painfull clutch hand
Nicky-Jano
PostPosted: 20:54 - 14 Apr 2007    Post subject: painfull clutch hand Reply with quote
Been riding my bike quite a bit since i passed my cbt, who doesn't? Very Happy
But have noticed on my left hand the muscle between my thumb and finger is really sore. Was sore but ok yesterday, but today it's really bad. Have put deepheat on it to no effect.
Has anyone else got any suggestions? I'd like to be able to ride my bike tomorrow without massive pain everytime I work that clutch! Sad
my right ankle is quite ouchy aswell from the kickstart, any tips other than just grit my teeth and get on with it? Razz
thanks
Weedy
PostPosted: 20:58 - 14 Apr 2007    Post subject: Reply with quote
Workmate of mine just took her CBT and has been complaining of the exact same things, clutch hand and ankle hurting.
I think it just takes time for your body to get used to using those muscles more than normal Thumbs Up
Maybe a hot bath to soak the hand/arm after a long ride? Thumbs Up
<CBT passed 16th Sept 2007><Theory Test passed 11th Oct 2007><Practical Test passed 19th Apr 2008>
OWNED: 2008 Aprilia Pegaso Strada CURRENT: Bikeless :'(
Nicky-Jano
PostPosted: 21:01 - 14 Apr 2007    Post subject: Reply with quote
The past week I've been crashing at the bf's house so only been nipping home for a shower, no nice warm baths to sooth muscles Sad
Weedy
PostPosted: 21:04 - 14 Apr 2007    Post subject: Reply with quote
Hmmm, I take it you're using all four fingers to pull the clutch in? If so, maybe see if only using 2 fingers helps?
The thing my workmate was doing a lot was "covering" the clutch pretty much all the time...If you're doing that then maybe try not covering it all the time (if you're comfortable with that?)
Only other thing I can think of is just taking it easy with the riding if it gets painful (RSI can be aggrivated to the extent where you can't use the hand at all Confused )
Lou Thumbs Up
Nicky-Jano
PostPosted: 21:06 - 14 Apr 2007    Post subject: Reply with quote
I think it's made worse because I live in traffic jam central and am constantly stopping and starting (not confident enough to filter yet! Razz ).
But yea I do use all four fingers to bring clutch in. Will give the two fingers a go Thumbs Up Smile
nick606
PostPosted: 21:10 - 14 Apr 2007    Post subject: Reply with quote
clutchless gear changes Very Happy use the clutch till ur in second and then just drop revs knock up and then bring the revs back on. (use the clutch when going down though the gears though)
hmmm this post doesnt really help as ur still using the clutch 60% of the time : /
Nicky-Jano
PostPosted: 21:11 - 14 Apr 2007    Post subject: Reply with quote
It's the thought that counts! Razz
pwntifex
PostPosted: 21:13 - 14 Apr 2007    Post subject: Reply with quote
This might sound silly, but are you pulling too hard on the clutch lever?
You should generally be easing the clutch in and out rather than grabbing a fistful.
Nicky-Jano
PostPosted: 21:17 - 14 Apr 2007    Post subject: Reply with quote
Fair question don't worry Smile . I'm pretty easy going on it except when trying to get to a higher speed quickly (catching up with the bf so I don't get lost).
I think the soreness comes mostly from sitting in the traffic jam keeping the clutch in at first gear. Have been told to stick it in neutral, but am quite paranoid I'd bugger up and keep everyone behind me waiting! Razz
Weedy
PostPosted: 21:22 - 14 Apr 2007    Post subject: Reply with quote
Just give them the finger (unless its the police!) and take your time Thumbs Up Everyone stalls now and again! Cool
Nicky-Jano
PostPosted: 21:26 - 14 Apr 2007    Post subject: Reply with quote
I take stalling to a whole new level believe me!
