Honda NSR 125 RR Dies suddenly then repeats it.......
borntoride
PostPosted: 14:33 - 08 May 2007    Post subject: Honda NSR 125 RR Dies suddenly then repeats it....... Reply with quote
HI Very Happy I have just bought an NSR125 RR and was riding it back when about halfway threw the journey she started to splutter and lost power and when i tried to rev her she just died.I then after a short while got her restarted and then after a bit more riding she done the same again she done this the whole way home which was about 20 miles. Does anyone know what is wrong i have only previously ridden scooters and the guy i bought it from said it was working fine and hes no help Sad Sad can anyone suggest a remedy. Cheers all....
Minty
PostPosted: 14:35 - 08 May 2007    Post subject: Reply with quote
Fuel starvation perhaps.
The way the fuel line runs round the airbox can cause a kink - it has done to me.
Have a look.
My fingers smell of your mum.
borntoride
PostPosted: 14:49 - 08 May 2007    Post subject: Reply with quote
Cheers r1NSR for that I will have a look
0ddball
PostPosted: 15:30 - 08 May 2007    Post subject: Reply with quote
Didn't you have a test ride before you bought it?!
ZXR750L
Marci
PostPosted: 16:28 - 08 May 2007    Post subject: Reply with quote
Spark plug getting cooked? First (& cheapest) thing to try - new spark plug.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Steve - RS125
PostPosted: 16:53 - 08 May 2007    Post subject: Reply with quote
Or something as silly as leaving the choke on and flooding the engine!
(If it has a manual choke that is!) Thumbs Up
Suzuki VL Intruder 125cc - September 2004 to July 2005
Aprilia RS 125cc - July 2005 to Present
Suzuki RF600RR - May 2006 to October 2006 (RIP RF600)
demoNSR
PostPosted: 19:21 - 08 May 2007    Post subject: Reply with quote
Sounds like a slly question. But is your fuel tap turned fully clockwise? As if it is in the res. position, you may be running out of fuel in your reserve tank, and the fuel in the tank, sloshing about, may replace a little fuel each time you go round a bend, but not enough to keep the bike running smoothly.
I had done this myself once, when i first got the bike. I had forgot to turn the fuel tap back to "ON" after filling up.
Or, check for a kink in the pipe, as stated earlier. Or the fuel filter may be clogged.
Does the bike fire ok when you start it?
Timmeh
PostPosted: 21:58 - 08 May 2007    Post subject: Reply with quote
if the bike has been stood for a while there could be some water in the tank, which will also cause the symptoms you describe.
Once you've got it home, check the hoses, throw in a new sparkplug for good measure (BR8ES for about 3.99) and fill the tank up with fresh petrol.
Go out riding, just local to start with and gradually increase the range as you become confident with its reliability.
numpty
PostPosted: 22:05 - 08 May 2007    Post subject: Reply with quote
If you lift the tank up there should be a breather pipe. If this gets kinked then it can create a vacuum in the tank after a while and prevent fuel from leaving - thus starving the engine of fuel. After a while the air will seep back into the tank, releasing the vacuum and enabling the fuel to flow again. So hopefully if you un-kink the pipe then all will be good again, with no need to change spark plugs etc.
Current bike: CBR600F-Y
borntoride
PostPosted: 17:07 - 09 May 2007    Post subject: Reply with quote
Opps guess whos a silly billy cheers demonNSR I wont do that again ha ha Embarassed Embarassed
borntoride
PostPosted: 17:09 - 09 May 2007    Post subject: Reply with quote
Yes Mate and she worked great it wasnt until I was riding her home. But demonNSR put me right on that Embarassed Cheers Guys
borntoride
PostPosted: 17:11 - 09 May 2007    Post subject: Reply with quote
Cheers everybody for your help I really appreciate it and look forward to many more discussions thanks and Happy Trails........
The last post was made 19 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 70.73 Kb
