Rebuilding top end on NSR, help needed
bonceunounce This post is not being displayed because the poster is banned. Unhide this post / all posts.
Scotty
Scooter Boi
PostPosted: 17:42 - 19 Sep 2003    Post subject: Reply with quote
Did you download the manual.
I think theres a circlip in there somewhere stopping it coming out.
me thinks.
Regards
Scott
PostPosted: 20:03 - 19 Sep 2003    Post subject: Reply with quote
Reading the manual both rings should be marked. As I read it they are just saying not to interchange them, ie if you have installed them and used them then do a rebuild and reuse the rings make sure they go back in the same positions. The marks should face up.
The power valve is held in place with a circlip which is under the seal. The shaft will only go into the bits of the power valve inside the exhaust port in one position.
The gaps in the rings should sit over the small pins in the ring gaps (it stops them rotating round the piston), and those pins should point towards the back of the engine.
PostPosted: 20:56 - 19 Sep 2003    Post subject: Reply with quote
The seal has a long small spring as part of it. You are probably most of the way there.
PostPosted: 21:00 - 19 Sep 2003    Post subject: Reply with quote
Scottys did have a circlip , but it didn't survive being removed! Once the seal of out I think the shaft should just come out.
PostPosted: 21:20 - 19 Sep 2003    Post subject: Reply with quote
Don't think it matter whether they are up or down. Just pull firmly and carefully (be careful not to bend the shaft). Remember that the shaft and those flaps have been subject to loads of heat and exhaust gases for the past decade.
PostPosted: 22:06 - 19 Sep 2003    Post subject: Reply with quote
Take the barrel along to a local motor engineer / decent bike shop. They can probably hoik it out in 2 minutes flat.
Scotty
Scooter Boi
PostPosted: 01:12 - 20 Sep 2003    Post subject: Reply with quote
Well tis what i'll be doing!
I imagine not to bollock the bike, try keep it below 5k i imagine,
but vary the throttle every now and again i think.
Regards
Scott
Scotty
Scooter Boi
PostPosted: 12:27 - 20 Sep 2003    Post subject: Reply with quote
imagine all the trouble if it was a 4 stroke you'd be having Very Happy
Regards
Scott
PostPosted: 14:13 - 20 Sep 2003    Post subject: Reply with quote
Disconnect the cables from the servo. The turn the ignition on and allow it to reset its position.
The one with the spring goes on the right (ie front of the bike) as you said.
As far as I can make out the cable with the spring connects to the servo motor nearest the frame.
Make sure you get the cables the right way round or it will do all sorts of odd things (such as have no power). Also make sure you adjust them correctly as if the cables are too tight you stand a fair chance of burning the servo motor or its control unit out.
Hex
Party Boy
PostPosted: 10:49 - 21 Sep 2003    Post subject: Reply with quote
Been covered lots of times how to run in mate if you do a search. Basically you want to vary the revs and keep under certain limits (about 7k for so many hundred miles etc).
Normal running in period is 500 miles.
As said do a search and you should find loads on it as its been covered a lot of times before.
Hex
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
The last post was made 22 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 2.48 - MySQL Queries: 13 - Page Size: 129.49 Kb
