Bike's been resting for a while, what should i do?
bob-a-job
PostPosted: 01:09 - 08 May 2007    Post subject: Bike's been resting for a while, what should i do? Reply with quote
My CBR 600 F has been sitting in a garage for a few months, since january. I am about to bring her out again and was wondering what you guys suggest doing to make sure she is all good to ride again...
MaybeGuy
PostPosted: 01:14 - 08 May 2007    Post subject: Reply with quote
oil change and fuel i'd say.
maybe pour a little oil in each cylinder, turn the engine slowly via the alternator flywheel, and thats about it!
hmmmnz
PostPosted: 09:44 - 08 May 2007    Post subject: Reply with quote
oil should be still ok, but still worth doing for a new season of riding.
drain all the fuel. and empty the float bowls, refill and fire it up.
you may need to charge the battery as well.
check the battery levels as well Thumbs Up
the humans are dead
I kick arse for the lord
Check you tyre pressures, also check said tyres for flat spots(assuming you haven't used paddock stands), if the bike has been sat in the same position for more than 2 weeks the tyres start to develop flat spots and are out of round.
Check and lube or chain.
Change oil and fuel. Hope you drained the carbs or they will be gummed up.
Check your brake fluid.
If you have a haynes manual it's all in there tbh.
Finglonga
PostPosted: 11:06 - 08 May 2007    Post subject: Reply with quote
Just Tyre pressures as said, if an alarm is fitted battery might need a boost. Fuel will be ok its only been just over 4months, it wont go off in that short time.
Andy Sez....
F.Y.Y.F.F.
Bendy
Mrs Sensible
PostPosted: 11:08 - 08 May 2007    Post subject: Reply with quote
Press the 'go' button, it's all I ever do.
matmanmarsh
PostPosted: 13:03 - 08 May 2007    Post subject: Reply with quote
Check battery is ok
***BRAKE FLUID*** definitely check this! Bleed brakes to see if fluid is correct colour =]
And of course all other previously mentioned checks.
Guns for show, knives for pro.
bob-a-job
PostPosted: 15:41 - 08 May 2007    Post subject: Reply with quote
Thanks guys, if only i had lots of Karma cookies free... will remember it all tho..
The last post was made 19 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.44 - MySQL Queries: 13 - Page Size: 55.92 Kb
