Kawasaki GT550
FreshAL
Sir Crashalot
PostPosted: 11:11 - 30 Apr 2007    Post subject: Kawasaki GT550 Reply with quote
Hi,
I've just got a 1994 GT550 (Thanks Tatters!) It's a cheap hack for commuting, and to learn some basic maintenance stuff on.
I can't find a Haynes for post '91 GT's - did they make one? If not, is the Hanyes for Kawasaki Air cooled 4's any use?
I suspect I'm going to have a fair few questions, so thanks in advance.
First job is the exhaust gaskets - is it as simple as undo exhaust header bolts, replace gaskets, put exhaust back on? Anything else I should do at the same time, anything to watch out for?
Karma
Paddy Blake
PostPosted: 17:19 - 30 Apr 2007    Post subject: Reply with quote
I am nearly sure that there is no difference between the 1990 gt and
the 1994 gt.
FreshAL
Sir Crashalot
PostPosted: 17:54 - 30 Apr 2007    Post subject: Reply with quote
the 1994 gt.
Thanks, I'll grab a cheap Haynes off eBay, and play spot-the-difference Smile
Grav
PostPosted: 21:29 - 30 Apr 2007    Post subject: Reply with quote
Try to get a factory manual if you can, they are a lot better than Haynes destroy it yourself manuals.
The GT 550 didn't change an awful lot throughout its production life and is a good workhorse.
The exhaust gaskets is as simple as that mate.
Change the oil and filter every 3,000 and it will literally go forever.
bish777
PostPosted: 20:27 - 03 May 2007    Post subject: Reply with quote
Later model GT550s share the motor with the zephyr 550, so the motor is a little different, other than that they are the same.
GSXR1100J
There is a gap of 2 years, 67 days between these two posts...
conan
PostPosted: 13:26 - 09 Jul 2009    Post subject: 1989 Gt 550 Reply with quote
Im buying one tonight.Wont tick over properly but drives fine.Adjust idle screw when first started and its ok but drive it for a while and put in neutral the revs are high.Think it could be the manifold intake boots.Are they hard to get (aftermarket,which would work new or secondhand.It also needs petrol cap and key can tou get aftermarket ones.Conan
conan
PostPosted: 21:51 - 16 Jul 2009    Post subject: gt 550 Reply with quote
Bought the 1989 gt 550 hit large pothole and baffel in one side of exhaust came loose can this be fixed.Drill out the rivets an end of can to get to baffel.Also can shocks be repaired press on back of bike and thery are slow to come back up.Conan
Grav
PostPosted: 23:04 - 16 Jul 2009    Post subject: Reply with quote
Are they the standard rear shocks? If so put some air in them and don't put more than 40 psi in.
Dark Lord Of Custard
snigger..... Very Happy
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 53.96 Kb
