 brooky Brolly Dolly
 xlfive Scooby Slapper
 techierob Traffic Copper
 Posted: 19:26 - 28 Apr 2007 Post subject: |
you'll need to determine whether the slow disk speed is down to excessive disk traffic or whether it's a hardware fault.
If you're running a unix os, then you can just run iostat to get an overview of traffic on each controller, disk and partition. If you're running windows, then the performance monitor should give you an idea of how much the disk is getting thrashed, although if it's a trojan causing the disk traffic then there's a better-than-average chance that it would have modified the performance monitor to disguise its presence, so putting your ear to the disk might be a more reliable method.
Is the disk formatted as NTFS? If not, then try booting off a knoppix live cd and testing the disk speeds with that. If the problem goes away, then it's almost certainly a software issue.
If there's no unusual disk activity, then it could be a hardware fault. If the disk is IDE/ATA then it could be either the motherboard, the cable or traffic bottleknecking somewhere on the disk controller. Does your disk share an IDE chain with another drive? If so, I'd first suggest you explicitly jumper them as master and slave rather than rely on cable-select. If there's a cd/dvd drive sharing the controller, then maybe there's just a cd in there that's causing the disk controller to get swamped or else the audio cable has got disconnected from the sound card. To make sure, try disconnecting any other devices using the same controller and see if it alters the speed at all.
If the disks are SATA, then check if there's been any recent changes to the drivers and if they're SCSI, check that the disk(s) are jumpered correctly for their ID and that the chain's terminated.
If none of that sheds any light on things, then try reseating all the cables. If that doesn't fix anything, then you'll need to test the disk out with a new ribbon and/or test the system with an alternative disk to see if the problem still exists with that. |
