NSR 125 Won't start???
demoNSR
PostPosted: 00:49 - 12 Apr 2007    Post subject: NSR 125 Won't start??? Reply with quote
Hi guys Smile , just a new member, joined a few days ago.
Went out for a ride tonight, started the bike as normal, with choke out for a minute or two. Then when i put the choke back in the bike cut out. Checked the petrol and found it was nearly dry, but still had about a cup full in the tank. So, off i went to the garage, petrol can in hand. Got back, put petrol in tank, and now bike wont start at all.
Was too dark to start checking fuel line for blockage, spark plug etc.
I dont think it could be a blockage in the line, because the inside of the tank is still really clean, like new (03 model)
So now i am wondering if it could be the spark plug, or maybe the carb is flooded.
Any ideas???
Will try starting it again in the morning, have turned the fuel tap off, so if it is the carb, hopefully it will have a chance to dry out.
Cheers.
CRAZY_BIKER
Guest
PostPosted: 00:51 - 12 Apr 2007    Post subject: Reply with quote
Take the plug out and give it a clean with a wire brush, put the spark plug back, then try again and let us know if that makes a difference. Because it could be that you have oiled the plug up.
demoNSR
PostPosted: 01:23 - 12 Apr 2007    Post subject: Reply with quote
I was thinking along those lines, and was going to buy a new plug. But now i will have to go to the bike spares shop on the bus (groan Sad ) if it doesn't work. Will give it a go though.
Cheers Karma
spike_Alike
PostPosted: 01:33 - 12 Apr 2007    Post subject: Reply with quote
Try cleaning it first before you go and buy a new one! Should be obvious whether or not its damaged or just filthy.
You sure its not flooded? Battery has life still right Razz ?
demoNSR
PostPosted: 01:41 - 12 Apr 2007    Post subject: Reply with quote
Yeh the battery is full of power, turns the starter no problem. But the engine seems dead. I thought it could either be the carb, or the plug. Will check the plug tomorrow if it wont start. by that time, any fuel in the carb should have evaporated eh.
spike_Alike
PostPosted: 01:45 - 12 Apr 2007    Post subject: Reply with quote
Yeh, give that plug a damned good cleaning and see how it goes Thumbs Up If no luck, then you might have to replace that plug. I'm sure it'll be ok though, I had a few flooding problems with my NSR when I first got it due to leaving the choke on too long. Seems that giving it too much throttle with the choke out isnt a good idea, and its rather prone to flooding Wink
Bandit 600
demoNSR
PostPosted: 01:50 - 12 Apr 2007    Post subject: Reply with quote
I think you are prob right fella. Will deff give that a go. Thing is, i have booked it in for new tyres tomorro too, and it is always the way when you need to do something, always something to bugger your plans eh.
Cheers mate Karma
spike_Alike
PostPosted: 01:54 - 12 Apr 2007    Post subject: Reply with quote
Rolling Eyes Sods law in action.
Best of luck with her, I'm sure she'll be ok, even if you gotta do a bit of fiddling first Wink
Bandit 600
demoNSR
PostPosted: 02:13 - 12 Apr 2007    Post subject: Reply with quote
Cheers fella, i'll let you know how i get on Smile
alains
PostPosted: 09:04 - 12 Apr 2007    Post subject: Reply with quote
put a new plug . try to start 3 or 4 times (if it doesnot) . take plug off and look at it . if plug is dry that's a fuel line problem , if it's humid it's a sparking problem . you may also take off the plug , put it on the HT cap and let it laying on the head . 2 or 3 long pushes on the start while looking at the plug if you see sparks coming . if no sparks that's an ignition problem
demoNSR
PostPosted: 10:40 - 12 Apr 2007    Post subject: Reply with quote
Cheers Alains, i took the plug out this morning, and it badly needed cleaning, and gap reset. This seems to have sorted the problem. Cheers also to spike_Alike for your helpful advice. Replaced the plug after cleaning, and setting the gap, and she burst into life Very Happy
demoNSR
PostPosted: 10:43 - 12 Apr 2007    Post subject: Reply with quote
Cheers also to Crazy biker Wink Karma
alains
PostPosted: 11:27 - 12 Apr 2007    Post subject: Reply with quote
throw away your genuine BR9ECS and buy a BR9EIX (£8ish) or a DENSO IW27 (£10ish) even if it's a lot more expensive it's worth to have those , trust me
demoNSR
PostPosted: 11:42 - 12 Apr 2007    Post subject: Reply with quote
I know the BR9ECS is the standard plug, and the manual says you can also use a BR10ECS aswell, and i was thinking of that one too maybe. Will it make much of a difference, and if so, what difference can i expect?
