| SoulRider |
 SoulRider World Chat Champion
 Posted: 09:36 - 18 Apr 2007 Post subject: Adjusting chains |
Just a quick question really, im going to get a 30mil socket bit soon and start tightening my chain up, i obviously cant check the play while sitting on it so when im tightening it (whilst on paddock stand) how much play should there be for a chain to be nice and tight?
Obviously i dont want it to tight by mistake so thought i would check first.
Cheers  ____________________ My Bike Pics |
| iand |
 iand Nitrous Nuisance
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 10:00 - 18 Apr 2007 Post subject: |
30mm socket?
Don't forget 'free play' is loose slack, not how much the rock solid tight chain bends  |
| SoulRider |
 Posted: 10:49 - 18 Apr 2007 Post subject: |
Yup big 30mm socket for my back wheel, and i know its loose slack lol.
Ill check my haynes manual later to see what it says. ____________________ My Bike Pics |
| Finglonga |
 Finglonga World Chat Champion
| SoulRider |
 Posted: 10:55 - 18 Apr 2007 Post subject: |
When i watched them in the garage there was no one sitting on it, he tested the play with the back wheel spinning.
Are you saying i should tighten it a bit, sit on it test the play then tighten more if nessecery? ____________________ My Bike Pics |
| MarJay |
 MarJay But it's British!
| demoNSR |
 demoNSR Scooby Slapper
 Posted: 11:13 - 18 Apr 2007 Post subject: |
Is it normal to have tight spots on the chain? As i just had new tyres fitted a few days ago, and when the wheel was put back on, the guy was spinning the wheel and there is a couple of tight spots after adjustment, where the wheel becomes stiff while spinning. I had tried to adjust my chain before this myself, and found i got the same problem, and thought i was doing something wrong. So when the mechanic found the same problem, i asked if it was normal, and he said yeh, sometimes. I am a bit dubious, and was wondering if my front sprocket might be warped. The wheel spun straight though, when i put the bike on the paddock stand. I even put it in first gear, stood back and watched, and the wheel seemed to spin straight and true. Any ideas?? |
| Rookie |
 Rookie World Chat Champion
 Posted: 11:17 - 18 Apr 2007 Post subject: |
| demoNSR wrote: | Is it normal to have tight spots on the chain? As i just had new tyres fitted a few days ago, and when the wheel was put back on, the guy was spinning the wheel and there is a couple of tight spots after adjustment, where the wheel becomes stiff while spinning. I had tried to adjust my chain before this myself, and found i got the same problem, and thought i was doing something wrong. So when the mechanic found the same problem, i asked if it was normal, and he said yeh, sometimes. I am a bit dubious, and was wondering if my front sprocket might be warped. The wheel spun straight though, when i put the bike on the paddock stand. I even put it in first gear, stood back and watched, and the wheel seemed to spin straight and true. Any ideas?? |
Tight spots are just a sign of a worn chain, but if there's plenty of adjustment left and not too much sideways movement it's OK. Best bet is to take the chain off and soak it in paraffin for a good few hours to try and work the tight spots out.
Also check how sharp the teeth on the sprockets are, if they're really sharp then you'll want to replace the lot. |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 11:18 - 18 Apr 2007 Post subject: |
It's just where the the chain has worn unevenly. They are called "tight spots".
Nothing to really worry about, just make sure you measure the slack in the chain at one of the tight spots and you'll be fine. ____________________ My Flickr |
| Finglonga |
| Grubby |
 Grubby Spanner Monkey
| Feasty |
 Feasty World Chat Champion
 Posted: 12:36 - 18 Apr 2007 Post subject: |
And just to quickly ask the question I'm sure is on the tips of everyone's tongues whilst reading this thread!
What's the best and quickest way of checking where the tightspots are on a chain? |
| Finglonga |
| demoNSR |
 Posted: 13:13 - 18 Apr 2007 Post subject: |
Thanks guys, I was a bit worried that i had a warped sprocket or something. I do keep the chain lubed regularly, but i will check the teeth on the sprocket etc, and try adjusting the chain like Finlonga described. Cheers fellas, very useful tips.  |
| cagiva gezzer |
| demoNSR |
 Posted: 17:42 - 18 Apr 2007 Post subject: |
Yeh i have tried that, cheers. So i think my chain is probably stretched in 1 or 2 places. It is kept well lubed though, so i don't think it is corrosion, as it has never been let to go dry while i have had it. And it was perfect when i bought the bike in october, no tight spots. Thinking of getting a new chain and sprocket set for it for de-restriction anyway. Just hope it doesn't snap in the meantime.  |
The last post was made 18 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
