| c-m |
 c-m World Chat Champion
 Posted: 13:07 - 13 Mar 2007 Post subject: Bloody thing won't start again |
Kind of a continuation of my previous thread, but its about a different topic. I have a KH125, after taking it on a 40mile ride yesterday the bloody thing now won't start.
After it woun't start yesterday morning, I took out the battery, moved the fuel tap to 9 o'clock and kicked it a few times and it started. I then put the battery back in and took it for a ride, where it started first kick every time.
When I finished with it last night I turned on the engine cutt off switcha and shut off the fuel. Yet this morning after turning everything back on, the thing won't start again and smells slightly of petrol.
Any ideas? ____________________ Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/ |
| cokker |
 cokker Spanner Monkey
| c-m |
 Posted: 13:48 - 13 Mar 2007 Post subject: |
It could be,
So if I turn the fuel off and kick the hell out it, will that clear it? I didn't use any choke or anything to try and start it this morning, but it just wouldn't start, surely it wasn't flooded then?
I hope the engine cutt off switch isn't faulty. I turned it off last night. Though the switch seemed to work ok yesterday. ____________________ Motorcycle headlight bulbs and HIDs
| cokker |
| c-m |
| Gazdaman |
 Gazdaman I did a trackday!!!
| c-m |
 Posted: 16:37 - 13 Mar 2007 Post subject: |
Tired to bump start it the other day, problem is sometimes without it actually on and running you can only select between 1st gear or neutral.
I turned the fuel off and kicked it some more, then turned the fuel back on and kicked it somemore, and eventually it started.
I rode somewhere left it for 30mins came back and it almost didn't start.
When I am leaving the bike for hours, should I turn the fuel off, or just leave everything as it is/was? ____________________ Motorcycle headlight bulbs and HIDs
| Blau Zedong |
 Blau Zedong Banned
| Gazdaman |
| Vincent |
 Vincent Banned
 Posted: 17:26 - 13 Mar 2007 Post subject: |
Our kid had a KH125, used it for his test last year and it was a great starter. Used choke when cold just to start it, no more. Maybe it's time for a new spark plug What does yours look like Do you have any pics of it? Whatever's wrong, I doubt it will be an expensive fix. If it was starting ok until you used the kill switch then that might be your problem, I'd try a new plug first. |
| c-m |
| Finglonga |
 Finglonga World Chat Champion
| iooi |
 iooi Super Spammer
| bish777 |
 bish777 World Chat Champion
| Vincent |
 Vincent Banned
| c-m |
 Posted: 22:29 - 13 Mar 2007 Post subject: |
'86-'98,K4-K7/K9-K10.........NGK BR8ES mines the 96 K-9
Thanks for all the advice guys.
I took the thing to training and left the hall 5mins early so everyone didn't take the piss when I couldn't start the thing. Took about 8-10 kicks and started. I think I'm getting the hang of it.
oh by the way I don't have a manual, thats part of the problem. ____________________ Motorcycle headlight bulbs and HIDs
| Vincent |
 Vincent Banned
 Posted: 22:49 - 13 Mar 2007 Post subject: |
Yep anything longer than half an hour, I'd try starting with the choke. If I remember right, there isn't a manual. It was a K9 that r kid had, a red one. Only problem he had was the end of the kickstart shaft had broken, managed to fix this tho. Otherwise it was a good bike, 6 gears aswell - bonus. Good luck with the training and keep an eye on your 2-stroke oil level  |
| c-m |
 Posted: 21:16 - 05 May 2007 Post subject: |
hmm been using techniques in this thread fine,
But recently the bike has been taking at least 6 kicks to get it going. The idle revs are also very low and it sometimes cutts out at junctions, leaving me looking like a fool.
I have tried adjusting the screw on the carb to increase the idle revs, but it doesn't seem to do a single thing. ____________________ Motorcycle headlight bulbs and HIDs
| Timmeh |
 Timmeh World Chat Champion
The last post was made 19 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
