My idea of fun, head bearings and valve clearances.
Gazdaman
I did a trackday!!!
PostPosted: 13:11 - 10 Apr 2007    Post subject: My idea of fun, head bearings and valve clearances. Reply with quote
Well the bandit's on 44k miles. So thought I should check the valve clearances, and give it an oil change etc whilst I'm home with a nice big garage etc.
And the steering was very notchy, as if some wiring was catching on something behind the headlight as I turned the bars.
So I thought I'd check the head bearings aswell. Didn't expect them to be bad, I only replaced them 8k miles ago.
https://www.bristolbikers.com/images/Bandit-temp/IMG_9254%20(Small).JPG
https://www.bristolbikers.com/images/Bandit-temp/IMG_9255%20(Small).JPG
Not only were the bearings bone dry, they were also knackered. Luckily I had a spare laying around, so I replaced it. It handles much better now!!
https://www.bristolbikers.com/images/Bandit-temp/IMG_9261%20(Small).JPG
I was kind of hoping the clearances would be way out so I could fix something. But they were pretty much perfect. The middle two cylinders' exhaust clearances were a touch tight. So I sorted those, but I'm pretty sure they could have been ignored.
Now all it needs is an oil change.
Gaz
Nath
PostPosted: 02:21 - 11 Apr 2007    Post subject: Reply with quote
God bless screw+locknut valve clearance adjustment Thumbs Up
Hard livin', hard luck.
garth
PostPosted: 06:26 - 11 Apr 2007    Post subject: Reply with quote
Christ I miss my bandit.
Screw and locknut with enough room to actually fit your hands in to check and adjust.
You have to be built like a borrower to work on the gsxr Laughing
Gazdaman
I did a trackday!!!
PostPosted: 10:27 - 11 Apr 2007    Post subject: Reply with quote
Yeah I probably wouldn't have attempted it on anything much newer tbh.
Gaz
PostPosted: 11:08 - 11 Apr 2007    Post subject: Reply with quote
Gaz,
As you probably know, when you do head bearings you are supposed to get a handful of grease and using your other hand roll the bearing in the grease.
You kind of press it into the palm of your hand until you can't pick any more up on the rollers and in the shell and thats pretty much the only way I know to grease them properly.
The other way is to warm some grease in an oven and dip the bearing in, but this is quite messy.
If you didn't do either of those things, then they'll need doing again soon! Smile
Gazdaman
I did a trackday!!!
PostPosted: 11:51 - 11 Apr 2007    Post subject: Reply with quote
I just did mucho smearage. On both the inner bit, and the outer bit. And then a load on top for good measure.
It'll do for me.
Gaz
PostPosted: 12:36 - 11 Apr 2007    Post subject: Reply with quote
It'll do for me.
Gaz
You need to get the grease behind the rollers, so its packed in there. Thats probably why they failed so quickly! Wink
Gazdaman
I did a trackday!!!
PostPosted: 13:30 - 11 Apr 2007    Post subject: Reply with quote
Arg you bender, I'll take em out again in the next few days. MZ engine is priority at the moment, the new crank's in, just making sure I've got everything wedged in there before I seal them back together.
Gaz
The last post was made 18 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 59.13 Kb
