Seized rear caliper screw on Honda NSR 125.
scottishcammy
PostPosted: 18:20 - 19 Apr 2007    Post subject: Seized rear caliper screw on Honda NSR 125. Reply with quote
AAAAAARRRRRRRRGGGGHHHHHHHHHH!!!!!!
My mate came round today and removed all the farings on my new Honda NSR 125 ('03 plate). He put new front brakes on, new spark plug, high temp' paint on the exhaust and cleaned the shit out of it! Very Happy
However, as you can tell from the title, the rear brake caliper screw is seriously, stuck. It just won't budge. It's been in WD40 all bloody day but still no joy & the head is now starting to go.
He's leaving it over night to come back & try tomorrow.
If it's still buggered, any suggestions? I'm going to be totally sick if I have to buy a new caliper...I want to get out on my new bike!
Any suggestions would be braw Wink
Finglonga
PostPosted: 19:01 - 19 Apr 2007    Post subject: Reply with quote
What do you mean screw? Do you mean the bleed nipple? If so you wont need a new calliper, you just need to carefully drill it out and put a new one in.
Andy Sez....
F.Y.Y.F.F.
ncrn
PostPosted: 19:11 - 19 Apr 2007    Post subject: Reply with quote
what for changing the rear brake pads? those bolts don't move on mine either.
The way I did it was to take the rear wheel off the bike, and you can remove the caliper that way. A bit more labor but it works.
scottishcammy
PostPosted: 19:18 - 19 Apr 2007    Post subject: Reply with quote
Thanks for the replies. It's the screw in the middle that won't budge Sad
https://www.thewatchforum.co.uk/uploads/monthly_04_2007/post-127-1177006651.jpg
https://www.thewatchforum.co.uk/uploads/monthly_04_2007/post-127-1177006729.jpg
https://www.thewatchforum.co.uk/uploads/monthly_04_2007/post-127-1177006809.jpg
ncrn
PostPosted: 19:50 - 19 Apr 2007    Post subject: Reply with quote
ah now I see what you mean, thats a bugger. Erm, I'm not really sure how to get stuck screws out I'm afraid Sad
adamj
PostPosted: 20:21 - 19 Apr 2007    Post subject: Reply with quote
Theres a few threads about stuck screws/bolts going about Very Happy
Depends what resources you've got at hand really, try tightening it up a tiny bit then loosen it to where it was, increasing how much you undo it each time for starters but I guess you might have tried this already.
If the WD40 doesn't work try penetrating oil which is usually a bit thinner for another night.
If you've got a copper hammer or copper bar, as long as it doesn't damage anything I'm not sure it matters as long as its less dense than the screw/caliper, try hitting the screw along its length just to shock it then go back to tightening and loosening if it'll budge.
If you've got a heat source try warming it up so it expands and grips the threads.
That screws looking a bit rusty tho so might be a bit of work, make sure when it goes back in, if you're not replacing it, put a bit of oil on the tip so you won't have the same problem next time!
Good luck getting it off, let us know how you get on Smile
scottishcammy
PostPosted: 21:10 - 19 Apr 2007    Post subject: Reply with quote
HUUURRRAAHHH! Thanks everyone so much, I got the bloody thing off! I put the caliper back on the bike, for leverage, and I put a spanner on the screwdriver. I leaned into it with all my weight and it wouldn't move. I then turned it to tighten it, and it moved a tiny fraction, kept doing this and eventually it shifted! Oh, it was almost sexual. Turns out it's a cap, which protects a lovely, clean, easily moving screw!
The thread was totally white.
Phoned my mate & he was well chuffed! He's a great guy and is coming round tomorrow for similar 'fun'!
The last post was made 18 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 54.53 Kb
