complete strip down might otherwise have to be contemplated
Ichy
PostPosted: 22:26 - 08 Apr 2007    Post subject: Reply with quote
G, remember aluminium doesn't glow when it gets hot, watch the temperature or the bracket will melt before you know it especially since the melting temp of the filler rod is close to the melting point of aluminium.
Question Brazing works through capillary action, your going to struggle to get a brush between the two pieces of metal Wink
The stainless brush will clean the joint without leaving silicate particles embedded into the aluminium. Wash the freshly scrubbed surface with distilled water and braze as soon as humanly possible after drying the joint.
The problem with welding or brazing aluminium is the aluminium oxide which has a melting temperature of around 3500 degrees F which is a lot higher than the melting point of aluminium alloys. You need to completely remove the oxide before joining otherwise your weld will fail ether during the welding process or shortly after. So you can leave the flux out if you want but it does have a purpose.
PostPosted: 22:51 - 08 Apr 2007    Post subject: Reply with quote
Hmmm, I was hoping to not have to 'clean up' the joint at all as far as abrasion is concerned - the parts still match pretty well where they cracked.
The flux I've got doesn't mention what it has in it, just that it doesn't have lead.
These are the rods I've got (also got two others listed under 'brazing rods' on the left:
https://www.bernzomatic.com/bernzomatic/consumer/jhtml/detail.jhtml?prodId=BernzoProd100064
Cheers for the thoughts all Thumbs Up.
Bendy
Mrs Sensible
PostPosted: 22:58 - 08 Apr 2007    Post subject: Reply with quote
Superglue it and wrap it in gaffa. Thumbs Up
Ichy
AL3 are flux cored. Out of interest how much did they cost?
ZRX61
Victor Meldrew
PostPosted: 23:13 - 08 Apr 2007    Post subject: Reply with quote
mildly entertaining thread... LMFAO! Rolling Eyes
hmmmnz
PostPosted: 01:35 - 09 Apr 2007    Post subject: Reply with quote
lol, yep its a bit of the blind leading the blind Very Happy
gotta love it Thumbs Up
the humans are dead
The last post was made 19 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 132.96 Kb
