Which soldering iron to buy?
Yoshi
PostPosted: 15:56 - 29 Apr 2007    Post subject: Which soldering iron to buy? Reply with quote
I want to solder connections on my bikes, especially on the TS250 I'm currently stripping (the wiring is a total mess on it, I couldn't believe my eyes when I took all the tape covering the coil off, some muppet had screwed a big ole screw in there to replace the original connector Shocked )
I have no experience with soldering at all so not sure what to look for in the equipment. I don't want to spend alot, hopefully one of the cheap ones on ebay will do?
I'll be using it to solder wires onto components, connecting wires and maybe to have a go at plastic welding at some point. Not going to be heavily used.
I've seen these on ebay:
https://cgi.ebay.co.uk/Soldering-iron-20W-130W-boost-Ceramic-element-Solder_W0QQitemZ180111370510QQihZ008QQcategoryZ106001QQrdZ1QQcmdZViewItem
https://cgi.ebay.co.uk/40w-Soldering-Iron-Tip-Set-20-gram-Solder-Combi-Kit_W0QQitemZ290109228550QQihZ019QQcategoryZ106001QQrdZ1QQcmdZViewItem
https://cgi.ebay.co.uk/ELECTRIC-SOLDERING-KIT-iron-gun-solder-INCL-VAT_W0QQitemZ160109476964QQihZ006QQcategoryZ106001QQrdZ1QQcmdZViewItem
I like the look of the middle one, seems to be what I need? Silverline so lifetime warranty too. Don't think I need all the stuff in the big set?
Thanks,
Matt
Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250
evilknievel
PostPosted: 16:22 - 29 Apr 2007    Post subject: Reply with quote
i think you well find the middle one could be too hot fot what you want it for! but if you do get it dont take too long soldering as you can over heat the electrical stuff you trying to fix. and soldering is not as easy as it looks best thing to do is find a old radio you dont want and practice soldering on that first till you got the hang of it
T1z3R
PostPosted: 16:25 - 29 Apr 2007    Post subject: Reply with quote
get a £15 one from maplin. itll do what you need.
duck my sick!
Yoshi
PostPosted: 19:10 - 29 Apr 2007    Post subject: Reply with quote
Aha but is a £15 one going to be the same thing as an £8 one from ebay, exept for a bit of mark up due to the fact that maplin's selling it not some muppet on ebay?
I've taken on board the fact about the middle one being too hot. That's a 40w, the one above is 20w, will this be ok?
How hot/wattage does it need for plastic welding?
Thanks,
Matt
Yoshi
PostPosted: 19:13 - 29 Apr 2007    Post subject: Reply with quote
Oh and also what kind of solder do I need for electrical work. Some state they come with solder for electrical work, but the top one doesnt, so what kind does it need to be? Or does it not matter?
Thanks,
Matt
truslack
PostPosted: 19:35 - 29 Apr 2007    Post subject: Reply with quote
it depends on the grade of the wire, but look out for solder with a flux core.
The 40w will heat up faster than the 20w, not sure if it will get much hotter though.
Soldering guns are less precice for soldering wire, theyre mainly used for plubming solder (i think), but they heat up instantly.
T1z3R
PostPosted: 19:54 - 29 Apr 2007    Post subject: Reply with quote
try sending it back to a guy on ebay when it breaks.
i use 60/40 multicore for just about every job i do.
duck my sick!
cestrian
PostPosted: 20:44 - 29 Apr 2007    Post subject: Reply with quote
I do alot of soldeing. I bought an Iroda gas soldering iron from Maplin. On its lowest setting it is just perfect for thin wiring, it is also capable of heating up starter motor cables too. No wires either (obviously).
Yoshi
PostPosted: 21:06 - 29 Apr 2007    Post subject: Reply with quote
How much did that cost cestrian?
I can see soldering as something I might get into and do quite a bit of so maybe a good idea to buy a decent one now.
PostPosted: 21:38 - 29 Apr 2007    Post subject: Reply with quote
I'd personally go for the higher wattage. I tend to find that with a cooler iron, you have to hold it against the contact for longer to get it hot enough to take the solder. The longer it's on, the more chance you have of melting the insulation on the wire.
A good hot one will heat it up quicker and tends to just heat the bit you want, you can also use it to put nipples onto control cables if you feel inclined.
I prefer using one with a flat bit on it (a little like a screwdriver blade) rather than a pointed bit for vehicle wiring. You can get more surface area of the bit in contact with the metal you're soldering which again makes things quicker.
vfr800
PostPosted: 21:48 - 29 Apr 2007    Post subject: Reply with quote
I bought a gas powered iron from B&Q last week, It's fook'n great.
Bernzomatic is the make, came with three different tips and is heat adjustable, it also included solder.
The heat ranges from 400 to 3000 degrees, you can use it as a small blowtorch which is great for heat shrink tube.
It cost 15 sob's, in my book that's great value for something thats so versatile. Thumbs Up
No need to get the extension lead out either!
don't take it easy 'ride it like you stole it'
The last post was made 18 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 68.51 Kb
