Engine Flat Spot
davidimurray
PostPosted: 19:54 - 10 Apr 2007    Post subject: Engine Flat Spot Reply with quote
My bike seems to have developed an interesting 'flat spot' in the revs. If i rdie up to around 5000RPM, hold it steady then open the throttle it just doesn't accelerate. The engine tries to pull, you can hear the exhaust note change, but it just won't go.
Does it in all gears. If I start below 5000 RPM and accelerate through that range it's fine.
I haven't got around to looking at it yet, in the meantime any ideas what it could be? The bike has had a K&N fitted for a few months now but it never used to be like this.
Cheers
Dave
TheShaggyDA
Repost Police
PostPosted: 20:03 - 10 Apr 2007    Post subject: Reply with quote
What bike do you have? How old is it?
Possibly a slipping clutch - my Enfield would happily accelerate (I use the term very loosely) up to top speed in one go, but if I were cruising and then just opened the throttle it would have to be coaxed up. Once the clutch cable settled in it was better, and it disappeared once I put heavier springs in.
davidimurray
PostPosted: 20:37 - 10 Apr 2007    Post subject: Reply with quote
It's a 2002 Kawasaki ER5 - it had a new clutch about 2000 miles ago and the revs don't actually go up when I nail it.
One other thought, i've been using the car a bit for work so it's taken me 4 weeks to get through a tank of fuel - could it be going off?
Cheers
Dave
Diggs
PostPosted: 22:12 - 10 Apr 2007    Post subject: Reply with quote
Check the plugs - old plugs cam cause those symptoms too...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
davidimurray
PostPosted: 22:15 - 10 Apr 2007    Post subject: Reply with quote
The plugs were changed about a month and a half ago at the same time the carbs were balanced.
theguitardoct...
PostPosted: 23:16 - 10 Apr 2007    Post subject: Reply with quote
I had a Kwak that behaved exactly like this, and it was down to a tube that had been "re-connected" during a service...basically a tube got stuck onto the moisture outlet on the airbox and it created a vacuum which stopped it getting above 5000rpm. I took the pipe off after I removed the tank, and lo and behold she revved freely again...check they didn't do this amongst the other problems...
Failing this, try some carb/imjector cleaner type additive and maybe change out the fuel filter as that may be restrictng flow when you nail it.....
The last post was made 19 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 46.52 Kb
