Whats going on with my rear Dunlop?
CoronaBoner
PostPosted: 12:05 - 15 Apr 2007    Post subject: Whats going on with my rear Dunlop? Reply with quote
Just got back from a quick ride and noticed I was having grip issues on my left turns, felt very weird as I was driving out of corners.
I have had this rear tyre on for only a week now and its showing signs of abnormal wear already? the pattern is consistent throughout the whole left hand side of the tyre and is very very sticky to touch...
The PSI is bang on 36 which is recommended.
The right hand side is fine, but I do tend to push left handers harder, but I can't see how that would do this to my tyre.
Its the latest Dunlop, 208rr model I think, any ideas to why its getting like this? as it cost me £120 Evil or Very Mad
https://img247.imageshack.us/img247/805/prilla325bcftgp0.jpg
https://img244.imageshack.us/img244/7391/prilla329bcftkc3.jpg
2004 RSV Factory
Cluck cluck chicken
mrtEE
PostPosted: 12:26 - 15 Apr 2007    Post subject: Reply with quote
is the chain rubbing on the tyre?
CoronaBoner
PostPosted: 12:29 - 15 Apr 2007    Post subject: Reply with quote
Very good idea, I'll go check. Thumbs Up
2004 RSV Factory
Cluck cluck chicken
cokker
PostPosted: 12:31 - 15 Apr 2007    Post subject: Reply with quote
Agreed, looks like chain rub, if the rear tyre is the right size your rear wheel must be way off straight Shocked
No longer have a bike due to a DVLA/Court royal f**k up.
0ddball
PostPosted: 12:34 - 15 Apr 2007    Post subject: Reply with quote
Sounds like the most likely reason. Either that or the tyre is rubbing on the swingarm/hugger.
Also make sure you're axle is tight. If not there is a possibility that the tyre alignment looks fine when stood still but the wheel is moving slightly under load.
ZXR750L
CoronaBoner
PostPosted: 12:41 - 15 Apr 2007    Post subject: Reply with quote
Yea it is the freaking chain Twisted Evil If it does end out to be due to an ill fitted rear then can I get my money back? or get a new one as it looks shagged for week old road going tyre.
Cheers guys.
2004 RSV Factory
Cluck cluck chicken
doggone
PostPosted: 13:35 - 15 Apr 2007    Post subject: Reply with quote
Something seriously wrong then - Very bad alignment? spacers not in correct place?
Wrong size tyre?
bish777
PostPosted: 13:43 - 15 Apr 2007    Post subject: Reply with quote
thats very bad!
The tyre would have to be very oversize to do that so I suspect the chain and rear wheel alignment is way out.
As has been mentioned before, are the spacers fitted correctly?
Id check it and see-if you took the whole bike and had them remove the wheel, you need to get them to sort it out. They should do this gratis and a new tyre too!
GSXR1100J
PostPosted: 13:48 - 15 Apr 2007    Post subject: Reply with quote
Also worth checking that the spacer between the sprocket carrier and the wheel is in place. If that is missing then there is a good chance the bearing in the sprocket carrier will collapse, and the swinging arm will be wrecked when the studs holding the spocket on touch it.
CoronaBoner
PostPosted: 15:18 - 15 Apr 2007    Post subject: Reply with quote
Can't do sod all till Tuesday as all the places round here close Sunday and Monday.
Its the right sized tyre, 190/50, SDC performance said a 180 would fit in just fine but I really wanted to stick with stock as I am comfortable with the bike as it is.
Annoyed as it could have been dangerous had I not looked.
Also managed to nail a bird that got stuck in between my yokes Sick Been trying to scrape all the crap of my forks.
Some day!
2004 RSV Factory
Cluck cluck chicken
PostPosted: 15:47 - 15 Apr 2007    Post subject: Reply with quote
If it is the spacer behind the sprocket carrier then do not ride it.
Personally, stick it on a paddock stand, whip the back wheel out and have a look.
lllN30lll
PostPosted: 16:19 - 15 Apr 2007    Post subject: Reply with quote
Cheers guys.
checked your wheel alignment?
if the left is further back than the right adjuster then it'll happen
Turbo R1
CRF450R
Finglonga
PostPosted: 16:36 - 15 Apr 2007    Post subject: Reply with quote
Eh? Cant you look yourself? Wouldn't pay anybody to check that, its only a case of whipping the rear wheel off, then making sure everything is in the right place.
Andy Sez....
F.Y.Y.F.F.
CoronaBoner
PostPosted: 16:50 - 15 Apr 2007    Post subject: Reply with quote
One thing is I don't own a Torque wrench and would not trust myself messing with wheels.
I'm happy to do the brakes oils and the other basic things, but I spent £120 quid to get this done so why should I bother to go to the trouble of taking the wheel off and checking myself all because a "trained" mechanic could not do a proper job!
