stripped a tank, found a hole, what to do?
shleppy
PostPosted: 18:02 - 03 May 2007    Post subject: stripped a tank, found a hole, what to do? Reply with quote
was stripping an rxs100 tank i bought for £1 off ebay, so that i can keep my little rxs100 running and change over the tank for a nice smooth, undented shiney tank. so i bought this fuel tank and stripped it down to the metal, patiently taking up all the filler, god there was alot of filler - an of course dents.
got through it all and there were two little holes probably from rust poking through near where the fuel tape connects. is there anything i can do to fill them, i have no idea how to weld unless u count my soldering-iron Wink.
Any fillers designed for this? or is it a simple weld if i could borrow the equipment?
i enclose pictures of the tank:
shleppy
PostPosted: 18:04 - 03 May 2007    Post subject: Reply with quote
theres a fair bit of rust on the bottom too, im gonna wet and dry as much off as possible and with the aid of a trust wire brush i should be able to get a fair bit off. i laso plan to give it the we-40 treatment but is there anything else i should do; hamerite the bottom?
PostPosted: 18:17 - 03 May 2007    Post subject: Reply with quote
You may be able to get it welded, but will have to get someone else to do it.
WD40 treatment? eh?
Is this inside or outside the tank?
bish777
PostPosted: 20:03 - 03 May 2007    Post subject: Reply with quote
Id use a drill with a wire cup to get the rust off otherwise youll be there for all eternity!
You could repair the tank with petro patch or JB weld.
https://cgi.ebay.co.uk/GRANVILLE-PETRO-PATCH-REPAIR-PETROL-TANK_W0QQitemZ320108505330QQcmdZViewItem
GSXR1100J
The last post was made 19 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 39.83 Kb
