flat tyre
mikeoldcars
PostPosted: 20:07 - 03 May 2007    Post subject: flat tyre Reply with quote
this morning i noticed my tyre was nearly flat so i pumped it up, the valve was leaking air so i tightened the valve put a bit of spit on it no bubbles tyre pressure ok so jobs a good un or so i thought.
came out of work and the tyre was almost flat again so pumped it up again and rode the ten minute journey home checked the pressure when i got home and it was almost flat again.
Ive changed the inner bit that screws into the valve and noticed that when i was putting the pump onto the valve where the valve moves slightly the hiss of the escaping air was getting louder and quieter, ive hqad to screw the inner bit of the valve right in to try and stop the leak but now i cant get a reading on my guage.
at a guess id say the innertube is buggered where its joined to the valve.
ive got the wheel off and am taking it to the bike shop tommorow
any ideas if it the valve, innertube or both?
jimbothe
PostPosted: 12:41 - 04 May 2007    Post subject: Reply with quote
If it has an innertube then the valve will be attached to it otherwise it will never hold air.
My guess is the bike shop will just change the innertube and all should be ok. Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
mikeoldcars
PostPosted: 17:29 - 04 May 2007    Post subject: Reply with quote
spot on, thats what the bike shop said they would do its cheaper to fit a new inner tube than patch the old one, should be fun refitting everything
jimbothe
PostPosted: 18:23 - 04 May 2007    Post subject: Reply with quote
Cool
Im sure you will have no problems Thumbs Up
The last post was made 19 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 40.1 Kb