I stalled about 15 times straight after my cbt. Though some blame can go to my gear box which is unusually low Confused having it fixed soon me hopes. I have to point my foot down like a ballerina to change gear, hard in Dr Martens Razz
Weedy
PostPosted: 21:29 - 14 Apr 2007    Post subject: Reply with quote
That could be a problem, especially in DM's! Laughing
Hope you get it all sorted soon though, I know how much RSI hurts, it's really not fun Sad
pwntifex
PostPosted: 21:32 - 14 Apr 2007    Post subject: Reply with quote
That sounds almost like you're sitting with your heels on the pegs.
Nicky-Jano
PostPosted: 21:34 - 14 Apr 2007    Post subject: Reply with quote
I ride the way I was taught. My gear box is alot lower than the one on the CG I learnt on.
Giffer2
PostPosted: 21:45 - 14 Apr 2007    Post subject: Reply with quote
The box is or just the lever - If it's just the lever adjust it to a position more comfortable for you.
Mar 2007 - Varadero XL125v7, May 2007 - SV650S
17/05/07 - A2 Test Passed
Nicky-Jano
PostPosted: 21:46 - 14 Apr 2007    Post subject: Reply with quote
Must be the lever then cause my dad mentioned adjusting it for me.
Sparks!
Sir Tart-a-lot
PostPosted: 22:24 - 14 Apr 2007    Post subject: Reply with quote
Adjust the lever round until you are happy with it. Maybe try loosening the clutch adjuster off a bit so the bite point is quite far out on the lever, so then you don't have to pull it in so far.
If that fails, go to www.racespec.co.uk > Controls > Levers
and buy the "Premium Forged 3-Way Lever + Bracket - complete "
https://www.racespec.co.uk/rs_shop_final/media/3way_lever_2_copy.jpg
Should make the clutch pull a LOT lighter. May well help....
Nicky-Jano
PostPosted: 22:28 - 14 Apr 2007    Post subject: Reply with quote
Thanks Thumbs Up will have a look but it depends on prices. I'm a little short on cash at the mo so depending on my dad's mechanic skills and favours called in from his mates to get stuff sorted.
Sparks!
Sir Tart-a-lot
PostPosted: 22:32 - 14 Apr 2007    Post subject: Reply with quote
Lever is £12 posted. Needs nothing else to fit and is easy enough to do so won't need to go into a garage or anything... so all in very cheap.
But I'd start with just moving the lever round on the bar until you are happy with the positioning.. as it may be that its too high and you have to stretch your fingers upwards to get it.. if that makes sense.
Nicky-Jano
PostPosted: 22:35 - 14 Apr 2007    Post subject: Reply with quote
Yea thanks Thumbs Up Smile
Rookie
PostPosted: 23:53 - 14 Apr 2007    Post subject: Reply with quote
I had this when I got a bike after 5 months of not riding. The first trip I did on it was a 3 hour journey and I was in absolute agony. It was totally gone after about 2 days, it was just my hand not being used to the strain.
Nicky-Jano
PostPosted: 06:31 - 15 Apr 2007    Post subject: Reply with quote
Did my cbt a week ago have done a little over 600 miles already. May not be much to some but it is to my clutch hand Razz quarter of that or more is spent in traffic jams Mad
Could be both things, stiffish clutch and my muscles not being used it.
Think I might be having a break of riding today. Is bf's birthday, he gets to decide what to do Razz
st3v3
PostPosted: 08:57 - 15 Apr 2007    Post subject: Reply with quote
600 miles in a week? Shocked only just done 2 and a bit thousand miles since october last year. Confused
Nicky-Jano
PostPosted: 10:42 - 15 Apr 2007    Post subject: Reply with quote
Laughing I'm still new to it so it's still a novelty. I'll probably get bored of riding around for no reason... doubt it though Mr. Green
weathers been good too which adds to it.
trevoriv
PostPosted: 11:11 - 15 Apr 2007    Post subject: Reply with quote
Stop being soft Mr. Green
The last post was made 19 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 127.17 Kb
