Speedfight 2 50cc repairs
bornlucky
PostPosted: 20:44 - 03 May 2007    Post subject: Speedfight 2 50cc repairs Reply with quote
Hello guys & gals, joined the site yesterday and had a good read of all on offer. I've been trying to get my scooter back on the road after a year or more in storage, managed to sort out a lot of the mechanical stuff but I can't get it to start.
The starter ticks over, fuel is getting to the spark plug but it ain't sparking. With the aid of the trusty haynes manual I've found that the spark plug cap had given up so I've replaced it.
I'm going to have to replace the ht coil as a friend has accidentally removed the cable out of the end that should not be removed!
When I turn the key nothing happens on the dash instruments, but the starter will turn, the horn works and so do the indicators, haven't tested the lights yet as the bike is in pieces, some easier to reach than others!
I'm concerned that it could be the immobiliser as that seems to be a common fault and I don't have the master key.. the red key I have is for the boa lock attached to the bike.
Is there any way I can test the immobiliser, or is it something more obvious, especially as the instruments are not working?
Forgot to mention too, since it's been de-restricted the speedo cable has spilt apart and wrapped itself neatly into the connection near the front wheel, I was thinking of drilling it out, unless anyone knows a better way?
numpty
PostPosted: 23:24 - 03 May 2007    Post subject: Reply with quote
try changing all the fuses. Probably wont work but its just an idea Smile
Current bike: CBR600F-Y
bornlucky
PostPosted: 09:40 - 04 May 2007    Post subject: Reply with quote
Thanks for the reply, I checked the main fuse and it seems to be in one piece, wasn't aware of any specific fuses for the dash though..
Ok just checked the circuit diagram and there is only one fuse, I'll check it over later..
The last post was made 19 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 35.86 Kb
