indicator rules / mot question?
iand
PostPosted: 12:12 - 14 Apr 2007    Post subject: indicator rules / mot question? Reply with quote
Please confirm the following for me,
As far as i understand it is not illegal to run a bike wihtout indicators, but if it has indicators fitted dthey must work correctly.
Does this mean if i remove the indicators i have to remove the switch and wiring too?
This would be on a 1980 kawasaki by the way.
cheers
Iand
PostPosted: 12:22 - 14 Apr 2007    Post subject: Reply with quote
Correct for a bike that old. As to the switch that tends to depend on how strict the tester wants to be. It doesn't say in the old manuals floating around on the web, but could be insinuated by wording on perminantly disconnected.
bish777
PostPosted: 12:24 - 14 Apr 2007    Post subject: Reply with quote
According to my MOT tester, provided the bike is pre august 1986(or thereabouts) If they arent fitted, they arent tested, that includes the switch and telltale, even if they are still on the bike.
GSXR1100J
KTM Gordo
PostPosted: 22:45 - 14 Apr 2007    Post subject: Reply with quote
FWIW, the exemption on indicators also applies to enduro and trials 'bikes that are not normally used on the road. My KTM doesn't have indicators, and the switch and tell-tale have both been removed. I have them in a box somewhere...
But Mr Kickstart is right that they're optional on a 'bike of 1980 vintage.
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
iand
PostPosted: 23:10 - 14 Apr 2007    Post subject: Reply with quote
i picked up a Z500 today and it has the worlds biggest indicators on it, there fucking enormouse, thats why i want to get rid of them, might be possible to get some smaller but still classic styled ones i guess?
what do you reckon, no indicators = bad idea?
Iand
KTM Gordo
PostPosted: 23:15 - 14 Apr 2007    Post subject: Reply with quote
It depends on when and where you're going to ride it.
If it's mostly gentle trundles in the countryside then just do hand signals; if mostly in town, commuting to/from work etc., then I'd rather have indicators.
Most people these days aren't expecting hand signals, so be extra careful.
HTH Smile
iand
PostPosted: 23:40 - 14 Apr 2007    Post subject: Reply with quote
i think i might try to find something a little more subtle rather than removing them.
h00dwink
PostPosted: 06:51 - 15 Apr 2007    Post subject: Reply with quote
my indicators havent worked for about 4 months now. it's probably just a loose connection somewhere as they work fine from teh alarm. but i'll be jiggered if i can be active enough to get off my arse to fix it.
hand signals prove useful.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
Nicky-Jano
PostPosted: 07:43 - 15 Apr 2007    Post subject: Reply with quote
Not like some people actually look anyway. Indicated to change lanes and people have sped up! (don't think it was on purpose, they just didn't look at my indicators)
Went around a roundabout the other day in the right lane clearly indicating, then i get beeped at by some random guy when i go into my turning. Confused
KTM Gordo
PostPosted: 10:27 - 15 Apr 2007    Post subject: Reply with quote
That might not have had anything to do with indicators - perhaps he thought you hadn't seen him.
A toot of the horn means the same as a flash of the headlights: "I am here".
kestrel
PostPosted: 23:01 - 15 Apr 2007    Post subject: Reply with quote
Got this from ukmot.com
If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
brooky
PostPosted: 23:05 - 15 Apr 2007    Post subject: Reply with quote
I'm sure someone mentioned on here how they removed the indicators and simply taped over the switch so you could not move it.?
I guess it all falls down to how friendly the tester is.
Suzuki GSX-R 750 K6.
steveh
PostPosted: 23:07 - 15 Apr 2007    Post subject: Reply with quote
ive removed my indies on my cat, just use arm signals and be carefull and ive never been asked about it.
Saying that they wernt removed, the rear never got put on after i got my tail tidy, so i just taped over the front to be legal.
this legal?
kestrel
PostPosted: 23:21 - 15 Apr 2007    Post subject: Reply with quote
this legal?
Not according to the regs Steve, if it's a road bike registered after 1st August 1986 then it must have approved indicators fitted and they must be working.
The last post was made 19 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 82.09 Kb
