Engine braking..
Dan 4RR
PostPosted: 19:45 - 12 Apr 2007    Post subject: Engine braking.. Reply with quote
Hi. Which engine design would give better engine braking ability over others. For example would an inline four have better engine braking abilities over a V twin. Are 2 strokes better than 4 strokes at engine braking, etc and why???
Cheers.
Humans....the largest form of cancer the world has ever seen!
Speed Cameras - Putting goverment revenue before public safety!
Sephiroth
PostPosted: 19:49 - 12 Apr 2007    Post subject: Reply with quote
4 stroke V twin although I think a single is better?
iooi
PostPosted: 20:17 - 12 Apr 2007    Post subject: Re: Engine braking.. Reply with quote
Cheers.
Well 4 strokes give far better engine brakeing.
The only thing a 2 stroke engine will break is the pistons.....
cokker
PostPosted: 20:46 - 12 Apr 2007    Post subject: Reply with quote
2 Strokes don't really engine brake, the engine just gets faster the more you change down lol.
Id say big single and V-twins are the best, something to do with compression i think Confused
No longer have a bike due to a DVLA/Court royal f**k up.
PostPosted: 21:08 - 12 Apr 2007    Post subject: Reply with quote
You shouldn't really engine brake for any length of time on most 2-strokes. Closed throttle = insufficient oil. The throttle controls the oil pump so when it's closed you're giving it oil for tickover but the engine's doing 6k revs. If you must (like on a steep hill) then it's best to blip the throttle occasionally.
Big singles have a huge amount of engine braking, you can lock up the rear if you downshift too quickly but it's more down to compression. A high compression, low revving engine will tend to have more engine braking effect than a lower compression, high revving engine.
Also the bigger the engine, the more effect. Try snapping the throttle shut on a 1340cc Harley and see how far you get.
magpiemale
PostPosted: 16:57 - 13 Apr 2007    Post subject: Reply with quote
have done that on a z750 and it has a harsh one if slow rideing good when comming to a slow on the motorway
Method
PostPosted: 20:45 - 13 Apr 2007    Post subject: Reply with quote
IL4 4t's have next to none.
2 Strokes have none.
4t Parallel twins have some, barely noticeable.
4t V-Twins have quite a bit, very noticeable.
4t Singles have collosal amounts.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
SoulRider
PostPosted: 22:55 - 13 Apr 2007    Post subject: Reply with quote
Have to admit my engine braking on my sv650s means i hardly have to ever use the brakes unless needed to stop fast. i usually just tap the brake to make the light come on.
V-Twins FTW Thumbs Up Very Happy
My Bike Pics
Deckx
PostPosted: 11:06 - 14 Apr 2007    Post subject: Re: Engine braking.. Reply with quote
iooi wrote:
Cheers.
you can engine brake a SC 2 stroke by changing (slamming) down gears, can actually get it to hop in the direction ur turning , good fun ! Very Happy
bish777
PostPosted: 12:40 - 14 Apr 2007    Post subject: Reply with quote
Small ones wont i guess, but on bigger fours 600 and up say, its noticable. On large fours -750 and up Id say they have a pretty good amount of engine braking.
GSXR1100J
PostPosted: 12:48 - 14 Apr 2007    Post subject: Reply with quote
Throttle and revs control oil. The pump is affected by both. Still not a good idea to use engine braking for a prolonged period of time.
Whether it is a V twin or a parallel twin should make no difference. Important things are compression ratio and gearing.
Marci
PostPosted: 22:22 - 14 Apr 2007    Post subject: Reply with quote
Throttle cable meters the aperture effectively whilst revs control impeller speed and thus flow rate? That right? ie - all the throttle does is reduce the restriction on the flow the more you open it but faster the engine's going faster the flowrate no matter what the restriction... which should also produce the necessary variances in delivery - as the restriction opens head pressure decreases but flowrate increases... that sound about right Keith? (just guessing)
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Jack_Cheese
PostPosted: 22:46 - 14 Apr 2007    Post subject: Reply with quote
Surely depends on the specific engine?
Aren;t you more used to wheelying when you close the throttle? Razz
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 23:01 - 14 Apr 2007    Post subject: Reply with quote
Sounds right, although never really thought it through in any detail.
In theory yes, but just about all modern ish 2 strokes seem to use very similar oil pumps.
dabigginger
PostPosted: 23:06 - 14 Apr 2007    Post subject: Reply with quote
I thought the number of cylinders would have a big effect on it also. For example, a 4 cylinder 4 stroke is going to fire on every turn of the crank, making it nice and smooth, a 2 cylinder 4 stroke is going to fire every other turn of the crank, and a single is only firing once every 4 turns of the crank, so there's not a lot keeping it going! So wouldn't that have some effect on it as well?
PostPosted: 23:19 - 14 Apr 2007    Post subject: Reply with quote
Not sure it alone is going to have any great effect on the total engine braking. Some effect from how heavy the lumps of metal are it is slinging round inside in total. More effect on how it feels / how long it takes feeling to return to your fingers when you have slowed down.
Get rid of the compression and you could turn the crank by hand.
PostPosted: 10:02 - 15 Apr 2007    Post subject: Reply with quote
My 1203cc Harley engined bike doesn't do a lot when you shut the throttle...
... but then thats because the ECU is programmed to continue to fuel the bike so you don't have crippling engine braking. Slipper clutch? Who needs 'em? Very Happy
bish777
PostPosted: 13:50 - 15 Apr 2007    Post subject: Reply with quote
Dump the FI for a big flatslide carb, that'd be more fun.
GSXR1100J
Jack_Cheese
PostPosted: 17:28 - 15 Apr 2007    Post subject: Reply with quote
Rolling off throttle mid-corner would certainly produce some touser browners!
lumphammer
PostPosted: 23:53 - 15 Apr 2007    Post subject: Reply with quote
V-Twins FTW
Same with the old Deauville. Thumbs Up
The last post was made 19 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 112.73 Kb
