back bleeding
shleppy
PostPosted: 12:14 - 03 May 2007    Post subject: back bleeding Reply with quote
can someone explain, maybe with the aid of diagrams or pictures how to back bleed my brakes. as i hear is meant to give better results and also easier to do by yourself.
Ichy
PostPosted: 12:19 - 03 May 2007    Post subject: Reply with quote
Type 'brake bleeding bike' into google and, as if by magic, this and many more appear Wink
https://www.h-e-l.co.uk/HEL_Performance_Motorcycle_Brake_Lines_Brake_Doctor_Brake_Bleeding.htm
shleppy
PostPosted: 17:51 - 03 May 2007    Post subject: Reply with quote
ty itchy i had a little look, but nothing on page 1, and couldnt be arsed to look therough the rest, especially as already stumbled upon one about anal bleeding. Shocked
shleppy
PostPosted: 18:01 - 03 May 2007    Post subject: Reply with quote
tbh thank you, but i was refering to back bleeding, this doesnt really explain how to do that.
PostPosted: 18:14 - 03 May 2007    Post subject: Re: back bleeding Reply with quote
If at first you don't succeed, give up and ask someone else to find it for for you change your search terms.
Personally, I just use a syringe, nut there's plenty of different ways. In some cases you have to loosen the banjo bolt to the master cylinder and bleed it to there.
PostPosted: 19:37 - 03 May 2007    Post subject: Reply with quote
You're exactly like your brother, only worse. Impatient, and always looks on the downside.
He'd have at least looked a couple of pages further on though! Wink
timjim
PostPosted: 20:57 - 03 May 2007    Post subject: back bleeding Reply with quote
means bleeding the system by its lowest point,normally caliper.Buy a syringe or cheap oil can,fill with brake fluid,fit tube on bleed nipple,open it,take reservoir cap off,slowly squeeze syring/oil can watching for air bubbles in reservoir.when bubbles gone leave for 5 mins,tighten bleed screw and that SHOULD solve crap brake problems.Tim
Ichy
PostPosted: 21:05 - 03 May 2007    Post subject: Reply with quote
Sorry mate I actually thought you had spelt it wrong Laughing
I prefer to use the end off a spray gun, you know the type they use for spraying water on plants? I fit the end of the pipe on to the bleed nipple and pump away. it sucks the fluid through in no time. Works really well on empty systems which can be a pain in the neck to get fluid through.
The last post was made 19 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.24 - MySQL Queries: 13 - Page Size: 56.6 Kb
