XHTML, CSS - How can I solve this problem?
pwntifex
PostPosted: 23:44 - 06 May 2007    Post subject: XHTML, CSS - How can I solve this problem? Reply with quote
Hi,
I'm working on setting up a travelblog on my site.
One of the features I'd like to have is a map system where I can show users exactly where I am at the present point by drawing a little dot on a map.
It'd work a bit like the way the location system works on BCF: I'd have a base image like this:
https://upload.wikimedia.org/wikipedia/commons/thumb/d/de/Uk_outline_map.png/450px-Uk_outline_map.png
And I'd be able to basically put a dot on the image wherever I was.
I don't need the backend calculation crap, all I need to know is
The best way to actively superimpose one image onto another image (preferably linkable, so that I can link to the latest post).
Thoughts?
bob-a-job
PostPosted: 02:49 - 07 May 2007    Post subject: Reply with quote
<div class="main">
<img class="map" src="Uk_outline_map.png" alt="This is the map">
<img class="dot" alt="This is the dot">
</div>
<style type="text/css">
.main
position: relative;
.dot
position: absolute;
top: 10px;
left: 22px;
</style>
Briefly tested on IE7 + FF, not got any other testbeds..
Not sure what you mean by linkable to the latest post...
bob-a-job
PostPosted: 02:57 - 07 May 2007    Post subject: Reply with quote
Two links added in to make the map and dot linkable (guessedthis is what you meant). NOTE that that class for the dot has moved from the image to the <a> ref...
<div class="main">
<a href="#Map_is_linked"><img class="map" src="Uk_outline_map.png" alt="This is the map"></a>
<a class="dot" href="#Dot_is_linked"><img alt="This is the dot"></a>
</div>
.main
position: relative;
.dot
position: absolute;
/* Y co-ord */
top: 100px;
/* X co-ord */
left: 22px;
</style>
bob-a-job
PostPosted: 13:35 - 08 May 2007    Post subject: Reply with quote
Oh and tw, i think the image created by this board is done on the server using image processing, ie the dots are drawn on map image by the server...
Dom
PostPosted: 14:04 - 08 May 2007    Post subject: Reply with quote
Nope, it uses CSS like yours:
https://www.bikechatforums.com/profilemap.php?x=473250&y=173750&x2=468750&y2=113250&tag=bob-a-job
Photos and that
bob-a-job
PostPosted: 14:14 - 08 May 2007    Post subject: Reply with quote
You are correct... well done have a karma cookie
should really check these sort of things before I say stuff... Rolling Eyes
pwntifex
PostPosted: 20:15 - 08 May 2007    Post subject: Reply with quote
Wish I could create a script that placed the dot based on postcode...Thinking
Thanks for the code bob!
sagalout
PostPosted: 20:36 - 08 May 2007    Post subject: Reply with quote
Postcodes in the UK are a nightmare because the Post Office own the rights to them. I've done a fair bit of geomapping for a few sites using googlemaps. Technically google wont goecode a UK postcode using its API because of the above reason, but theres a way around it. I can dig out the links if you want.
bob-a-job
PostPosted: 22:33 - 08 May 2007    Post subject: Reply with quote
Well here is a excel file holding loads of postcode (2821 i think) with their X, Y, long and lat values..
You will need to export data into a lookup table you have coded (i woiudl suggest server sided) and from the values gain it should plot the point for you...
Bob Thumbs Up
pwntifex
PostPosted: 21:03 - 09 May 2007    Post subject: Reply with quote
Bob Thumbs Up
That is a great resource! Have a cookie.
But behold as I ask yet another question which may be an incredibly stupid one: how do I convert the real x/y values into x/y values that correspond to the map?
Obviously 442900px x 419100px is not going to show up in de rite place...
bob-a-job
PostPosted: 23:14 - 09 May 2007    Post subject: Reply with quote
You will need to find the X, Y values of a specific point. So on you map find out what x,y values is Where you think London and work it out from there..
For example:
Lets say London on you map is
x = 350
y = 500.
Find a london value in the spreadsheet lets say
x = 442900
y = 419100
then get the difference:
x = 442900 - 350 = 442550
y = 419100 - 500 = 418600
From these value you can now work out the new vaslues fopr any postcode:
Pretend edinburgh is
x = 442900
y = 419100
~Then values for map will be:
x = 442650 - 442550 = 100
y = 418900 - 418600 = 300
I think thats right... Wink
BTW i would do this for a few values and work out the average, will produce a more accurate result...
Dom
PostPosted: 09:37 - 10 May 2007    Post subject: Reply with quote
Bob Thumbs Up
Cheers for uploading that Bob. It looks as though it could be very useful. Thumbs Up
Photos and that
The last post was made 19 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 76.56 Kb
