| Fenat |
 Fenat L Plate Warrior
 Posted: 13:43 - 18 Apr 2007 Post subject: Honda NSR -97 , blackbox? |
Hello
I'm about to try and de-restrict my NSR. I have looked in the air intake and the exhaust pipe and found nothing. Still the motorcycle barley do 110 km/h. I have heard something about a black box somewhere under the tank.
The problem is, i have no clue about what one looks like so i can't check if I have one. So I was wondering if anyone could post a picture of a blackbox?
I checked myself and found this thing, is this the one?
https://i14.tinypic.com/4371579.jpg
There are four cables going in to it. It looks like a gold box, about 2x2x2 cm in volume.
Thanks |
| demoNSR |
 demoNSR Scooby Slapper
 Posted: 14:20 - 18 Apr 2007 Post subject: |
Have a look at Alains de-restriction guide. https://www.geneva-racing.com/~alains/NSRtips.doc I am sure there is something in here about the CDI unit for European spec bikes. Assuming yours is a European spec model.
UK spec models have a baffle in the header, and a restrictor behind the carburettor.
Also, have a look at NSR125.com Workshop section. this tells you how to de-restrict a UK spec bike. |
| Fenat |
| demoNSR |
 Posted: 15:20 - 18 Apr 2007 Post subject: |
Alains guide also tells you that you need to make adjustment to the Airbox. This is a black box, about 30x15cm. This is located under the tank also, and the lid/top is held down with 6 screws. You will need to make extra holes in the box to allow more air in. This is explained in Alains guide. But if your bike is European spec, the CDI unit is also restricted, which would explain why you only achieve 7,500rpm. This will only require you to make a break in a connection. But not sure which connection. Hope this helps  |
| Fenat |
| demoNSR |
 Posted: 16:59 - 18 Apr 2007 Post subject: |
The jont is a soldered joint on the circuit board, but i am not sure which one. I think this restricts the power valves. but i am sure there is something about it in Alains de-restriction guide. But my bike is UK spec, so i did not take much notice of the procedure, as the CDI on UK spec bikes is not restricted. Once your bike is fully de-restricted, you should reach speeds of around 105-110 mph, or about 150-160 kmh (i think) But you will also need to make extra holes in the Airbox to allow more air in.  |
| Fenat |
| demoNSR |
| Fenat |
| demoNSR |
 Posted: 18:44 - 18 Apr 2007 Post subject: |
Yes, there is a bridged joint on the circuit board in the CDI that will need to be broken. This will allow your valves to open fully, (i think). But check the guide to be sure.  |
| Fenat |
| demoNSR |
 Posted: 19:15 - 18 Apr 2007 Post subject: |
This should de-restrict the valves, but what have you done so far? What size front sprocket is on the bike? There may be more than one factor you need to look at before your bike is FULLY de-restricted.
I know for UK spec bikes, you need to remove a baffle from the exhaust intake, remove restriction from behind the carburettor, up-jet the carburettor (new jets), modify the air box and fit a new larger front sprocket. I am also goint to fit an after market exhaust, which should give me a little more power too. and carbon reeds. But you will need to do everything in Alains guide for a European spec NSR to fully de-restrict. He seems to know more about NSR's than anyone else, so it is the best place to look.
My bike is UK spec, so that is what i am concentrating on, and i am no expert, i just pick up tips along the way.
A good idea is to print the whole guide for your particular bike, then you will have it beside you when doing the work.  |
| Fenat |
 Posted: 19:29 - 18 Apr 2007 Post subject: |
So far I practically haven't done nothing. I have just looked for restrictions. There was no one in the exhaust pipe or in the air intake.
And to be honest, I don't know what size the sprockets are. My guess is that they are the original size.
I dont think I will buy new jets nor a new exhaustpipe, going for a bigger bike in the summer But for now it would be fun if all my friends didn't drive away from me so easily. |
| demoNSR |
 Posted: 19:35 - 18 Apr 2007 Post subject: |
Ah you poor luv
You will most likely need a new front sprocket, modify the airbox, and up-jet the carburettor.
New jets are very cheap, about €20 for all 3 needed.
To modify the airbox is free/gratis, if you know what needs to be done.
New front sprocket will be around €60
And of course, de-restrict the CDI. |
| alains |
 alains World Chat Champion
The last post was made 18 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
