Metal supplies
andrew
Mister Road Rage
PostPosted: 17:37 - 27 Apr 2007    Post subject: Metal supplies Reply with quote
I'm after some thin metal tubing to make a stay for a radiator conversion. Does anyone know of anywhere on the internet i can order some in small quantities.
Thanks
Walloper
PostPosted: 17:47 - 27 Apr 2007    Post subject: Reply with quote
What about cutting up an old bike frame?
andrew
Mister Road Rage
PostPosted: 18:05 - 27 Apr 2007    Post subject: Reply with quote
I'd prefer it if the tube was solid and about the thickness of a pencil to be honest. I'm not great welding so thing i'd be able to weld it better that if the tube was hollow.
Good idea though, i must have something lying around that i could cut up...
slj23
PostPosted: 18:52 - 27 Apr 2007    Post subject: Reply with quote
couldn,t you use threaded bar,you can buy that anywhere.
'isn't it enough to see that a garden is beautiful without having to beleif that there are fairies at the bottom of it too?'
Walloper
PostPosted: 18:58 - 27 Apr 2007    Post subject: Reply with quote
You want a piece of bar stock then not a tube.
Bolt as suggested.
Tecknikally speaking. If you are welding to the radiator a braze would be better and if welding to the frame be carefull you do not warp or de-stress the area welded. Frames are assembled in jigs to prevent twisting.
Arc or Gas?
andrew
Mister Road Rage
PostPosted: 19:57 - 27 Apr 2007    Post subject: Reply with quote
I'm not doing anything too drastic, i'm making a u shaped clip to hold the bottom of the radiator and planning on welding a bar to that, once that's welded together i'm going to fabricate a metal plate that will bolt onto an existing bracket on the engine, normally there is a belly pan in its place but that won't be there.
adamj
PostPosted: 23:19 - 27 Apr 2007    Post subject: Reply with quote
Only internet one I know with a wide range of stock is https://www.metalsdirectuk.com/
Not used them myself but they look good on the face of things, I plan on using them for a possible future project so lemme know how they turn out if you use them Thumbs Up
Failing that have you tried ebay? You'd be suprised the stuff you can find, I found all sorts of ally round bar etc on there.
willi
PostPosted: 14:46 - 28 Apr 2007    Post subject: Reply with quote
make it out of aluminium your hardware shop should sell it. and get someone to weld it.shouldnt cost alot.wont rust and have that billet look Thumbs Up
wat goes around comes around.
andrew
Mister Road Rage
PostPosted: 23:00 - 28 Apr 2007    Post subject: Reply with quote
Thanks for the advice, i think that's probably the best bet, i'm sure they'll make a much neater job than me.
Walloper
PostPosted: 14:05 - 29 Apr 2007    Post subject: Reply with quote
Alloy is such a bitch and difficult to do unless tig or mig.
Expensive.
Gas or arc is easier to find.
Unless the frame is alloy Doh!
willi
PostPosted: 22:33 - 29 Apr 2007    Post subject: Reply with quote
Expensive.
its not expensive here.
PostPosted: 22:37 - 29 Apr 2007    Post subject: Reply with quote
I was looking for some metal for playing/stuff in my van.
Found there's a metal yard just up the road - they have a cheap section for off cuts and a 'free bucket' for little bits, with plenty of useful stuff in.
davidimurray
PostPosted: 09:26 - 30 Apr 2007    Post subject: Reply with quote
If you're only after a small amount have you tried B&Q? They tend to keep some stuff in ? How much are you after and what size?
andrew
Mister Road Rage
PostPosted: 13:02 - 30 Apr 2007    Post subject: Reply with quote
I'll take some measurements tonight. It's only going to be a small amount though. G, could you get me some details for this place near you?
Thanks
The last post was made 18 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 79.14 Kb
