| CaPo |
 CaPo Scooby Slapper
| matthab |
 matthab Crazy Courier
| hazza |
 hazza World Chat Champion
 Posted: 21:27 - 27 Apr 2007 Post subject: |
yeah that sounds like the clutch slipping to me  ____________________ 3 Honda NC50's(Sold)-->'72 Puch Maxi S (Sold, want it back!)--> '90 Yamaha RXS 100 (Stolen)--> '87 Honda Cub 90(Sold) --> '95 Kawasaki Eliminator (Sold) --> '98 Bandit 600 (Sold) -->'07 SV650S (Current) |
| dibs |
 dibs Derestricted Danger
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 21:50 - 29 Apr 2007 Post subject: |
Had the same problem myself,hence trying everything I could think of to solve without giving in to the theory of a fried clutch.
Two things I did which certainly made a difference to me (I was also having problems selecting gears) were to take off the left hand footrest assembly and give it a good clean and lubrication (the gear lever was too stiff and was stopping the returner in the cluch doing its job correctly) and also adjusted the tension on the cable (between the clutch and the lever connecting to the actual clutch cable).
These seem to have sorted my problems.my slip was noticable at only 10k revs. ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| CaPo |
 CaPo Scooby Slapper
| dibs |
| Kwaks |
| R1stu |
 R1stu Shrek!
 Posted: 14:17 - 30 Apr 2007 Post subject: |
That steel don't look too bad from what I can see. If it's slipping but not turning the whole steel blue then I would suspect the oil as above. The proper thing to do is to either measure your clutch stack-height (all the steels and fibers stacked together) and check against the manual or measure each steel and fiber individually to check they are within wear-tolerance. If it's got very hot the steels can warp causing slip and/or judder. ____________________ a.k.a 'Geri'
| R1stu |
 R1stu Shrek!
 Posted: 17:15 - 30 Apr 2007 Post subject: |
If there was no oil in the gearbox then there was no oil in the engine and it would have seized had you run it. ____________________ a.k.a 'Geri'
| paulmuphesto |
 paulmuphesto L Plate Warrior
 Posted: 14:15 - 01 May 2007 Post subject: |
hey this thread was started for my bike. i joined up to post some advances.
so i swapped the oil today. changed the old magnetec stuff for this: https://www.castrol.com/castrol/productdetailmin.do?categoryId=9003128&contentId=6008623
took the bike out for a spin and it seemed to be working perfect straight away (better than before with other oil actually). So the longer i had it out, the more i was revving it up high in lower gears to see if any slipping occurd. Seemed to be fine straight away, but after about 3-5 minutes i noticed it starting to slip again. Could it be that the friction plates etc will need time to soak in the new oil and get the magnatect stuff off of it? or perhaps the clutch is actually buggered. I tryed to get the side casing off to measure the plates but the thing was stuff on solid
also, when i took out the old oil : there was no metal fragments or anything similar, no smell of petrol, infact it didnt even look "that" used.
is it still ok the use the bike at low revs or will this cause the problem to get worse?
thanks in advance |
| R1stu |
 R1stu Shrek!
 Posted: 18:35 - 01 May 2007 Post subject: |
The clutch isn't usually running in oil it's pumped-in via the pushrod tunnel. I don't know if it's true for your bike but it's the favourite method. ____________________ a.k.a 'Geri'
| paulmuphesto |
| paulmuphesto |
 Posted: 12:08 - 02 May 2007 Post subject: |
so heres another update.
after leaving the bike with the new non-magnetic oil in it for well over 24 hours i took it out for a shot.
Again, starts up perfect, didnt even need choke. Very easy to select all gears (apart from neutral, but thats always been difficult). Bike starts off great, revs no probs, gets up to a high speed pretty fast, feels perfect actually. This lasts for anywhere between 3-7 minutes then uh oh.....the problem returns. oh and i couldnt get it above 60mph in 6th gear without the engine revving up without producing the power to the wheel
the clutch level is adjusted properlly, new oil in it just a fraction under full level.
you think its time to open up the clutch and starting measuring plates and what not? |
| paulmuphesto |
 Posted: 15:51 - 03 May 2007 Post subject: |
so i took the clutch apart today. the plates were all just under 3mm but over 2.8mm. Ive ordered new ones anyways. Also the springs were about 10-15mm short of what they should have been.
Hopefully this is the problem and when i put in new springs and plates it will be sorted  |
 Posted: 18:35 - 03 May 2007 Post subject: |
10-15mm short? I never heard of anyhting like that before. ____________________ a.k.a 'Geri'
| CaPo |
 CaPo Scooby Slapper
 Posted: 18:38 - 03 May 2007 Post subject: |
Its true, the haynes manual says they should be 60mm, we measured them all at about 48mm  |
| bish777 |
 bish777 World Chat Champion
The last post was made 19 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