Cheers Karma
Marci
PostPosted: 15:31 - 12 Apr 2007    Post subject: Reply with quote
Cleaner running... less carbon deposits left on cylinder and piston = increased performance longevity and a bit more response from the engine (widely debated)
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
demoNSR
PostPosted: 23:06 - 12 Apr 2007    Post subject: Reply with quote
Cheers mate, got a new plug, but the dealer only had the standard NGK BR9ECS. But it was only £2, bargain. And she is running sweet now. Will maybe still try the optional plug to see if there is a difference. Karma
alains
PostPosted: 18:58 - 13 Apr 2007    Post subject: Reply with quote
https://www.sparkplugs.co.uk buy a couple (one on , one spare under your seat)
demoNSR
PostPosted: 19:37 - 13 Apr 2007    Post subject: Reply with quote
Hi Alain. I have ordered a box of 4, from the guy who fitted my tyres yesterday, only £10, which is a bargain i think.
Thanks fella Smile
demoNSR
PostPosted: 19:39 - 13 Apr 2007    Post subject: Reply with quote
P.S. Your De-Restriction guide is also most useful Very Happy Karma
CRAZY_BIKER
Guest
PostPosted: 01:59 - 14 Apr 2007    Post subject: Reply with quote
What shop sells spark plugs for £2 mate ?
demoNSR
PostPosted: 02:05 - 14 Apr 2007    Post subject: Reply with quote
Hi mate. The guy who fitted my tyres sold me a NGK BR9 ES for £2. He is a mechanic with his own work shop, and he sells helmets, leathers etc. The name is "Bills Bikes" of Jarrow, South Tyneside. Not sure if you are nearby fella, but he is one of the fairest mechanics i know. He only charged me a tenner for fitting and balancing both new tyres. His number is 0191 496 3830.
CRAZY_BIKER
Guest
PostPosted: 02:12 - 14 Apr 2007    Post subject: Reply with quote
Cheers for that mate but thats about 200 miles away from me, thanks any way. I might ring him and see if he would sell them in bulk and post them out to me (would still work out cheaper)(looking at buying 10 of them)
alains
PostPosted: 08:59 - 14 Apr 2007    Post subject: Reply with quote
you are a bit hard ! i told you to throw the genuine BR9ECS which are bull shit ! and you bought 4 of non suitable (for this bike) plugs
the BR9ECS can be swapped with a BR8ES (not BR10ES) , but they about the same . trust me buy BR9EIX or denso IW27 . they worth even they cost 4 times the genuine . optimised sparking , much longer life time , you'll spare about 1/2 L to 3/4 L by full tank , engine run far more smoothly , try it once , you wont be disappointed Thumbs Up
demoNSR
PostPosted: 09:24 - 14 Apr 2007    Post subject: Reply with quote
Hi Alain. i was told that the BR10 EIX would be better for the summer, especially if i ride fast. As they can handle higher heat. But i will buy the BR9EIX too, and see which one works best, that was my plan. At the moment, i have a new BR9 (ES) installed, as that is all that was available at the dealers. But he is ordering the BR9 EIX, and BR10 EIX just for me Smile
alains
PostPosted: 14:36 - 14 Apr 2007    Post subject: Reply with quote
https://www.sparkplugs.co.uk shipped within 3 days
The last post was made 18 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 119.57 Kb