It's going back to the shop Tuesday where they can fix it.
I only chose this garage as it was a quick solution to getting it sorted as I had a big nail stuck in the one before it, and they happened to have a Dunny in stock.
SDC performance would have been place of choice but they would have had to order in the tyre.
2004 RSV Factory
Cluck cluck chicken
SoulRider
PostPosted: 11:13 - 16 Apr 2007    Post subject: Reply with quote
Ive got a torque wrench you can use (no idea what setting would be as havent used it yet) but i dont have a socket set big enough, i need to get a 30 soon for my rear wheel.
Best bet is to leave it on as some garages will try and say it has happened since you took the wheel of, or just dont tell them you've had it of. Let them pay for it and sort it out , their mistake after all.
My Bike Pics
gadfium
PostPosted: 21:10 - 16 Apr 2007    Post subject: Reply with quote
I got me one of THESE...only 15 squid.
Perfectly fine for axle nuts (I have tested it with my £50 halfords wrench and it is bang on accurate at 60ft/lbs)
Those who risk nothing, do nothing, achieve nothing, become nothing.
doggone
PostPosted: 10:10 - 17 Apr 2007    Post subject: Reply with quote
I think you can use common sense for an axle bolt TBH.
Dom_
Points Mean Prizes
PostPosted: 11:42 - 17 Apr 2007    Post subject: Reply with quote
You'd prefer to tighten the sump plug and filter without a torque wrench but you won't do the rear wheel? Confused
I've never used a torque wrench on wheels, it's just common sense as to how tight it should be. Why not have a look yourself, will take you 30 mins, you'll gain some experience and you'll be able to spend more time on the bike if you fix it.
CoronaBoner
PostPosted: 12:18 - 17 Apr 2007    Post subject: Reply with quote
Rolling Eyes Yes basically....
Like I said, they screwed it up, they can fix it. Not going to cost me nothing. Thumbs Up
May even get a 180 put on to see if theres a great change to how fast it turns in.
2004 RSV Factory
Cluck cluck chicken
CoronaBoner
PostPosted: 19:43 - 17 Apr 2007    Post subject: Reply with quote
UPDATE:
Well now I really am confused.. Confused
Took it to the reliable garage where they got it up on the bench and gave it a good look over, first thing they said was that the tyre didn't look right, as if it were too flat and wide..
Everything had been put back together spot on, so this was causing some confusion as to why it was making contact with the chain with a standard sized tyre that should work fine, as it has done the 3-4 times before...
The actual tyre in question is a Dunlop D208rr Qualifier.
So they got onto the phone to Dunlop and specified the problem. Dunlop basically said that it could be an iffy one of the production line as they do get some that are not 100%. So basically get it swapped from where it was done.
They also told me that it would fail an MOT like it is at the moment! ( got that in 3-4 weeks time :O )
So going back to the place that done the actual tyre fit are saying that my chain is loose and thats whats making the contact andcausing the wear.
But the other garage say otherwise... and if it were the chain, then why did this not affect the previous tyre, and even if it were loose, is it not the duty of the garage to check this when putting on a new tyre?
So how do I go about getting this resolved as I have a week old tyre that cost loads and won't pass an MOT..
2004 RSV Factory
Cluck cluck chicken
R4nger
PostPosted: 20:03 - 17 Apr 2007    Post subject: Reply with quote
A good chain does not move that much side to side. It mainly goes up and down. The shop is talking crap to fob you off.
0ddball
PostPosted: 20:05 - 17 Apr 2007    Post subject: Reply with quote
I just looked at mine and there is about 10mm between the chain and tyre with a 180 fitted, so i guess with a 190 fitted it would be possible for a loose chain to rub against it. Then again, if the 190 is standard you'd expect the manufacturer would have built in a similar clearance.
But whatever caused it, it's a dangerous fault and experienced mechanics shouldn't have even let it out of the workshop like that. If they take the rear wheel off it's up to them to put it back right with the chain at the correct tension.
ZXR750L
SoulRider
PostPosted: 09:24 - 18 Apr 2007    Post subject: Reply with quote
Let me come down with you, i wont take no for an answer.
End of the day you have confirmation from dunlop saying that it is a dodgy one of the line and it needs to be replaced.
My Bike Pics
PostPosted: 10:10 - 18 Apr 2007    Post subject: Reply with quote
Get them to ring Dunlop up or say you will take them to court and sue them for selling good not fit for purpose.
Sounds like they are just being lazy to me as they could surely claim the money back from Dunlop if they have admitted it's a dodgey batch. Or get Dunlop to send you a credit note to get another tyre put on else where.
The last post was made 19 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 126.17 Kb
