gpz500s steering problems
duncanpage
PostPosted: 12:27 - 04 May 2007    Post subject: gpz500s steering problems Reply with quote
I was enjoying my ride home from work today and as I took my hands off my handlebars to open the vents on the back of my helmet I noticed the handlebars started wobbling, gently at first but then building up in speed until I got scared & put my hands on the bars again, I thought it would develop into a full tank slapper!
I tried it again a few times on the journey, different levels of road quality but none particularly bumpy, just normal roads through Harrow. Each time I'd release my grip on the bars but left my hands next to them and each time it would gradually build into a wobble. What is wrong with my steering/wheel/handlebars/yoke? Any ideas? I had 2 new tires fitted about 1500 miles ago so i assume they balanced the wheels when they fitted them.
I'm wondering if this has something to do with why I was aching so much after my 90mile journey to Seaford having to cope with all the vibration and wobbling on the motorway!
PostPosted: 12:34 - 04 May 2007    Post subject: Reply with quote
What sort of tyres?
Check the head bearings aren't loose.
jimbothe
PostPosted: 12:36 - 04 May 2007    Post subject: Reply with quote
I would have said tyres but if they were new only 1500 miles ago im not so sure.Are they a good make tyre? You could also take it back to the garage where you had them fitted and say it's not right and wobbles now and they should re balance it free of charge.
Do you have a box on the back? I found with my fj when i had a givi rack on it did what you were describing so i took it off.
Other possibility could be worn forks if it's a high-ish miler
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
0ddball
PostPosted: 12:38 - 04 May 2007    Post subject: Reply with quote
The usual cause is a worn (not necessarily illegal) front tyre, head bearings or low tyre pressure.
You seem to have covered the tyre angle so i'd guess head bearings. If you stick it on the centre stand, when you turn the bars can you feel a very slight notch as the steering passes through the stright ahead position?
ZXR750L
PostPosted: 12:40 - 04 May 2007    Post subject: Reply with quote
We haven't covered the tyre angle. GPZ500s are very fussy about tyre brand and model. Put the wrong ones on (eg contis) and it'll handle like a shopping trolley.
jimbothe
PostPosted: 12:42 - 04 May 2007    Post subject: Reply with quote
I had avons on my 500s and they seemed to work well
PostPosted: 20:48 - 04 May 2007    Post subject: Reply with quote
Can be a fun way of scaring people coming the other way Laughing .
As well as the above, check the wheel bearings, and also for play in the rear suspension linkages.
duncanpage
PostPosted: 19:59 - 05 May 2007    Post subject: Reply with quote
Hi all.
I checked the tire pressures & they're perfect. I tried to have a look at the bearings but when I took hold of the front forks I got oil on my hands, I realised there's quite a weep on the front forks...is this the cause of my problem?!
I was thinking about replacing the front fork springs with Hagon progressive springs & some decent fork oil, obviously I'll have to replace the seals too. Will this improve the ride over the standard springs or is it worth me just getting the standard springs? I regularly have my wife on the back as its our only form of transport if that will make a difference to the recommended springs.
I also need to replace my sprockets & chain as the teeth on the inside of the front sprocket have worn so it wobbles! Looks like it'll be an expensive month for me! Sad
PostPosted: 20:42 - 05 May 2007    Post subject: Reply with quote
Yes, worn/leaky for seals wouldn't help matters.
The progressive springs are good Thumbs Up.
Do you mean the central hole of the front sprocket that slides over the splined shaft? A certain amount of play is normal in that, especially back and forth along the shaft. I've also found that the thrust washer is fairly prone to wearing but as long as it can't come off the splines, you should be ok. There shouldn't be much by way of sideways play as you rotate the sprocket round the shaft
The last post was made 19 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 62 Kb
