VFR400 NC30 Ideas
kingnathski88
PostPosted: 12:53 - 29 Apr 2007    Post subject: VFR400 NC30 Ideas Reply with quote
Hi all, I was thinking as I finish my A-Levels soon I want to start messing about my my bike and maybe get another one.
First off I came accross a 'Honda VFR400 NC30 HRC Ram Air Tray' and wandered whther this would be worthwhile putting on my bike? The link is https://cgi.ebay.co.uk/Honda-VFR400-NC30-HRC-Ram-Air-Tray-RVF400-NC35-VFR_W0QQitemZ200101805843QQihZ010QQcategoryZ10460QQrdZ1QQcmdZViewItem
Gazdaman
I did a trackday!!!
PostPosted: 15:46 - 29 Apr 2007    Post subject: Reply with quote
Think you've got some competition from this forum for the bidding...
In a race situation where every 0.5bhp is vital then yes, that would be a good idea. If you're just looking to tart up a road bike then I wouldn't waste your money.
It's unlikely to make enough difference to warrant the amount of money it'll most likely sell for.
Anything with the initials HRC are instantly expensive.
Consider stripping it down and giving it a damn good clean, see Craig's project thread in the show and tell forum for ideas. Maybe get the suspension sorted for your weight, that's a worthwhile project.
Gaz
Cillit-BANG
PostPosted: 16:59 - 29 Apr 2007    Post subject: Reply with quote
I'm with Gaz.
The main performance problems with the NC30 is getting the suspension sorted for UK sized people. This is likely to be far more beneficial than the HRC Scoop.
Don't get me wrong it's a great piece of kit, but it opens up a whole new can of worms. Really it needs using in conjuction with race pipes, open air-boxes, much larger main jets...... It will also go for silly money.
craigs23
Mr Muscle
PostPosted: 07:26 - 30 Apr 2007    Post subject: Reply with quote
..and a lot of dyno time to sort the hole in the midrange such an airbox produces.
Get your suspenders first, easily worth 10bhp.
andrew
Mister Road Rage
PostPosted: 15:04 - 30 Apr 2007    Post subject: Reply with quote
yeah ha ha deano won that for a bargain.
andrew
Mister Road Rage
PostPosted: 09:00 - 01 May 2007    Post subject: Reply with quote
Dean posted that by the way. Very Happy
kingnathski88
PostPosted: 14:26 - 01 May 2007    Post subject: Reply with quote
Thanks very much for your reply, muich appreciated it. Suspension? I am really not that hands on but willing to give things ago.
Also, are there any larger capacity engines from other models of bikes that you know of, that would fit into an NC30 frame?
Gazdaman
I did a trackday!!!
PostPosted: 14:47 - 01 May 2007    Post subject: Reply with quote
You're not hands on enough to change your suspension but you're willing to try and shoehorn in a bigger engine?
Get your priorities right, and walk before you run.
Get a haynes manual and have a read. The short answer with the engine is no.
The less-short answer is yes, anything is possible depending how much work/money you're willing to throw at it.
Gaz
kingnathski88
PostPosted: 14:52 - 01 May 2007    Post subject: Reply with quote
I wasn't saying I was gunna do it myself. Me and a mate also riding a VFR was thinking about it as a project on the side. The only problem on mine is i use it every day so i cant afford to mess up.
andrew
Mister Road Rage
PostPosted: 16:47 - 01 May 2007    Post subject: Reply with quote
It's a silly idea. The best you can do is fit a big bore kit but unless you do it properly and get everything set up to perfection then you'll end up with reliability problems.
I'd recommend leaving it as is and upgrading when you can.
kingnathski88
PostPosted: 14:34 - 04 May 2007    Post subject: Reply with quote
Ok thanks for your view. It was merely something for us to do over the summer to keep us busy. I checked the manual. As i have the 89' VFR I cant change the front forks suspension apparently. And there is very little info regarding changing the rear shock in the book. Can anyone shed some light?
Thanks, Nathan.
The last post was made 19 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 66.49 Kb
