| CortezTheKill... |
 CortezTheKill... Could Be A Chat Bot
| numpty |
 numpty Scooby Slapper
| pwntifex |
 pwntifex World Chat Champion
| phk6 |
 phk6 Nearly there...
| CortezTheKill... |
| phk6 |
| mrtEE |
 mrtEE World Chat Champion
| G |
 G The Voice of Reason
| CortezTheKill... |
| phk6 |
| phk6 |
 Posted: 22:05 - 02 May 2007 Post subject: |
fair enough lol, can i have one so i can track it?
swap for a cb500 heh  ____________________ Current .. 2008 BMW R 1200 GS Adventure ..
Before .. 2003 Yamaha Fazer 1000 .. 2004 Kawazaki Z1000 .. 2003 Suzuki Sv1000s .. 1999 zx6r Track Bike .. 1999 CB 500 Cup ..
/Phil |
| st3v3 |
 st3v3 Super Spammer
 Posted: 22:24 - 02 May 2007 Post subject: |
cortez, we (in general) can only learn through practice and experience.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
 Posted: 00:26 - 03 May 2007 Post subject: |
If you're bricking your pants, you are exceeding your own abilities. If you don't feel in control, push it no further. Back it off a little, think 'smooth' and you'll find you are actually going faster still without the sensation of 'pushing'.
I'd owned a GPZ500 for six years before I felt I was actually trying to push the bike itself harder through corners that it was capable of doing. Clues include being unable to change up a gear because there is insufficient ground clearance between the road and the gear lever, repeatedly decking bits of the bike out and squirming of the rear tyre.
If you feel the back-end starting to break away and don't get a sinking feeling in your stomach, it's probably time to upgrade your bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rookie |
 Rookie World Chat Champion
 Posted: 00:54 - 03 May 2007 Post subject: |
As far as cornering goes, I look at my chicken strips. I've gone from a 1cm chicken strip on my rear tyre to a 1-2mm strip. So I know I'm getting closer to the traction limit, but I'm not there yet. Once I have no chicken strips I'll know I've reached the bikes limit, right? If I'm using all the available tyre surface area, then there's no more grip to use. The difficult bit is figuring out when I'm reaching the bike's traction limit, and when I'm not. My right hand strip is a bit smaller than my left one. So I can assume my right hand cornering is better than my left, but more importantly roundabouts are right handed. So I'm getting the most out of the bike on roundabouts, but not on left handed turns, because turns are harder to negotiate than roundabouts, and there are no left handed roundabouts.
If I feel I've gone as far as I can go on a LH turn (and I've done that many a time) and get home and find my chicken strip on the LH side is still 2-3mm, I know it's a mental block. If there's no chicken strip, I know I've reached the limits of the corner.
Am I wrong? It just seems to me that chicken strips are the easiest way of knowing whether you're pushing your bike to the limit or not. Of course, other factors like suspension and tyre pressures can affect this, so I suppose the question is; do chicken strips measure accurately the limit of your bike in it's current setup? |
| TheDonUK |
 TheDonUK World Chat Champion
| Itchy |
 Itchy Super Spammer
 ..... Quote Me Happy
 Posted: 07:05 - 03 May 2007 Post subject: |
Get it on the track. I've pushed mine 10x harder on the track than I ever have on the road and it's taken it in it's stride.
It has its wobbles etc but as long as you do everything smoothly then it should give you enough warning to think 'Hang on.... that means x y and z'. If you start giving it handfuls of gas and brake then the first warning will be when you're either 6 feet in the air or sliding along the floor.
Slowly slowly catchy monkey  |
| DEN MONKEY |
 DEN MONKEY World Chat Champion
 Posted: 07:15 - 03 May 2007 Post subject: |
Every time you get onto the bike you are going to have different limits.
That is with every extra mile you clock up your limits will be extended if ever so slightly.
The only way to know where your limits are is to ask yourself questions just like this one and be completely honest with yourself in your reply.
Because if you aren't......... well you know what might happen.
When I first started I found a corner which was on a normal run to work and just kept a mental note of my ability to take the corner and at which speed I was doing it every week or so.
Without even making a concerted effort I realised that I was now taking the corner well above the posted speed if I wanted.
Where only not so many weeks ago I was responsible for holding cars up wanting to do the speed limit.
It does wonders for your confidence to be able to recognise improvements when they happen, no matter how small.
Better is better
If you can find something like this, you can have a good measure for how your riding and confidence are building and what you find you can handle.
Now while knee down ball draggin corners might look great and impress the mates dont forget that something else that will issue you with greater confidence is finding yours and the bikes limits when performing emergency breaking.
What I'm saying there is that there are so many areas of develpment in your riding career, that you should try and be a well rounded rider rather than a focused riding type/styled one.
As for being depressed about how far you had to go...are you mad I found that time to be most rewarding.
You're learning something new and gaining new knowledge and experience.
Take your time, learn well and enjoy the journey.... ____________________ meh |
The last post was made 18 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
