VFR400 Oil Question
rpg
PostPosted: 18:22 - 08 May 2007    Post subject: VFR400 Oil Question Reply with quote
hi all, i set out to buy some oil for my VFR400 NC30 today at halfords. I was looking for a semi-synthetic 10W-40 engine oil. But when i got to the stand, there was either gear oil or engine oil to this specification. I was under the impression that engine oil was what i needed, but is there gearbox oil which is different to the engine oil? Meaning that i need to buy two oils-one for the engine and one for the gearbox?
Sorry if this seems a thick question, ive just never owned a bike like this before Embarassed
thank you
PostPosted: 18:33 - 08 May 2007    Post subject: Reply with quote
you were looking at car stuff. Cars use different oil to lube the engine and gearbox.DON'T BUY IT! Bikes use the same oil for both gearbox and engine.
Get Castrol GPS Semi synth 10W40. It's 25 odd quid for 3 litres and that will be enough. I've been told to avoid castrol R4 superbike, although I have never used it.
I wouldn't want to take chances with my oil esp. in a high revving 400 like the NC.
Just my Penny Coin Penny Coin
EDIT
https://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10151&productId=222387&categoryId=53791
That's the stuff you want. 25.99 for 4 litres. Easily enough for an oil change.
rpg
PostPosted: 18:51 - 08 May 2007    Post subject: Reply with quote
Thank You very much, Big-Ham Smile
PostPosted: 18:57 - 08 May 2007    Post subject: Reply with quote
All in a day's work. Cool Thumbs Up
Cillit-BANG
PostPosted: 20:44 - 08 May 2007    Post subject: Reply with quote
It's not just R4, you want to avoid any fully synthetic oil on NC30's. It can cause problems with clutch slip with certain clutch plates, so it's best to avoid as you'll waste £35 of oil if by chance you do have problems.
I presume you are changing the filter and drain plug washer too as a matter of course? Halfords should stock those too.
I personally prefer to support my local bike shop than Halfords though. Prices are usually comparable.
rpg
PostPosted: 21:36 - 08 May 2007    Post subject: Reply with quote
Yeah i have bought a replacement filter-but didnt know that the washer would need replacing too. Thanks for that Smile
PostPosted: 08:50 - 09 May 2007    Post subject: Reply with quote
They don't always. Honda reccommend you do, but I don't tend to bother.
I personally only ever use genuine OE filters on my bikes too, but that's just me.
Make sure you do the sump plug bolt up to the reccommended torque otherwise you may crack your sump if you overtighten it, or the bolt my vibrate out if you don't tighten it enough.
rpg
PostPosted: 16:58 - 09 May 2007    Post subject: Reply with quote
Thank You very much once again Smile
Ive bough a haynes manual so am going to try and work my way through it, as i dont fancy being walked all over at a garage as ive had it before, they saw a female and charged me the earth Sad
PostPosted: 17:08 - 09 May 2007    Post subject: Reply with quote
On a random note, oil filter tools are worth their weight in gold to get the old one off. You can get strap thingey's but I have never used them.
Cillit-BANG
PostPosted: 19:09 - 09 May 2007    Post subject: Reply with quote
Another reason why I prefer to use my local bike shop, they put a new sump washer in with the oil filter everytime I buy one from them, so it gets changed as a matter of course.
They are only 10p or so anyway.
Remember to have the bike upright when you check the dip-stick level, otherwise you will overfill it if you do it whilst on it's side stand Thumbs Up
The last post was made 19 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 63.81 Kb
