push start
kwellsqpr1
PostPosted: 23:57 - 04 May 2007    Post subject: push start Reply with quote
does push starting my bike damage anything at all if i do it much?
keeping it rubber side down
Ariel Badger
PostPosted: 00:01 - 05 May 2007    Post subject: Reply with quote
only if it runs away from you when it fires up.
I have been bumping my black bike for years.
mr.z
PostPosted: 00:05 - 05 May 2007    Post subject: Reply with quote
Only automatics will be damaged afaik (scooters pretty much)
All a starter does is push the engine arround with a strong electric motor, as does a kick starter, so rolling it down a hill or bumping it will be putting less wear on the bike starter and battery for that matter..
kwellsqpr1
PostPosted: 00:11 - 05 May 2007    Post subject: Reply with quote
thats good:D. how can you push start an automatic scooter? my m8 tried loadsa technics because his wouldnt start with kick or electric 1 day . prbably flooded
PostPosted: 00:15 - 05 May 2007    Post subject: Reply with quote
Not sure you can push start most scooters. They work with a centrefugal clutch, so require the input to the clutch to be spinning for the clutch to engage and transmit drive. Engine not running means no clutch engagement.
mr.z
PostPosted: 00:17 - 05 May 2007    Post subject: Reply with quote
Quite sure they can't be, trying isn't going to do it any good, you really need a clutch to be able to push it upto a decent speed and let it out for it to engage..
If its flooded you can drain the carb, but best not to in the first place, give it a rest for 10minutes and try again often works..
edit: that makes more sense Laughing
Nath
PostPosted: 04:26 - 05 May 2007    Post subject: Reply with quote
Have bump started my Honda Bros everyday for 7months going to and from work. It's a very effective way of starting a bike, and I far prefer it to using an electric starting motor.
Hard livin', hard luck.
Finglonga
PostPosted: 12:16 - 05 May 2007    Post subject: Reply with quote
Your right! Mr. Green Its not the carb that gets flooded its too much fuel in the barrel and not enough oxygen (crude description). So draining the carb will only . . . . er . . drain the carb. Laughing
Andy Sez....
F.Y.Y.F.F.
LeeR
PostPosted: 12:29 - 05 May 2007    Post subject: Reply with quote
If you have a newer bike with a CAT then you really don't want to bump/push start your bike as unburnt fuel gets into the CAT and ruins it.
My claim to fame: Austin Vince nicked my pen...
Finglonga
PostPosted: 12:45 - 05 May 2007    Post subject: Reply with quote
Harder to start on them as they are all injection and thus need a fuel pump and thus need power to power up said fuel pump and injectors.
Don't matter anyway as bikes emmisions aren't checked on MOT's so wouldn't matter. Wink
Andy Sez....
F.Y.Y.F.F.
LeeR
PostPosted: 12:48 - 05 May 2007    Post subject: Reply with quote
Insightful that I didn't realise, though my previous bike a Suzuki Van Van had a CAT and a carb. Karma Thumbs Up
The last post was made 19 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 70.63 Kb
